Question about Maytag MSD2756G Side by Side Refrigerator
Freezer is cold but fridge is not
Setting is appropriate. fan runs. Freezer is cold, ice is OK but the fridge portion is not cooling.
model not available but would be RSW2700, RSW20E or RSW22E0
  • Maytag Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
tygf
Posted on Sep 29, 2010
Bosch kann58a50gb/o8 fridge not cooling freezer seems ok
See or hear if the fan inside is working. Im not conversant with your model. Some units have 2 fans , 1 in the freezer and 1 in the fridge. Some only have1 , which will be in the freezer only. If the fan fails, the fridge cannot blow cold air into the food compartment. Generally, when an evaporator fan fails, the fridge doesn't get cold and the freezer overfreezes causing an excess ice buildup in the freezer.
Feb 23, 2015 | Bosch Refrigerators
Whirpool wgi fridge freezer, fridge not cooling?
Most frideges get all their cooling from the freezer. There will be a fan and duct in the back of the freezer that pushes cold air down into the fridge. If the duct is blocked with ice or the fan motor has quit. Your freezer will work fine but the fridge will barely cool at all. Check that the fan runs when the compressor is running, ( turn both temp knobs to the highest cooling and leave door open until comp. comes on). If the fan runs your duct is plugged. If not you need a new " Freezer Fan Motor". Most are simple to replace and cost around $100.00.
Jan 01, 2012 | Whirlpool Refrigerators
I have noticed that the fridge part is not cooling the way it should while the freever part still looks to be freezing at the appropriate levels. What can i try to fix it. the fridge is only 1.5 years old
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it'll be the control.
Jan 21, 2011 | Kenmore 73502 / 73504 / 73509 Bottom...
GE Monogram Built In Fridge-freezer is not cold enough, but ice is ok...refrigerator is too cold no matter the setting. Someone suggested vacuuming filter above the fridge. Would this work?
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Feb 23, 2010 | Refrigerators
Kenmore fridge not cooling
check for your freezer fan running properly
then check to make sure you have air flow into the freezer this model has a habit of freezing ice in the air channels
Oct 07, 2009 | Refrigerators
The refrigerator is not cold only cool. the freezer door got accidentally left ajar and got ice build-up on the food. Ever since that the refrigerator portion is only slightly cool not cold. I moved the...
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. The ice may have also stopped up this opening blocking the air flow.Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
Sep 21, 2009 | Refrigerators
Freezer works, fridge doesn't cool
Probably excessive ice in the condensor. Likely defrost thermostat or defrost heater problem.
What happens is excessive ice keeps airflow from the refrigerator part of the unit.
Jul 08, 2009 | Refrigerators
GE Side By Side top portion of fridge and freezer not cooling
heatman101
Jan 28, 2009 | GE Hotpoint Top-Freezer Refrigerator
Ice maker stopped working, plus fridge not cold, but freezer o.k.
I would check that fan motor in the freezer section is running. it distributes cold air from freezer into refrig section also if this motor is running the top portion of freezer will not get cold enough to allow ice production. the motor is easy to repl and is mod# specific you should be able to buy one online.
Jan 21, 2009 | Kenmore 64802 Top Freezer Refrigerator
Freezer fan
actually, freezer fan has to come on otherwise how is the fridge supposed to cool.(fridge draws off from the freezer compartment). check if there is power to the fan. if freezer is nice and cold and fan does not run(assuming there is no power to the fan at that time, then you would need to check your freezer thermistors after that, your board. all this is assuming you dont have a blockage or shortage of gas in the sustem.
Sep 20, 2007 | Kenmore 72293 - Stainless Steel Top...
Maytag MSD2756G Side by Side Refrigerator Logo
223 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
