Question about Philips MCD288/37 DVD Micro Theater System Theater System
I have an LG home theatre HT353SD, the problem is that the disc tray says LOCKED and won't open, although everything else work perfectly, tried the menu, the remote but nothing to solve this, I think it needs a pin code or something, any ideas!!!!!!!
    President:
  • 1,099 Answers
you do not need a code, all you need is open the cover of the system and check for the rubber attached to the motor of the mechanism if it is slack or cut .
but if it does not have a rubber , the problem is from the mechanism.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The following website sells the drives mechanism and does installs:
store.richsxparts.com
hope this will help....
Posted on May 26, 2010
Panasonic DVD Home Theatre not reading
Make sure the tray is clean - no debris on tray If the disc is misaligned slightly it will spit it out
Make sure you are not putting them in upside down
and lastly find a new disk (not home made one) and see if this one works
Disks get damaged much easier than people realize\
If nothing works you have no choice but use a proffessional
Feb 06, 2012 | Audio Players & Recorders
I have a Philips HTS 3371 DVD home theatre and can not play many DVD's as it give wrong region error. Can you please provide the unlock code and how/where to enter it to get it fixed?
Hi -
Please follow the instructions below for unlocking your Philips HTS 3371
Please note: Unlocking a DVD player may invalidate the warranty. Unlock sequences may not work with some firmware updates and some DVD players have been damaged through failed attempts to unlock them. Unlocking your DVD player is done at your own risk.
1. Switch the DVD player ON
2. OPEN the disc tray
3. Key 9 9 9 9 0 using the Philips remote control supplied with the player
4. Press PLAY. The disc tray will close.
5. Switch the player OFF then switch ON again.
6. To test, play a disc from a region which was previously locked.
If it does not work the first time, switch the player off and back on, then try again.
This is a verified unlock method, but I was unable to confirm whether it works for players sold locked to Region 1 (North America). If you have a Region 1 player and the method above does not work, you will not be able to unlock your player.
Regards,
BElectric
Mar 26, 2011 | Philips HTS3371D Theater System
Installing a LG Network Blu-ray Disc/DVD Home
YOU NEED TO CONNECT OPTICAL CABLE (NOT INCLUDED) TO OPTICAL1 CONNECTION ON YOUR HB405 AND OPTICAL OUT OF YOUR TV. IF YOU ALREADY HAVE DONE THAT TRY PRESSING SIMPLINK BUTTON ON YOUR TV REMOTE NAD CHANGE THE SPEAKER OUTPOUT FROM TV TO HT(HOME THEATER).
Jun 19, 2010 | LG Televison & Video
My LG LHB977 home theatre Displays NO DISC whenever I insert any disc.What could be the problem???
It may be a dirty "laser lens". It is possible to clean this lens w/rubbing alchohol and a Q-tip.
Disconnect all power b4 disassembly.
Aug 20, 2009 | LG LHB977 Theater System
LG HT353SD?
open tray
0 0 0
then appears a screen asking for region, put 0 for free region, then press pause.
done
Aug 23, 2008 | Philips MCD288/37 DVD Micro Theater System...
RCA RTD206 HOME THEATRE
This is an indication that the optics are either dirty or failing. Carefully open up the unit and clean the lens using a cotton swab and alcohol. That should resolve the problem. If not, try playing a music CD. If the CD plays but a DVD does not, the optics are failing and need to be replaced.
Dan
May 22, 2008 | Audio Players & Recorders
Disc is stuck in machine
When the try is stuck:
On a Lifestyle system with a tray that won't open, try this:
  1. Turn off the power.
  2. Unplug the power cord.
  3. Wait at least 5 minutes.
  4. Plug the power cord back in.
  5. DO NOT TURN THE UNIT ON !
  6. Hit the Open/Close button.
This worked perfectly for me!
drgeri
Dec 24, 2007 | Bose Lifestyle 38 System
LOCKED displays when attempting to eject disk from SA-HT670
i have a panasonic SA-HT720 and it displayed locked anytime i wanted to eject discs so i found out that dad27's solution was the best and holding down the stop and power buttons also locks the system as well as unlocking it. God richly bless u dad27 u really helped me out
Jul 27, 2007 | Panasonic SC-HT670 System
Philips MCD288/37 DVD Micro Theater System Theater System Logo
581 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
