Question about Toshiba Satellite U305-S7448 Notebook
Wireless deactivate from BIOS
It seams that Wireless is deactivate from BIOS. Pls advice the BIOS menue steps to activate.
thx.
  • 22 Answers
It is not in bios but in control panel under system under device drivers under network
if you see red next to wireless you need to enable
otherwise lot of laptops also have a small switch which turns on/off wireless
Posted on May 26, 2010
Can't get the wireless to come on
Exterior Wireless Switch
Step 1
Position the laptop so that you're facing the screen and the keyboard is in front of you.
Step 2
Check the front edge of the laptop's casing.
Step 3
Identify the wireless indicator light labeled with a wireless antenna icon. The "On/Off" switch to the left of the indicator light is the wireless switch.
Step 4
Move the switch to the "Off" position to deactivate the wireless adapter or move it to the "On" position if you want to power on the wireless adapter.
On-Screen Wireless Switch
Step 1
Press and hold down the "Fn" function key on the computer's keyboard to display the laptop's hotkey card icons on the screen.
Step 2
Click the "Wireless" icon on the screen or press the corresponding hotkey button on the keyboard, typically the "F8" key on a Toshiba laptop.
Step 3
Click the "Wireless On" or "Wireless Off" icon in the options list below the hotkey card icon to activate or deactivate all wireless connections. If your laptop has Wi-Fi and Bluetooth connections, you can also choose to activate or deactivate these services separately.
if have drives problem you can download using this link
http://www.toshibadirect.com/td/b2c/retail-product.jsp?poid=452315
Sep 13, 2013 | Toshiba Satellite L505DS5983 Notebook
How to get internect access with my alcatel onetouch mobile phone
Hi
You need to set the internet settings on your phone:
  • Go to menu >settings >wireless and networks
  • Select 'mobile networks' >GSM/UMTS Options
  • Press Access Point Names.
  • Select corresponding APN.
  • Now input data according to your local network parameters.
  • Make sure 'Disable Mobile Data Con' is deactivated by moving to menu >battery saver >Settings >Deactivate'Disable mobile data con'.
  • Now go to Menu >Settings >Wireless & networks >Mobile networks >Activate Data enabled.
No try internet connections.
Hope it helps.Thanks!
Feb 27, 2012 | Computers & Internet
I am unable to access the internet using Linksys Wireless-G 2.4. My laptop is Toshiba Satellite L645-S4102
http://us.toshiba.com/computers/laptops/satellite/L640/L645-S4102/ pres down the blue fn (function) key and F8 key at same time for activate and deactivate wifi/bluetooth on computer or check in bios settings if its enabled or not press esc or F10 or F2 key at boot up to enable bios settings
Aug 03, 2011 | Linksys Wireless-G Broadband Router
Connects to internet wireless then when surfing drops browser says not connected to internet. Computer says connected signal strength excellent
I presume your Number pad is Locked. To unlock it you should hold down theFn key then hit NumLk/F11 key.
If it is locked every time you start/restart then the num pad is activated in the bios. You should deactivate it in the bios. Press F2 during the startup POST (power on self test) to enter bios. There you should look for the alternative to deactivate the num pad(it is system dependent).
BR
Jan 13, 2010 | Acer Aspire One Netbook 8.9" Notebook
Dell wireless keyboard does not work after changing batteries. On the receiver the led is on showing the Numeric Lock Function is active. Not sure if this is coincidence or the problem, but can't seem to...
The first step i would take is to see if there is a reset button on the bottom of keyboard.
Then i would try to reconnect the keyboard to the receiver, by pushing the connect button on all devices.
If still not working, i then would uninstall the keyboards software, and then reinstall it. and connect the devices back to each other.
Oct 12, 2009 | Dell Wireless Keyboard Optical Mouse w0147
Can connect via cable, but when we try wireless we cannot make connection, we have a secure network but will not accept our password?????
hi
have you checked to see the access to wireless has been activated or deactivated.
also may have to check the channel of communication, any DNS, proxy settings
cheers
pls rate if this was any help
Jul 13, 2009 | Belkin (54G F5D7230UK4) Wireless Router
Help me out pls; my bluetooth and wireless are un funtional
Your laptop has a button which activates and deactivates the wireless network and bluetooth. Your manual should provide you with the detailed information as to where this button is.
Feb 01, 2009 | Computers & Internet
How do you turn on the wireless function on the esprimo v5535?
hai
According to the laptop's quick guide this is how you enable and disable your wireless:
Radio components: Wireless LAN/ Bluetooth/UMTS
The installation of a wireless LAN module not approved by Fujitsu
Siemens Computers GmbH voids the permits issued for this device
(see chapter "Technical data", Page 22).
Depending on the device variant, wireless LAN, Bluetooth and/or UMTS may be integrated in your notebook.
On delivery, WLAN components are switched on, Bluetooth components off.
Switching the radio components on and off
Start the WirelessSelector using the key combination Fn + F1 .
The WirelessSelector enables you to switch the radio components activated in
BIOS Setup on and off individually.
BUWlMuireTtlSeososthLAN
Press the key combination Fn + F1 to start the WirelessSelector.
The radio component indicator will be illuminated when one or more
radio components is switched on.
If you switch off the radio components, the Bluetooth module, UMTS and wireless LAN transmission unit (antenna) will also be switched off.
You can enable or disable the radio components individually.
BIOS Setup allows you to specify which radio components can be switched on
and off using the key combination Fn + F1 .
Only those components that have been activated in BIOS Setup can be switched on and off using the key combination Fn + F1 .
Conversely, components that are deactivated in BIOS setup cannot be controlled using the key combination.
You can also activate and deactivate the radio components individually in the BIOS Setup. You must have assigned the supervisor password in order for this function to be available.
Pay attention to the additional safety notes for devices with radio
components provided in the "Safety" manual.
Details on using Wireless LAN can be found in the online help system
included in the Wireless LAN software.
You can find more information on how to use Bluetooth on the CD you
received with your Bluetooth software.
Sep 06, 2008 | Siemens Computers & Internet
Toshiba Satellite U305-S7448 Notebook Logo
52 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
