Makes funny noise when I try to grind coffee and no ground coffee comes down into the handle.
Seems like something is stuck in the grinder.
if
you hear it trying to grind, but is not, or hear it spinning and is not
grinding, more than likely it is blocked, or so oily that bean will not
drop. Coffee beans, have so much oils in them, that after a while it
gets caked up, and beans either get jammed, or stuck. If you hear
grinder low humming, then it is probably stuck or clogged, if it is on
but hear like a spinning sound, beans are not dropping, because they are
stuck because of oil build up. If you can get to the grinder, turn
machine off, unplug, get all beans out, take like a wooden chop stick and put it in area where beans go and move the chop stick around the gears. you like your reaming it out kind of. turn machine back on, try this procedure a few times. ( MAKE SURE MACHINE IS UNPLUGGED WHEN DOING THIS) As said early if it is a low humming, like motor turning but
jammed, do not use until jam is fixed, you will burn up motor, then have
more expensive fix. Let me know if this helped and solved problem. Mr
Bean Man from Fixya
