Question about Pride Mobility Products Casual CL20KD Lift Chair Chestnut
On board charger us.put in 3point socket,wires on new ch red,black,green,wires from scooter,white black,green.put red 2 white,bl 2 bl,gr 2 gr,seems to take charge ,no way as powerful as before ,could i have the bl and gr the wrong way thanks Bob
  • Neil Wood May 27, 2010
    Hi. Did you use a charger from a mobility scooter for your lift chair? If you did, its probably not the best idea. The scooter charger will be able to supply much more current ( amps ), and could greatly shorten the life of the batteries. Could also cause overheating of the batteries. Best idea is to purchase the correct charger for your pride lift chair. Neil.
    Problem Solver:
  • 17 Answers
Make sure you charge them for at least 8 hours
Posted on Jun 06, 2010
Chargers green light goes off as soon as inserted in boards 3 pin connector and not charging. seems dead.
Hi testing battery voltage will not give an accurate reading on battery condition U need a BATTERY LOAD TESTER.it will check the condition & give U a true reading on there condition ,..if batteries r good the next thing to check is the control box the charger circuit runs into the control then to the batteries if control box is faulty this could b the problem .,with youre charger not charging . LOAD TESTER AVAILABLE ON E/BAY APROX COST $35 , Cheers
Sep 19, 2016 | Blue Health & Beauty
How to wire trailer plug
hope this helps
6 pin socket
6 pin plug
7 pin socket
7 pin plug
5 pin socket
5 pin plug
7 pin socket
7 pin plug
7 pin socket
7 pin plug
7 pin socket
7 pin plug
12 pin socket
12 pin plug
small 6 pin round plug & socket
1 tail, clearance - brown
2 left hand turn - yellow
3 right hand turn - green
4 stop - red
5 electric brakes - blue
6 earth - white
small 7 pin round plug & socket
1 left hand turn - yellow
2 reverse - black
3 earth - white
4 right hand turn - green
6 stop - red
7 tail, clearance, side markers - brown
roundskt.jpg round socket
large 5 pin round plug & socket
3 earth - white
5 right hand turn - green
6 stop - red
large 7 pin round plug & socket
2 reverse - black
3 earth - white
6 stop - red
7 pin round heavy duty plug & socket
1 earth - white
2 left hand rear , clearance and marker - black
3 left hand turn - yellow
4 stop - red
6 right hand rear , clearance and marker - brown
7 reverse/auxilary - blue
7 pin flat plug & socket
2 reverse - black
3 earth - white
6 stop - red
7_flatsocket.jpg flat socket
12 pin flat plug & socket
2 reverse - black
3 earth - white
6 stop - red
8 battery supply - orange
9 auxiliaries - pink
10 earth - white
11 rear fog lamp - grey
12 auxiliaries - violet
Feb 02, 2013 | 2004 Toyota RAV4
Need manual for wiring phones
The 612 system required 3 pairs per phone. Every 3 pairs on the 25 pair cable would be one station. A modern 6 conductor jack would be wired according to the label. If you have jacks with Green,Red,Black,Yellow,White, and Blue wires, then it's wired as follows.
W/Bl - Green
Bl/W - Red
W/Or - Black
Or/W - Yellow
W/Gr - White
Gr/W - Blue
Oct 12, 2012 | Inter-Tel (660.7600) Corded Phone
I needto replace the battery charger on my Rascal 600F scooter
Hi. Most chargers with only two wires, have a small bridge wire from the
black ( negative ) wire to the middle terminal of the connector. This disables the controller while the machine is charging. The charger will still work without this bridge wire, but the scooter will still operate normally.
There are a few different chargers around that have an internal relay that disables the scooter, but these chargers are normally "on-board" chargers.
Good luck. Neil.
Jul 05, 2010 | Electric Mobility Power Electric Scooter...
My T101 timer switch is installed allready, but I dont know how to hook up the pool filter to it, it has three wires on it, black,white and green
If the timer is already installed, then the incoming (from the breaker or source) black wire should be connected to the #1 terminal. The incoming white wire should be connected to the "A" terminal and the bare (or green) wire should be connected to the "GR" screw on the (lower) case.
To connect the pool filter (load) to the timer, connect the black wire to terminal #2, the white wire to terminal "A" (along with the incoming white wire) and the green wire to the "GR" screw (along with the incoming bare or green wire). Usually one twists the two green or bare wires together with a short pigtail using a yellow or red wire nut and then connects the pigtail to the "GR" screw.
The two white wires don't need to be pigtailed, as the "A" terminal is designed for two wires.
Apr 25, 2010 | Intermatic T101 - 24 Hr. Dial Time Switch...
Wiring a TPH553 Surface Mounted Jack by RCA.
TPH553 T568A T568BPin 1 - BL White/Green White/Orange Pin 2 - OR Green Orange Pin 3 - BK White/Orange White/Green Pin 4 - RD Blue Blue Pin 5 - GR White/Blue White/Blue Pin 6 - YL Orange Green Pin 7 - BR White/Brown White/Brown Pin 8 - WH Brown Brown
REF: wikipedia
Feb 17, 2010 | Computers & Internet
My father bought a new charger from a battery store, they wired it, it had a white , black , and green wire, they tied the black and white together going to one lead of charger and the green to the other...
hi,
The battery connections are normally positive 24, Negative 24 & inhibit which is normally grounded, for some scooters the charger connections go to the batteries plus the controller but that does not mean it been zapped, hopefully there is a fuse (Car type ?) under where the seat seat stem is , a simple test is to turn it on, does the horn work ? does it appear to power up ?
Some scooters have a fuse in the tiller panel or control panel as it otherwise known so check it out and hopefull it will work.
Regards
GeWiz.
Dec 23, 2009 | Golden Technologies Companion II Travel...
Replacing front turn signal socket on 1990 dodge shadow
Okay. Hook black to black.
Green to green with white stripe.
Yellow to red with white stripe.
That should work. Nothing is going to blow up if it's wrong. It just won't work.
May 15, 2009 | 1990 Dodge Shadow
Pride Mobility Products Casual CL20KD Lift Chair  Chestnut  Logo
114 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
Robin Hill
Robin Hill
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
