Question about Maytag LSE7806A Top Load Stacked Washer/Dryer
Just bought a new (old) house and the Maytag stackable w/d stayed. The dryer doesn't heat up at all. We've cleared the vents, but still no heat.
Check the igniter switch
Posted on Feb 04, 2015
    Problem Solver:
  • 17 Answers
Check that you have 220 volts. or see that the timer is not set to Air Fluff ( no Heat)
you may have a bad thermostat, or a broken
heater coil. or a broken belt.
Posted on May 26, 2010
Maytag Centennial Dryer (MEDC400VW) not drying properly
First of all, please make sure the vent is clear all the way through. Next the vent must be straight as possible. Next it can not be to long. People think that because they feel the air outside the vent is clear, not always true. The vent can be partially clogged. So make sure. Next, if the vent hose has sags or bows and even tight turns. It can accumulate the moisture in it from the drying proceed. If water has collected in the vent hose the clothes will not dry properly. If the vent is to long it can not dry properly either, the blower on the dryer can only move air so far. So the shorter the better. If all of these requirements are meet. Then, I would have to start checking the thermostats. I hope I have helped you. Please respond if you need further assistance.
Jan 29, 2014 | Maytag Dryers
The dryer runs but does not heat.
Check the thermostats again. One is bad.
Dec 01, 2012 | Maytag Dryers
Ignition works but doesn't stay on long enough to heat dryer
its either the hi-limit switch is weak on the burner tube,or the gas valve coils on the gas valve are weak and can no longer keep the gas valve open to supply gas,if they appear warm after operation they are most likely bad
May 24, 2012 | Maytag Dryers
My stackable washer/dryer is taking at least 3 cycles on high heat before it will dry one load. It's heating up but it doesn't get hot enough. I've checked the venting and it is clear and...
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Jun 19, 2011 | Electrolux Dryers
I have a Maytag Neptune gas dryer that is approx 8 yrs old and has worked great as far as drying time. The gas will now light and stay on for 15 seconds and then shut off, in 2 or 3 minutes it will light...
to me it sounds like your venting going out side,if it doesn;t get a clear flow it will come on and off the thermastate inside sencing to much heat.try unpluging the vent then try it if it stays on then you know your answer
Sep 12, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Unit will not dry clothes....vent is clear; no breaker problem; not over loaded; was working fine. unit is 6 years old.Will sometimes heat up at the start of the cycle but does not stay heated.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 09, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Gas Dryer Problem
Be sure vent is clear, if vent is clear you may need a new set of solenoids for the valve.
Jan 15, 2010 | Maytag Neptune MCG8000AW Gas Dryer
Dyer LSG7804ABE Gas Stackable very little heat
self help is right .first i would try a load with out the ducting.if you have good air flow and still didn't dry[because now youv'e elimanated the house venting as a possiable.replace your coils
Jan 02, 2009 | Maytag LSE7806A Top Load Stacked...
New Maytag gas dryer with long dry times
Double check that vent by finding where it exits your house. It should be blowing pretty hard, like a blow dryer. Guarantee you its a vent issue. Also check that when u push the dryer back against the wall your not crushing the vent. If you have a vent issue. Try sticking a leaf blower in the end that the dryer connects to. Quick fix unless you have a really long vent system. Hope that helps. Dave, www.washermd.com
Dec 15, 2008 | Dryers
Dryer has heat and tumbles but won't dry
your vent is stopped or the fan is not turning . most likely the vent under the house
Dec 14, 2008 | Whirlpool LER3622HQ Electric Portable...
Maytag LSE7806A Top Load Stacked Washer/Dryer Logo
119 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
