Plustek OpticPro 12000P Flatbed Scanner
Problem for Plustek OpticPro 12000P Flatbed Scanner
DRIVERS
By cesarblases on Apr 07, 2008
Dear Sirs:
I have this scanner and Windows XP Pro, but when I try to scan something, the scanner does not reach the end of the bed, I mean, it only reaches until 280.
When I had it installed with Windows 98 SE it didn´t happen.
What can I do?
Comments:
Apr 07, 2008
- Thank you, Ziau, but I think this is a software problem, because the pop up window is too small, and even I reach the lowest, the scanner doesn´t reach the end of the page.
By the way... do you speak spanish?
Same Problem
May 17, 2009
-   how did you get your scanner work on xp ??
I can't find any driver for this stuff on xp :(-   Guest
Solution #1
posted on Apr 07, 2008
Somewhat Helpful)
ziau
Rank: Wiz
Rating: 80%, 74 votes
cesarblases,
when u scan,there are pop up windows right?,which u select the dpm's etc..can u see the dotted lines out there?,adjust that t the lowest,and that means u select a full page to be scanned..chat me in if u want sum mor info..tnx
Comments:
Apr 07, 2008
- cesarblases,
nop,i dont speak spanish..y??
Was this helpful?
Yes
No
Solution #2
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
come si installa una stampante canon s400 su windows xp?
Popular Solutions for Plustek OpticPro 12000P
Questions and Unsolved Problems for Plustek OpticPro 12000P
Do you recommend Plustek OpticPro 12000P Flatbed Scanner?
Answer
Answer
I need a serail number from a plustek scanner to install a software that I use to edit photos and... (More)
Answer
I have uninstalled my scanner and when I came to re-install it I found the CD was for Windows 3.1... (More)
Answer
OpticPro 12000P scanner on XP worked fine for past number of years suddenly results in b/w printouts... (More)
Answer
Tengo un problema: cuando le doy a escanear, a?n seleccionando todo el ?rea de escaneado, no llega... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Plustek OpticPro 12000P...:
Top Scanner Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more Scanner Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
