Question about InFocus LP70+ Multimedia Projector
I can''t get the computer image on the screen.
I turned on the projector first and then my laptop. The only image showing is the InFocus logo.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 269 Answers
Reflash the unit with the current firmware and also make sure your cables are good.
Posted on Jun 21, 2010
I have a Dell laptop ready to go with my first Power Point presentation. I check the projector out from the library and there are no instructions. I googled instructions and tried the advice: Push Fn and...
Look for the F-key with a square/icon of a laptop. Press FN+This button until you see your screen display show that it will be using your LCD + the output on your computer. Remember you need to hook both the VGA or HDMI out to the projecter as well as the USB cable.
Mar 03, 2011 | InFocus In2102 Projector
My Infocus 4805 is just showing the INFOCUS logo and not showing the picture from the TV. all connections are correct but no signal....help
Powering On
  • If your InFocus 4805 projector is having a hard time powering on or doesn't power on at all, it could be one of two things. Due to the extreme temperature of the lamp that causes the temperature of the projector to rise, every InFocus 4805 projector has a cooling system. Check your projector's cooling solution, as it may need to be replaced. Also check the projector's fan---if the fan doesn't spin, the unit will not turn on. If the problem is the fan, you'll have to get it replaced. You can do this at the same place you bought your projector.
  • The Lamp
  • If your InFocus 4805 Projector powers on but does not project any light, the lamp will need to be replaced. All projector lamps must be replaced at some point---how often usually depends on how much use the device gets. Simply order a replacement lamp, unscrew the old one and screw the new one in. The projector will then work like new.
  • Color Wheel
  • If your InFocus 4805 projector powers on and is displaying images but the colors on the images appear warped or are not in the proper places, your "color wheel" will need to be replaced. The color wheel is a small device that essentially acts like a prism. Light is projected through it and it displays the appropriate colors on screen the way they appear in the original video source. Order a replacement color wheel that fits your model and use your instruction manual as a guide as you swap the old one out and put the new one in.
  • Aug 08, 2010 | InFocus ScreenPlay 4805 Multimedia...
    First time using infocus 1x projector with this laptop - installed drivers but there is no start up screen on the projector and will not display laptop image.
    You have to tell the computer you hooked up an additional external monitor. Lower left on the keyboard you will see a "FN" key. Across the top, your F keys...look for an icon that looks like a monitor. Usually F5, F7 or F8. Hold down the FN key and select the F5 etc key which is the command to display the image through the external port. Doing this once displays image through the projector and laptop. Twice displays image to projector only and three times returns to display only on laptop again.
    Jun 19, 2010 | InFocus LP640 Projector Multimedia...
    The Infocus logo image is up-side-down even without connecting to the computer.
    Many projectors allow you to vertically flip the image for mounting the projectors upside down. Each projector is different in how to change that setting, so I would look in your owners manual.
    Mar 11, 2010 | InFocus IN36 Projector
    Need image to show on both the HP laptop and the InFocus IN15
    make sure the laptop is plugged in and not on battery. also make sure the dmi-vga cable is not too long. the signal isn't strong enough to get to both screens.
    Jun 04, 2009 | InFocus LP70+ Multimedia Projector
    My projector only shows black and white images
    probably you are facing with an NTSC signal and a PAL source or vica versa
    try to check with a regular tv or with a different source
    Jan 03, 2009 | InFocus LP120 / 1000 Lumens / XGA / DLP...
    Colors showing red on screen
    Hi Stella,
    There is a button on the projector called "Auto Image"
    Most people don't realize it's even there.
    Press it while you are seeing this problem and most likely the projector will figure out the image issue and all will be well.
    Note: this feature is nowhere in the menu(s)
    Good Luck!
    SagerTronics
    Oct 29, 2008 | InFocus ScreenPlay 4805 Multimedia...
    InFocus LP70+ Multimedia Projector Logo
    77 people viewed this question
    Top InFocus Office Equipment & Supplies Experts
    jasbo
    jasbo
    Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
