Question about Homelite Mighty Lite Lawn Trimmer
Engine start and shutdown - Homelite Mighty Lite Lawn Trimmer
  • 1,383 Answers
CHECK THE SCREEN ON OUTPUT OF THE MUFFLER. ITS CALLED A SPARK ARRESTOR, THESE GET OIL FOULED AND MAKE EM A BEAR TO RUN . CLEAN IT UP AND SHE WILL RON LIKE A CHAMP, THE CARB MIGHT NEED REBUILDING AND A SPARK PLUG IS THE FIRST THING TO REPLACE .. IF'N I WAS ANY HELP VOTE FOR ME ...THANKS.. JAY
Posted on May 26, 2010
Testimonial: "your answer was very helpful.thanks"
Engine runs for about 30 seconds and shutdown like an electrical shutdown as opposed to a fuel related shutdown.
Engine fired up, ran normally for 30 seconds, then shut down ...
www.thedieselstop.com > ... > 7.3L IDI Diesels (Not Power Strokes)
Sep 25, 2012 - Engine fired up, ran normally for 30 seconds, then shut down. ... it fired up and has been running since... if it just ran out of fuel jump it, and keep ...
Viewing a thread - cummins m11 starts then dies - AgTalk Home
talk.newagtalk.com/forums/thread-view.asp?tid=332921...flat...1
Sep 24, 2012 - 9 posts - ‎9 authors
98 KW with a cummins m11 will start and run for 5 seconds then dies. ... anything else like that, because it would run for 30 seconds and then die, not 5. ... The engineprotection system will not shut down the engine unless the ...
[PDF]John Deere Engine Safety Shutdown with "Black Box" (prior ...
www.tuckerbilt.com/.../John%20Deere%20Engine%20Safety%20Shutdo...
John Deere Engine Safety Shutdown with "Black Box" (prior to Tier II ECU ... Ifengine fails to start in 30 seconds, the Low Oil ... Test #1 (Engine not running).
1800 RPM for 30 sec before shut down [Archive] - Pilots of America ...
www.pilotsofamerica.com > ... > Pilot's Lounge > Technical Corner
Jan 01, 2016 | Cars & Trucks
Lexus 1979 2JZ engine start but shutdown after i select gear
Use a bottle of yellow HEET dry gas to remove any moisture problem in the fuel.
Clean / replace air filter.
Top off ATF to MAX level.
Jan 16, 2014 | Lexus Cars & Trucks
The van was running great, then all of the sudden it just died, the check engine light came on said it was crankshaft senser, put a new one on, ran good for a bit then did the same thing, put another one...
the shutdown relay does that. Check cooling system and
oil pressure sensor. engine gets too hot or not lubricated enough that the ECM tells the shutdown relay to shutdown the engine.
Dec 28, 2017 | 1997 Dodge Grand Caravan
Engine shutdown after 5 minutes
May be a dirty fuel filter. It is basically running out of gas because dirty filter is creating a bottleneck in the fuel system.
Mar 27, 2012 | 1994 Toyota Camry
I have a 2003 dodge dakota. 4.7l. I get codes p0685 and p0688. No start no spark. Relay is good. But voltage drops when using a voltage meter on one of the grounds in the pdc. Any live wire and that ground...
P0685 DODGE - Auto Shutdown Relay Control Circuit Failure
Symptoms - Engine Light ON (or Service Engine Soon Warning Light)
Possible causes - ASD relay circuit is open or shorted
- Failed Auto Shutdown relay
- Failed ECM
Tech notes Check all the ECM fuses, if the fuses are OK try replacing the ASD relay. P0685 DODGE Description Short or open in Auto Shutdown (ASD) relay circuit
P0688 DODGE - Auto Shutdown Relay Control Circuit Low
- Failed ECM
Tech notes Check all the ECM fuses, if the fuses are OK try replacing the ASD relay. P0688 DODGE Description The Front Control Module (FCM) has detected the supply voltage below an acceptable value
Jun 24, 2011 | 2003 Dodge Dakota Club Cab
I had my Smartstart intalled by a dealer. They were able to get the doors to work. but Directed to d them if the doors work then my engine should start after I activate my subscr iption. Well I did and it...
The multiple flashes of the parking lights are shutdown diagnostics:
1. 1 flash is runtime expired
2. 2 flashes is over-rev shutdown
3. 3 flashes is low or no rpm (tach wire)
4. 4 flashes is transmitter shutdown
5. 5 flashes is + brake shutdown
6 6 flashes is - hood shutdown
7. 7 flashes is timer mode/turbo mode manual mode error
8. 8 flashes is neutral safety shutdown ( the remote start control switch is in the off position).
9. 9 flashes is low battery (voltage setting)
10. 10 flashes is alarm triggered
11. 11 flashes is wait-to-start input timed out.
Hopefully, the above mentioned diagnostics will help you determine why your remote starter is not working and you will begin to enjoy the system.
Nov 25, 2010 | Viper SmartStart Module
Engine Shutdown
http://groups.yahoo.com/group/villagerquest/files/
sounds like idle air control is bad or needs cleaning. see site.
Jul 04, 2009 | 1999 Mercury Villager
Engine starts but shuts down immeditately
1989 Chrysler 2.5 L Turbo has a duel hall effect pick-up in the distributor. It is possible that the pick-up is not working. A "start and stall" indicates that this may be the problem.
Another problem may be the fuel system. Check fuel pressure with key on... should be 40-50 psi on multi-port. 30-40 on TBI
PS If the auto shutdown relay quit then you would not get a start at all. PSS oil pressure will cause a similer problem
May 26, 2009 | 1989 Chrysler LeBaron
VW Cabriolet 1.8 Liter Stalls after initial shut down
mcdevito75 here, Sounds like a faulty cold start valve / sensor. Have the shop check out the cold start system of your engine.
Apr 12, 2009 | 1989 Volkswagen Golf
Homelite Mighty Lite Lawn Trimmer  Logo
229 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
