Question about Maxtor Personal Storage 3200 (U01E200) 200 GB Hard Drive
No power!!! ALCON, My Maxtor One Touch 500gb Ext. Hard drive was working fine until a day ago. I moved to another room here while stationed in Iraq and upon plugging the ext. hard drive in, nothing happened. I have tried pushing the button on the front, I have tried many other plugs (also plugged other devices to those outlets and got power). I am unsure what to do and furthermore, am at my wits end as some files on it will extremely hard to replace. Any suggestions?? Thanks in advance, Cpl Justin Davis, USMC
  • 5 more comments
  • mobius12 May 16, 2008
    Same situation for me, I plugged it in, and all i get is the little green light on the front blinking dim and rapidly. no power to hard drive. I dont know what i did!
  • Anonymous May 27, 2008
    I have the exact same problem, I have no power at ALL!!, the green light that usually stays solid green is solid dead now. Is their a power supply fix?
  • spsshep Sep 06, 2008
    power supply plug dosen't work, can I get a replacement
  • turtlesam Sep 13, 2008
    maxtor will not stay on, it just stopped working
  • Anonymous Sep 30, 2008
    I get a faint light flashing but no power. It's clearly knackered! :( How can i extract the files?
  • Anonymous Oct 01, 2008
    No power faint yellow, tried the hard reset,power supply light is on.Dead Dead Dead...
  • Anonymous Nov 21, 2008
    I have the same problem light is on and the hard drive is trying to read but is not being recognised.
    Champion:
  • 230 Answers
Do you hear any sound when you plug in ?? any light blinking?
Posted on May 15, 2008
SOURCE:
My maxtor 500gb usb hard drive is not responding when I plug to my pc, so I can't access to any of my file
hello,
-make sure that the cables from the ext hard drive is properly connected like power if there is and USB -try other USB port -try other USB devices -try other USB cable for that Maxtor -try other computer
the reason why you are doing that is to know if the USB port is broken of if the ext hard drive is not responding.
cheers.
Feb 24, 2011 | Maxtor BASICS Personal Storage 3200...
How do I connect the hard drive for Maxtor One touch
Just use a standard USB cable to run from the drive to the computer's USB port, and connect the power adapter from the wall to the drive.
Feb 16, 2011 | Maxtor OneTouch 4 500GB External USB 2.0...
External HDD no longer recognized by new win7 PC
Probably not the right answer for your problem. Mine is an external 1 TB Simple Drive. Mine wouldn't respond at all. I unplugged the power cable from the back of the hard drive and replugged it in and instantly it worked. I had tried rebooting the computer, plugging/unplugging over and over into the computer and that didn't work.
Jun 19, 2010 | Maxtor OneTouch 4 500GB External USB 2.0...
My maxtor 250gb ext drive cant be read
Hi
Sounds like the armature of the drive has prob got damaged or the platters destroyed. If the data is important then maybe look into taking it to a data recovery specialised before its too late.
Do not attempt to pull apart yourself as ideally a 'clean Room' is required along with some pretty expensive kit.
Thanks
Taz
Oct 24, 2009 | Maxtor OneTouch II external hard drive...
Maxtor exter hdd 500 gb green light flashes but cant be detected
maxtor one touch 3 -500 does not detect on my macbook pro worked fine on my G5
Sep 11, 2009 | Maxtor MaxAttach NAS 3000 40 GB Network...
I have a Maxtor BAsics 500gb USB ext hard drive. The usb connector has come away from the circuit board. This circuit board can be removed from the main body - Question is ... Can i purchase any spares...
You can sometimes remove the connector clean up the sauder and reattach it to the circuit board. If you're handy with a saudering iron it's not difficult.
If you don't own one or aren't so handy I'm sorry to say it's not easy to find spare parts for those. What you can do though would be to take it to a computer store and ask them if they can sell you a new USB enclosure for your drive and they can move the HDD from the maxtor case into a working one.
This should prove an inexpensive solution either way.
Hope this helps FixYa,
Chris
Apr 21, 2009 | Maxtor OneTouch 4 500GB External USB 2.0...
External Hardisk Maxtor 4 One Touch not detected
Have you tried different USB cables with the drive? If the drive is self powered (no ext power supply) which I think that one is, then it needs a really good cable to draw the 5 volts from the USB port. If you have tried a known working cable, then it could be the USB controller or the disk itself. You can buy the USB box on eBay really cheap and move the drive over.
Apr 13, 2009 | Computers & Internet
500GB BAsics External USB drive
Simple Solution, Install XP on the Vista Machine...
Aug 28, 2008 | Maxtor Hard Drive
Maxtor One Touch III 320GB
THE PROBLEM IS MASTER AND SLAVE CONFIGURATION .. MAKE YOUR BACK UP HD A SLAVE IT MAY BE A MASTER NOW..
AND IF ITS A MASTER MAKE IT SLAVE
IF IT STILL DOESNT WORK THE CONTROLLER IC ON MOTHER BOARD CAN BE FAULTY.
Jul 28, 2008 | Maxtor One Touch III 500GB FireWire/USB2.0...
Hard drive is not recognize by the computer
have you tried using it on another computer? if its a plug and play device and it works on another computer, the problem may be with your computer. you have to first try this device on another computer to see if it works or not.
Jun 11, 2008 | Maxtor One Touch III 500GB FireWire/USB2.0...
Maxtor Personal Storage 3200 (U01E200) 200 GB Hard Drive Logo
184 people viewed this question
Top Maxtor Computers & Internet Experts
Ekse
Phil Whisenant
Phil Whisenant
Alun Cox
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
