The tv has locked and is asking for a 3 digit number. It will only let me key in numbers and cant do anything else, what can I do?
  • 12,061 Answers
You need you V-Chip, or parental code, to activate your TV it is in your manual, get a user manual, and look up parental protection.
Posted on May 26, 2010
Lifebook. Why can't I type on login page?
1. Press the Fn key a few times, it may be stuck.
2. Press the Fn key + the number lock key, your keyboard may be set as a number pad.
3. If you have access to a USB keyboard (e.g. from a desktop) then plug that in and see if it works.
Oct 30, 2015 | Fujitsu Computers & Internet
Curtis mathes LCD no remote and front panel is locked....
To unlock the panel lock, you should have its remote control. If you wish to buy a genuine remote control, you have to contact the authorized service center. If you wish to buy a universal remote control, you should know about, which brand remote control have set-up codes to your TV brand, and buy that one according to availability. The first thing you have to do is, to confirm the number of digits in the setup codes to your TV brand. There are 4 digit, 5 digit, 3 digit and even 2 digit codes. You can make it sure by entering '0s' at the code enter window the TV dispays, and asks codes. Enter 'Zeros', and count how many zeros can be enterd. That number will be the number of digit of setup code, the TV/Device need. If you can enter 5 zeros, the number of digit in the set-up code to your TV is a '5' digit one, if only 2 zeros can be enterd, the number of digits in the set-up code to your TV should be a 2 digit one, and so on.. If you wish to get more details about this, try the sites linked here. http://electrohelponline.blogspot.com/
http://electro-medical.blogspot.com/
Both the sites have setup code list, and setup procedure to many popular brand remote controls. Check the site in 'Mosaic' view. It will make search easy.
Jan 16, 2014 | Televison & Video
Code for NEO TV
Sounds like someone activated the lock (either V-chip or Parental Locking) on your TV. The only way around this is to find out who did, and get the code.
If you provide a model name and number, I can see if there's a workaround.
Jul 18, 2012 | Computers & Internet
Trying to program a direct tv remote to work with my 46" lcd, Vizio tv. Have tried the codes provided, but they don't show when I type them...not sure if actually being entered. Or, maybe have...
1 Vizio tv.code 0864 OR 10885 OR 11756OR 10178
Unable to Find Correct Code
If you were unable to find the code for your brand of TV or component, you can try a code search. This process may take up to 30 minutes.
1. Turn on the TV or component. Insert a tape or disk if applicable.
2. Slide the MODE switch to the TV, AV1 or AV2 position, as desired.
3. Press and hold the MUTE and SELECT keys at the same time until the green light under the selected switch position flashes twice, then release both keys.
4. Enter 9-9-1 followed by one of the following four digits:
Satellite - 0
TV - 1
VCR/DVD - 2
Stereo Receiver/Stereo Amplifier - 3
5. Press PWR, or other functions (e.g. PLAY for VCR) you want to use.
6. Point the remote at the TV or component and press CHAN+. Repeatedly press CHAN+ until the TV or component turns off.
NOTE: Every time CHAN+ is pressed the remote advances to the next code and power is transmitted to the component.
7. Use the CHAN- key to step back a code.
8. When the TV or component turns off, stop pressing the CHAN+ key. Then, press and release the SELECT key.
NOTE: If the light flashes 3 times before the TV or component responds, you've cycled through all codes and the code you need is not available. You must use the remote that came with your TV or component.
Verifying the Codes
Once you have set up the DIRECTV Universal Remote Control using the above steps, use the following instructions to find out the 5-digit code to which your component responded:
1. Slide the MODE switch to the appropriate position.
2. Press and hold the MUTE and SELECT keys at the same time until the green light under the selected switch position flashes twice, then release both keys.
3. Enter 9-9-0. (The green light under the selected switch position flashes twice.)
4. To view the first digit in the code, Press and release then number 1 key. Wait three seconds, and count the number of times the green light flashes. Write this number down.
5. Repeat step 4 four more times for the remaining digits; i.e., press number 2 for the second digit, 3 for the third digit, 4 for the fourth digit and 5 for the final digit.\
Depending on how you set up your remote, the VOL and MUTE may control the volume only on your TV, regardless of the position of the MODE switch. This remote can be set up so that the VOL and MUTE keys work only with the component selected by the MODE switch. To enable this feature, perform the following steps:
1. Press and hold the MUTE and SELECT keys until the green light under the DIRECTV position flashes twice, then release both keys.
2. Using the number keys, enter 9-9-3. (The green light will flash twice after the 3.)
3. Press and release the VOL+ key. (The green light flashes 4 times.)
Now the VOL and MUTE keys will work only for the component selected by the MODE switch position.
To Lock Volume to AV1, AV2 or TV
1. Slide the MODE switch to the AV1, AV2 or TV position to lock the volume.
2. Press and hold the MUTE and SELECT keys until the green light under the selected switch flashes twice and release both keys.
3. Using the number keys, enter 9-9-3. (The green light flashes twice.)
4. Press and release the SELECT key. (The green light flashes twice.)
Oct 03, 2011 | Televison & Video
Tv fuego
I dont know how to turn that asking but the key it is asking for is 512!
Jan 09, 2010 | Apex Digital GT2015DV 20 in. TV/DVD Combo
Wharfedale key code
Ur tv is lock could be letters or numbers or anythings.Ask the last owner for the codes.Try unplug it for awhile then replug the power,that all u could do.Codes to reset old tv might not exit anymore.
Oct 22, 2009 | Televison & Video
I want to be able to unock my sony ericsson w580i so that i may be able to put my vodane sim or indeed my orange sim card ,basiacally i want ti to be unlocked thanx!
Step by step instructions:
1.> Get your cell phones IMEI number. Press *#06# ( 5 key press) and you should see this number displayed on your phone. Note down all numbers except the last two. You will need this when you call your providers customer service to ask for subsidy unlock code. You can also get IMEI number by removing the battery cover and battery. You should see the IMEI number written on a sticker. This number is the correct IMEI number and should match the one displayed when you pressed *#06# on your phone except for the last two digit. AGAIN DO NOT GIVE THE LAST TWO DIGIT WHEN ASKING FOR SUBSIDY UNLOCK CODE.
2.> Call you cell phone customer service and give this IMEI number. Ask them to give you SUBSIDY UNLOCK code. Subsidy unlock code is 16 digit long number.
3.> Once you have unlock code, press <**< ( < is left navigation key) key combination ( 4 key press). Select Network to unlock network and enter the subsidy unlock code. Press OK. You will see Network unlocked message displayed. Inputting incorrect unlock more than 3 times will permanently lock your phone to your provider. So beware when you enter the numbers.
You now have a Sony W580i phone that is unlocked and can be used with any GSM based mobile providers.
Good luck. Hope it helps.
Feb 26, 2009 | Sony Ericsson w580i Cellular Phone
Need code for Directv remote for 26LG Flat Screen TV
Program TV Code
1. Turn on the TV.
2. Locate the 5-digit code for your TV.
3. Slide the MODE switch to the TV position.
4. Press and hold the MUTE and SELECT keys at the same time until the green light under the TV position flashes twice, then release both keys.
5. Using the number keys enter the 5-digit code for your brand of TV. If performed correctly, the green light under TV flashed twice.
6. Aim the remote at your TV and press the PWR key once. Your TV should turn off. If it does not turn off, repeat steps 3 and 4, trying each code for your brand until you find the correct code.
7. Slide the MODE switch to the DIRECTV position. Press TV POWER. Your TV should turn on.
Program DVD, VCR, Stereo Receiver, and Stereo Amplifier Code
The AV1 and AV2 switch positions can be setup to control a VCR, DVD, STEREO, second DIRECTV Receiver or second
1. Turn on the component you wish to control (e.g. your DVD Player).
2. Locate the 5-digit code for your component.
3. Slide the MODE switch to the AV1 (or AV2) position.
4. Press and hold the MUTE and SELECT keys at the same time until the green light under AV1 (or AV2) flashes twice, then release both keys.
5. Using the NUMBER keys, enter the 5-digit code for the brand of component being set up. If performed correctly, the green light under the selected position flashes twice.
6. Aim the remote at your component and press the PWR key once. The component should turn off; if it does not, repeat steps 3 and 4, trying each code for your brand until you find the correct code.
7. Repeat steps 1 through 6 to set up a new component under AV2 (or AV1).
Satellite - 0
TV - 1
VCR/DVD - 2
Verifying the Codes
Jan 14, 2009 | Directv RC23 Remote Control
You just dropped me without answering my question or really even trying
I can see you are frustrated so I'll see if I can help. Here are the Akai TV codes:
10812, 10702, 10030, 10672, 10060
As you can see, they are 5-digits for the direct remote, not 4.
This should help!
Program TV Code
1. Turn on the TV.
Satellite - 0
TV - 1
VCR/DVD - 2
Verifying the Codes
Hope this helps
Happy New Year!
Chris (ziraffa)
Dec 31, 2008 | One For All URC-3021 Remote Control
Sharp tv 2004 model
Program TV Code
1. Turn on the TV.
Satellite - 0
TV - 1
VCR/DVD - 2
Verifying the Codes
Jan 26, 2008 | Audio Players & Recorders
Televison & Video Logo
Top Televison & Video Experts
