Question about Husqvarna Chain Saw 20" Bar
Husqvarna 350 oil not getting to chain
I have a Husqvarna 350 it has been oiling the chain well, it did not drip oil from under the cylinder cover. While cutting old trees with rotten (like dirt) center, the chain (under the cylinder cover) got real dirty. I removed the cover-clutch drum-etc. I then removed the "oil pick up plate" and cleaned the entire area and pieces. I reassembled the saw and now very little oil gets onto the chain. I removed the cylinder cover and there was chain oil all over everything under the cover. I did not change the "oil flow adjustment". I took it apart and reassembled it twice with the same result. Please help. Thank you!
  • Anonymous Mar 17, 2014
    No oil getting to the chain
    Brigadier General:
  • 4,088 Answers
Take the bar and chain from the saw. Clean the two small ports that run from the large oil holes at the drive end of the bar out to the chain groove on each side. Clean the entire chain groove. Start the engine with these parts removed--oil should ooze out from the side port in the engine case with the engine running at med speed. If it doesn't, then there is trouble near the pump inside the case. When everything is back together, run the saw at full speed with the bar tip near a piece of cardboard--it should throw off a thin line of oil onto the cardboard after a few moments of running. Hope this helps!
Posted on May 28, 2010
Husqvarna bar oil leak? I have a Husqvarna 55 Rancher. After it has been sitting for a while, there is a puddle of bar oil underneath it. After removing the bar and chain, then the clutch and starter...
There is always going to be some oil under the saw, the pump is a constent loss system, oil onto the bar and chain and away, there is a lot of areas in the crankcase and chain brake for oil to get caught and drip out once the machine is set down, if the oil loss is not excesive i would say yjere is nothing wrong here.
Mar 08, 2013 | Garden
How to adjust oil flow on husqvarna 235e
I dont think you can on this model. I think its permenantly set. However, depending on the season you can get 'thicker'/'thiner' chain oils.
Sep 06, 2012 | Husqvarna 14-Inch 34cc Gas Powered...
Husqvarna 350 saw chain oiler not working , possible solutions . thanks Ken
Remove the chain and cover holding it and check the hole that the oil comes out is not blocked by sawdust.
Aug 09, 2011 | Husqvarna 450 e-series 18" Chain Saw
Husqvarna 350 chainsaw problen..not enough oil getting on the chain
The 350 had a three position oil pump, the adjuster is on the bottom of the saw, under the pump on the drive side, there is also a filter in the base of the tank, it is held with a single cross head screw, you can see it between on the drive side, between the fuel tank, it is grey in colour.
Jun 29, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
My husqvarna automatic chain oiler doesn,t work...235 husqvarna any fixes?.
You may have gotten some saw dust particles inside the oil resevoir that got sucked into the delivery tube, thus clogging up the oiler...you can drain the oil out of resevoir and run some seafoam thru the oil resevoir to see if you can get it unclogged
Jan 23, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna 235 is not oiling.Hole and groove on bar have been cleaned. The saw does drip oil with the bar off when running.All parts are clean but bar is not getting oil.Hope you can help,thanks.
With saw running and high speed hold saw close to a piece of wood and check for oiling. If still no oil, then use air pressure at hole in bar to clear.
Sep 26, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Problems with the 350 husqvarna bar.
If all you say is true and when revved up the saw oozes oil with the bar removed, then I suspect the bar is incompatible with the saw. Has the bar been replaced? The oiler holes in the bar must align with the channel in the saw. Oiler hole placement is part of the reason there are so many different part numbers for bars. The mount is only part of the requirement.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Apr 03, 2010 | Husqvarna Forest & Garden #952802239 235E...
Husqvarna 359 leaking chain oil
Remove the sprocket cover, bar, and chain. Find area where oil is discharged from case--is any part of the rubber seal damaged? Next, use compressed air to clean sawdust and dirt from oiler ports in rear of bar as well as the chain slot. Are you using motor oil instead of bar oil? Make sure there is nothing to prevent bar from making close contact with oiler port in case. Reassemble all parts and adjust chain tension.
Apr 10, 2009 | Garden
Excessive chain oil coming from oil tank onto the chain.
there is a screw right next where the oil comes from need to turn it clockwise ,unless it came off
Dec 27, 2008 | Husqvarna Chain Saw 20" Bar
Husqvarna chain saw, model 455 will not oil properly bar and chai
hi cindilou50
check the oil filter from the oil tank,the oil line ,the worm gear and the oiler under the clutch.Clean the ways where the oil goes with compresed air.(after you fill out the oil tank)Also check the oil hose.
best regards savumihai71
Nov 30, 2008 | Husqvarna Chain Saw 20" Bar
Husqvarna Chain Saw 20" Bar Logo
1,207 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
