Question about Samsung Syncmaster 730B 17" Flat Panel LCD Monitor
When i lose power to the house and try to bring my computer back up , my monitor does not stay on meaning there is power to the monitor but the screen goes blank after about 2 seconds - samsung syncmaster 731b
  • 11,361 Answers
Power supply failed.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on May 26, 2010
VL 1716 monitor. The display blanks out after 20-30 seconds. When I turn the power OFF anf Back ON, the display comes back normal, then blanks out agin after 20-30 seconds. The power light stays green.
This is due to system goes to stand by mode or Hibernate mode. To disable, go to power management and disable or incrase the time for the same.
Revert back for more assistance. Also give your valuable feedback/rating on the same.
Feb 08, 2010 | Computers & Internet
Monitor says it is going to sleep and there is only a black screen.
Monitors go to sleep when there is no computer activity it detected. Also, when your OS is working and somehow you have set a "sleep" time, then the monitor goes to sleep at the appointed time. Just press ENTER or press the POWER BUTTON to bring it back to life without losing your computer work.
Oct 29, 2009 | HP f2105 21" LCD Monitor
Like when i turn it on it stays on for 1 min and then the screen turns off. but the light is on
Is your computer turned on? If it is not providing any "signal" through the data-cable to the monitor, the monitor will eventually go into "power-saving" mode.
Have you tried connecting the monitor to a laptop computer?
If it works, then the monitor is OK, and your desktop computer is the problem.
Have you tried a different monitor with your computer?
Oct 27, 2009 | Samsung SyncMaster 920NW Monitor
Monitor is black. How do I fix it?
if the monitor led indicator is amber and and the hard drive (usually red) indicator on computer is blinking red. that means your computer is working but onboard video is dead. if under warranty, bring it back for replacement or repair.
Sep 23, 2009 | E-Machines eMachines Monitor E15T4
Emachine Monitor comes on a few minutes and cuts back off
I have the same problem and I think its the circuit board on the power on button and blue led. I unplug the board when the monitor is on and then the monitor stays on and works OK.
It don't make any sence it is only 3 parts switch led connector
anybody else run into the problem
Mar 29, 2009 | E-Machines eMachines Monitor E15T4
Color dis-order and then flickering display
Try uninstalling and reinstalling the monitor drivers if any are applicable, run a direct X test on your hardware make sure your video card is OK. Try doing a wiggle test on the VGA cable that is plug ed into the back of your computer, that sends the signal to the monitor. Work your way from one end of the cable to the other, look at the monitor screen and see if there is any change in the color , if that don't do it its possible there could be a lose connection between the circuit board and the picture screen inside the monitor, unless your mechanically inclined and know some basics of electronics its recommended you don't do this and get some one who is qualified to do so, but if you are mechanically inclined and do know basics of electronics and if your feeling confident remove the power cord from the wall outlet, remove the power cord from the back of the monitor, shut down your computer and unplug it from the wall outlet, remove the VGA cable from your computer, examine where all the screws are that hold the housing from the monitor together put a white sheet on your bed and carefully and slowly split the housing which are the front and back of your monitor, in the center of the white sheet so if any screws fall out you'll see them on the sheet, when you pull the two halves apart, if it doesn't come apart don't force it study its body and check for more screws when you get them apart , before you touch anything inside the monitor touch a metal object some where in the room that has no electric or electronics on or with in it, to release any static electricity from you body once you do so and open the monitor check all connectors for looseness or any corrosion don't touch anything else but the connectors. if all is well and the problem still exist bring it to a repair shop or bye a new one go to EBay or try www.MicroCenter.com those are your cheapest places, unless money is no object.
Oct 25, 2008 | AOC CT720G 17" CRT Monitor
Power button stay on for 2 seconds, black screen,no picture
hi there, yes, you do have a broken monitor, bring it to qualified service personel how can repair the monitor. or you can just simply replace it. TY
Nov 29, 2007 | HP vs15 15"LCD Flat Panel Monitor
When I select sleep or hibernate mode - the monitor stays black...
Hit the keyboard keys. It is better to just turn sleep and hibernate off and just use a screen saver or tun it off.
Aug 24, 2007 | ViewSonic VX910 19" LCD Monitor
Sony SDM-HS74P/S 17 Monitor won't stay on the right picture.
This is a duplicate post, click the following link to read the active posting: http://www.fixya.com/support/t138012-sony_sdm_hs74p_s_17_monitor_stay_right
Mar 16, 2007 | Sony SDM-HS74P/S 17" LCD Monitor
My monitor says "input ......" and then the screen flashes off.
Samsung Syncmaster 730B 17" Flat Panel LCD Monitor Logo
79 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
