Question about Dell Dimension 4600 PC Desktop
When I switched on my Dell computer - bright blue
When I switched on my Dell Dimension 5000 computer - bright blue screen appears which I can't progress past and says ''Unmountable_Boot_Volume'' Technical:- Stup. 0x000000ED 0x8736F9E0, 0xc000009c ''If problem continues disable BOIS memory option
Any thoughts?
    Sergeant:
    Champion:
  • 256 Answers
This error usually is for hard drive issue. if an operating system reinstallation wont work, a hard drive replacement should resolve this problem.
Posted on May 26, 2010
I have a dimension 5000 desktop, when I turn on I get a short burst on screen saying DELL, but then a blank screen. I hear a continuos beeping tone and all lightss on front of unit are dispalyed. Please...
Well if its a dell monitor also, it will say dell, and does not mean the computer is communicating with it, your manual is here ftp://ftp.dell.com/Manuals/all-products/esuprt_desktop/esuprt_dimension_desktops/dimension-5000_Owner%27s%20Manual_en-us.pdf (copy and paste) what EXACTLY is the beeping code doing, the term continuous beeping tone could mean different things. You should have 4 small led lights on the rear that say A, B, C, and D that are diagnostic lights, what color are those?
Jan 06, 2014 | Dell Dimension 9100 PC Desktop
Recovery partition
blue screen is an indication of failed hard drive
take it to an it specialist and have the problem properly diagnosed
Jun 25, 2017 | Dell Dimension 9200 PC Desktop
Red blue and green patterning on the monitor
You can try switching out the VGA cable (the one with the blue connectors on each end). If this does not work, try a factory reset on your monitor.
Oct 15, 2012 | Dell Dimension E521 AMD Athlon 64 X2...
I need to reset a dell dimension 8400 to factory setting what f key do I use
Welcome to FixYa!
Using Dell PC Restore by Symantec
Use Dell PC Restore by Symantec only as the last method to restore your operating system. PC
Restore restores your hard drive to the operating state it was in when you purchased the computer.
Any programs or files added since you received your computer-including data files-are
permanently deleted from the hard drive. Data files include documents, spreadsheets, e-mail
messages, digital photos, music files, and so on. If possible, back up all data before using PC
Restore.
NOTICE: Using PC Restore permanently deletes all data on the hard drive and removes any applications
or drivers installed after you received your computer. If possible, back up the data before using PC
Restore.
To use PC Restore:
1 Turn on the computer.
During the boot process, a blue bar with www.dell.com appears at the top of the screen.
2 Immediately upon seeing the blue bar, press .
If you do not press in time, let the computer finish restarting, and then
restart the computer again.
NOTICE: If you do not want to proceed with PC Restore, click Reboot in the following step.
3 On the next screen that appears, click Restore.
4 On the next screen, click Confirm.
The restore process takes approximately 6-10 minutes to complete.
5 When prompted, click Finish to reboot the computer.
NOTE: Do not manually shut down the computer. Click Finish and let the computer completely reboot.
6 When prompted, click Yes.
The computer restarts. Because the computer is restored to its original operating state, the
screens that appear, such as the End User License Agreement, are the same ones that
appeared the first time the computer was turned on.
7 Click Next.
The System Restore screen appears and the computer restarts.
8 After the computer restarts, click OK.
Good Luck
Nov 11, 2010 | Dell Dimension 8400 PC Desktop
No Sound Dell Dimension 3000
1)Check whether sound is enabled in bios.
2)Install Latest drivers from support.dell.com
3) Boot From the ResourceCD to Run Dell Diagnostics
1. Insert the ResourceCD in the optical drive, and restart the computer.
2. Tap the <F12> key during startup until the One Time Boot menu appears.
Note: If the One Time Boot menu does not appear, restart the computer and try again.
3. Press the <Down Arrow> to highlight Boot from CD, and press <Enter>.
4. In the ResourceCD menu, select Run the 32 Bit Dell Diagnostics, and press <Enter>.
5. The Dell Diagnostics screen appears.
Run sound test
Jan 10, 2010 | Dell Dimension 3000 PC Desktop
Dell computer blue screen saying STOP
Try installing the operating system or repairing the operating system.
Feb 22, 2009 | Dell Computers & Internet
Blue error screen and system shutdown on Dell Dimension C521
Rule of thumb test ram out first usally that is the cause what does the code say on the blue screen
Feb 13, 2009 | Dell Dimension C521 PC Desktop
Recovery disk
Hi jaspa - this is how it works:
To use PC Restore:
2 Immediately upon seeing the blue bar, press <Ctrl><F11>.
If you do not press <Ctrl><F11> in time, let the computer finish restarting, and then restart the computer again. NOTICE: If you do not want to proceed with PC Restore, click Reboot in the following step. 3 On the next screen that appears, click Restore.
The restore process takes approximately 6–10 minutes to complete.
5 When prompted, click Finish to reboot the computer. NOTE: Do not manually shut down the computer. Click Finish and let the computer completely reboot. 6 When prompted, click Yes.
7 Click Next.
If this solves your problem PLEASE rate this as fixed. If it did not or you had problems, DO NOT RATE YET, just add a comment letting me know what happened and I'll be happy to assist you further. Thanks.
Jeff
May 10, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension 5000 - Installing extra Hitachi 500GB SATA Hard Drive
you need to turn it on in the Bios so the computer sees the drive, then format it.
Jan 20, 2008 | Hitachi ( 0A30229-20pk) 400 GB Hard Drive
Dell Dimension 4600 PC Desktop Logo
96 people viewed this question
Alun Cox
