Question about Mansfield Plumbing Products Mansfield QUANTUM White Round Front Pressure Assist Two-piece Toilet with S
I have a narrowboat which had a mansfield toilet fitted, the toilet has been removed but the tank, pump etc is still there, I would like to refit a pump out, can you get just the toilet or would another type/manufacture fit, for example a maceator type?
    Scholar:
  • 81 Answers
While toilets can look the same there are several variables as to whether ony particular one would fit. As far as maceator toilets go, they are a little spendy but can do the job when others can't. I sugest you continue your search by googling Saniflo and go from there. There is just no single answer for you.
Posted on May 29, 2010
Testimonial: "Thank you for your advise I have seen the Saniflo site, I will look further at the options."
I have a mansfield toilet and after flushing it keeps running, how can I fix that?
Not sure about your brand but many toilets have a flapper valve inside the tank which needs adjusting or replacing. Try this U tube link
How To Repair Mansfield Toilet
Apr 06, 2015 | Home
Mansfield 160 toilet diagram
The tank bolts do not get removed. The flush valve is mounted in a hole toward the rear of the tank. The nut under the tank is removed to allow removal of the flush valve from the inside of the tank. The replacement flush valve is inserted into the hole inside the tank and the nut is installed to fasten it in place
May 15, 2013 | Danco Flush Valve. Replacement Flush Valve...
Poor draining toilet checklist
1. Is the toilet plugged or partially plugged. I have removqed toothbrushes, combs, toys etc. from toilet traps so check for any obstructions.
2. Rust and scale buildup. The buildup of rust , sediment and or scale in the internal passages of a toilet can greatly affect their performance.clean the small holes under the rim with a small piece of wire. Use Limeaway or CLR to remove rust and scale. put some in the tank and flush toilet. Let sit for a while and repeat.
3. Improper venting or plugged vent. A toilet needs a properly vented drain to work correctly. Check the vent to make sure it is not plugged or in the northern climates frosted shut.
4. Mechanical issues. Is the flapper lifting high enough when flush lever is flipped. Is water at correct height in tank. If it is a pressure assist is water pressure high enough. Is pressure tank waterlogged.
These are just afew of the many things that can cause a poor flushing toilet. Hope this helps.
Jun 28, 2012 | Mansfield Plumbing Products Mansfield...
Remove toilet tank. In toilet seat is small hole filled with sealer. What is this for and if removed will it leak water?
If I understand you correctly you remove the tank and looked into the opening of the bowl where the tank attaches. There is usually a dollop of white silicone sealer. This is to plug a pssage created when the toilet was manufactured. Removing this will cause the toilet to not operate properly. If the hole is not sealed properly seal with a good grade silicone sealer. Make sure surface is dry before applying. Hope this helps.
Jan 31, 2010 | Mansfield Plumbing Products Mansfield...
Leaky toilet
The tank will unbolt and can be removed to replace this seal.
Better yet for about $130 you can have a 1.6 LF new in box and start saving water.
Hope this tip helps.
R/
David
Jan 25, 2010 | Mansfield Plumbing Products Mansfield...
Leaking under the rim of the toilet
Sound like what you are looking at is a corroded bolt that holds the tank onto the bowl. Remove and replace bolt and gasket with new part.
Jun 07, 2009 | Mansfield Plumbing Products Mansfield...
Problem removing old flapper unit from Mansfield tank
Disconnect the water supply first. Then use a large channel lock and remove the large plastic nut on the botton side of the supply system. Take the old one out and replace it just use caution when retightening the nut. The porcelon is very delicate. Check for leaks after you have turned the water back on and if you have to carefully tighten it some more. I hope this was helpful Have a good week end! : )
May 09, 2009 | Plumbing
My super new eco toilet splashes me in the face.
This sounds like a pressure-assisted toilet, yes?
If so, there is a pressure regulator inside the tank that my or may not be adjustable. Some are set for about 30 psi, but some manufactuers make a lower pressure model set to about 20 psi. I'm pretty sure you will need to remove the pressure assist assembly to access the regulator, which is inside the tank. If possible contact the supplier where you purcased the toliet, explain what's happening, and ask them what possible options you have for your model.
Mar 28, 2009 | Mansfield Plumbing Products Mansfield...
Mansfield Plumbing Products Mansfield QUANTUM White Round Front Pressure Assist Two-piece Toilet with S Logo
127 people viewed this question
Top Mansfield Plumbing Products Home Experts
jdthefixer
john h
bobalix
Are you a Mansfield Plumbing Products Home Expert? Answer questions, earn points and help others
