Question about Hotpoint HDA2000G Built-in Dishwasher
DIrty Dishes SO i run a load a dishes through the diswasher and they dont come out clean. The original waste is gone but has been replaced by what looks like blended waste from the garbage diposal. I am wondering how you can declog the hose??? Or is it something else??? Thanks for your help.
    Champion:
  • 203 Answers
Try running it through empty with some cleaner in it check all the in side for anything clogging it and then if you can put some hot water in it to loosen any grese
Posted on Jul 10, 2014
5 Suggested Answers
SOURCE: Just connected a new garbage disposal up, and dishwasher won't drain anymore
The disposal has a knock out plug at the point where you connect the dishwasher hose. This is case someone doesnt have a dishwasher. It can be knocked out pretty easily with a hammer and screwdriver. Make sure that the power is disconnected because you will have to remove the plug by hand. Hope this helps!
-Walter
Posted on Jul 18, 2008
  • 4 Answers
SOURCE: my dishwasher isn't draining and
The impeller in the pump may be stuck, I have found that sometimes a small hard piece of material, in my case it was a toothpick gets stuck inside, most are easy to get too, but you do have to pull the dishwasher out from under the counter, unplug the electrical, and when you take off the drain line be sure to have a bucket handy, check tha drain lines, at the disposal as well, most parts are less expensive that you think, I use appliance parts on the web prices are fair, and parts come when expected.
Posted on Dec 23, 2008
heatman101
  • 43501 Answers
SOURCE: Dirty Dishes
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Posted on May 01, 2011
  • 1019 Answers
SOURCE: My dishwasher won't clean the
Check The Salt-Level ? Dishwashers rely, On salt and cleaning Fluids/Rinse Aids et,c. Also check for Any Blockages or Obstructions/Kinks/Bends et,c. in The External Outlet/Waste pipe.
Mike.
Posted on Jun 02, 2011
I have gritty debris on the dishes, it appears the small bits left on the dishes before loading get broken down and rinsed onto them as grit again! The dishes are not spotless going in but they are scraped...
1. it can be water backing upfrom maybe a garbage disposer like a clog ,or fill jet dry compartment completely.add nad fill then open and close the door 3 times then you will be able to add more what you are doing is taking out the air in the dispenser.once it is filled completely last thing is to make sure the water ghoing into machine is hot,then start the machine for best results. let me know if i have been of some help
Feb 24, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Mold growing on dishes
Recommend that you run another cycle with no DW soap aded, waiting until the dishwasher has filled with hot water and begins to do the first wash cycle. Then add 1/2 cup of bleach to the water and close the door. Allow the cycle to finish. Run it normally with a standard load of dirty dishes. Note: These high efficiency dishwashers count on the "dirt" of the dirty dishes to help wash/clean the dishes. Recommend you not rinse/wash the dishes before you put them in the dishwasher.
Watch for any occurrence of the black dots and repeat the bleach treatment.
Jul 22, 2009 | LG 24 in. LDF 7811 Stainless Steel...
My Hotpoint Aquarius diswasher won't dissolve the washing tablets
I don't have a solution, but the exact same problem is happening with my dishwasher. Nothing is getting cleaned properly.
Did you manage to get the problem fixed?
Jun 01, 2009 | Dishwashers
Dishes still dirty after wash cycle
It would be real helpful to have you provide the manufacterer and model number to get more specific with solution.
-Have you changes dishwasher soap powder recently? Buy a box of Electrosol or Cascade and see what happens. The ultracheep versions actually have caused cleaning problems, especilly in water-conserving dishwashers.
-Under the lower rack is the sump area with a filter that can be removed, usaully by removing several screws. Pull that filter, rinse is as best you can. Inspect under where the filter was and remove all debris. Watch out for broken glass that is found in most well used diswashers, it is hard to see and sharp! Reasemble the filter.
-If problems continue and if this diswasher is several years old, plan on getting the wash pump motor replaced (or replace the diswasher with a name brand, Energy Star model.) Good Luck!
Please update me with what you found. OK?
Mar 30, 2009 | Dishwashers
Dirty dishes on lower rack
Please confirm that you own an LG LDF7811 dishwasher and it is not cleaning properly.
-Are you getting any error codes displayed? -Did you remove the mesh filter and clean any debris beneath it plus rinse out the filter itself?
-Are you using a name brand diswashing powder? Avoid ultra-cheap detergent, especially in water-conserving units like the LG 7811. Never use DW gel or tablets in any dishwasher.
-Do not over rinse the dishes before placing them in the DW. The food granules actually are used to clean all the dishes before being rinsed away.
Please try these suggestions and reply to this message with what worked best and if the problem continues. Good Luck!
Aug 25, 2008 | LG 24 in. LDF 7811 Stainless Steel...
Dishes do not come clean grit on them
either dirty wash arms of insufficient water
Feb 24, 2008 | Frigidaire 24 in. PLD2850 Built-in...
Dishwasher not cleaning dishes. Casade cleaner not disolved.???
Run the unit with no soap, after about 5 min. of run time open door and check to see if water is clear or soapy,If soapy then you are having an oversudsng issue.When your washer gets to rinse cycle, your unit (if oversuding),will be rinsing with soapy water and the the drying cycle bakes the soap on dishes.You might be having a white film on your clear glasses.Cut down on soap especially if you have soft water.powder soap is best.Your dishwasher will fill , wash , the drain.Its what you put into it that will cause dishes not become clean.
Dec 01, 2007 | KitchenAid 24 in. KUDI02IRBS Stainless...
Dishwasher
Go to www.dishwasherfilter.com and have sparkling clean dishes with no film or spots, every time!!!
Make sure you use promo code DF5150 to get an additional discount!
Nov 14, 2007 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Dirty glasses
there is a new product out called the dishwasher filtration system. it actually filters the water going into your dishes. the dishes look dirty because your water has a lot of calcium and magnesium in it making them appear cloudy or dirty. the dishwasher filter reduces those minerals and my dishes look perfect now. no more dirty and grimy looking dishes. i also dont waste time washing them by hand before and after the dishwasher. hahaha you can get it at www.dishwasherfilter.com. use code DFMTEN and you will get 10% off. it fits right under your sink and is very affordable. you will be glad you bought this product. thanks
Sep 29, 2007 | Tricity Bendix 24 in. BDW53 Free-standing...
Dirty dishwasher
Sep 24, 2007 | GE 24 in. GLD5500L Built-in Dishwasher
Hotpoint HDA2000G Built-in Dishwasher Logo
44 people viewed this question
Top Hotpoint Dishwashers Experts
AcmeUK
Level 1 Expert
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
