Question about Garden
Not sure the model, but was using the mower last night, everything was going good then all of a sudden the mower just stopped and shut down. Thought the blades caught something so I raised the deck, restarted the mower and let out the clutch and the back belt that runs the back tires was smoking. After further investigation I saw that the back pulley was not moving, does this sound like a clutch or transmission problem?
  • 10,515 Answers
This is not a Problem with Clutch.
There should be a model plate at the read near the hitch, under the seat, or under the hood. Can you check, please?
Let me know,so that we could Proceed.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on May 26, 2010
  • 5 more comments
  • leonhara May 26, 2010
    I'm currently at work and don't have the opportunity to check for the model # at this time
    The other thing that I wanted to add was last night when all of this was happening, when I restarted the mower and took my foot off the clutch basically the rear tires would not engage.
  • taran_2005
    taran_2005 May 26, 2010
    Thanks for your response!!
    For me to Pull up all Details, i need to have the Model Number.
    Once you would be at Home, you could check the Model Number and then we could move from there.
    Hope i helped you.
    Thanks
    Ok, when I have an opportunity to get that information I will let you know
    Thanks
  • taran_2005
    Sure, i would wait for the Update.
    Hope i helped you.
    Thanks
    I just spoke with my daughter, and she is going to go look for the make and model # but she cant do it till around noon today, so as soon as I get it I will post the information for you.
  • taran_2005
    Not an issue. Take your time. You could Post the information and when i would be Online,i would be able to take care of it.
    Hope i helped you.
    Thanks
  • leonhara May 27, 2010
    Hello the mower is a Murray and the model # is 38600e
MY CRAFTSMAN 6.75 HORSEPOWER 21" MULTI-CUT POWER PROPELLED ROTARY LAWN MOWER MODEL NO. 917.377972 WILL NOT START AND RUN . STARTS THEN QUITS HAVE TRIED EVERYTHING IT HAS BEEN A SHOP LAST TWO YEARS HE CAN...
If the carb is new, then make sure the fuel is fresh- LESS THAN 30 DAYS OLD!!! Is the plug good? Air filter OK? Good oil in the engine? Make sure that the shut off cable hasn't stretched. It may make contact and shut off the engine.
May 20, 2014 | Mtd 22" Yard Machine Push Mower
When I open the doors normally everything shuts off inside, ie radio, instrument panel etc. Last night it stopped working. Everything stays running. I hadto disconnect the battery to shut it down. Still...
you will have to look for the wiring diagram to find this but try finding the relay switch had same thing happen to my 94 camaro and that's what I dif
Mar 04, 2011 | 2004 Chevrolet Suburban
My John Deer L120 riding mower is shutting down
Two things to consider....fire and fuel. Lets start with the simplest....check and replace the fuel filter, drop bowl off the bottom of carb to make sure float is working properly. If this dosen't work...your looking at a new coil. Some coils will go quickly where others are gradual. As they heat up...they will stop working until allowed to cool down again. www.nnyparts.com
May 29, 2010 | John Deere 420,1020,2010,2020,2510,2520...
We had a power outage last night and now every light on the printer is flashing. I have shut down everything, reconnected, uninstalled and reinstalled.
turn on/off, unplug, plug in2_bing.gif, should reset configs.
go to applications folder for your computer, dbl click printer icon for make of printer. check settings. print 'test document and clean cartridge heads', this should reset printing formats.
lastly, go to web site of printer model and check site for trouble shooting if this does not work above.
hope this helps and good luck
Apr 29, 2010 | Brother HL-5240 Laser Printer
My car has had the computer replaced and also the fuse box but it still continues to just stop. I can be going down the road and all of a sudden it just starts to lose power and then stop. Last night when...
crankshaft position sensor is possible. it works of the rotation of the engine and makes the sensor to keep the car running. if it's not being made then it will shut down.
Apr 05, 2010 | 2006 Chevrolet Malibu
Wii Remote A/ B problem
I know this sounds silly, but be sure that you have fresh batteries in each Wiimote and that you have them in the right way.
Whenever you start up your Wii, the first Wiimote that you press a button on becomes controller number 1 and then subsequent Wiimotes are added in the order a button is pushed on them. SO, if you are thinking that you have remote 1 because that was the one that was remote 1 last night, it doesn't necessarily mean that it is so. Be sure that whenever you activate a Wiimote, the lights flash - 4 lights flashing mean strong battery, 1 light flashing means replace; when flashing stops, the number LED that is lit from the left denotes which remote you have. Make sure that is the same Wiimote that you select a game with, and make sure that is the one you press A&B together with to start the game.
If it doesn't work, shut everything down and start up using the other Wiimote. If that DOES work, then it could mean that your other Wiimote is not syncronized with the console. See the directions in your Wii manual on syncronizing additional Wiimotes (they're called Wii Remote by Nintendo) to your console.
Good luck. If all the above fails, you may want to go to www.nintendo.com and request customer service.
Mar 25, 2009 | Nintendo Wii Remote Controller
Elements in convection oven won't heat
DO you have a model number for that. I'm almost sure it's a thermal fuse in the back of the oven. Usually they go out during or after cleaning but that would shut down both elements. If you have the model (usually by the inside door look all over and up in the cavity) Then if you go to this link
http://www.searspartsdirect.com/partsdirect/index.action?intcmp=xsite_Sears
It will show you a breakdown of the oven and where it is. If you give me the model I'll show you what I'm talking about. Good luck.
P.S. if it the fuse it's a cheap fix, little hard to get in back of the oven but cheap!
Mar 04, 2009 | GE Ovens
Acer Aspire 1644WLMi System problem?
You may try a clean reinstall of WinXP - after that you will see if problem persists - i think is ???the processor burried. I have experienced somethink like this
don't forget to vote
Jan 30, 2008 | Acer Aspire 5100 Notebook
Garden Logo
23 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
