Question about Blanco Classic Single Handle Faucet with Pull-Out Spray ....
Pull out sprayer attachment of a Blanco faucet (PURUS II) is not working. I don't have the PDF manual to look at the installation instructions so any advice would be greatly appreciated.
  • goonerpaul Jun 01, 2010
    thanks so much i think that between the two suggestions here i'll be able to fix it cheers,
    paul.
  • 8,197 Answers
Here is the Purus II faucet in PDF.
http://www.blancoamerica.com/SPECIFICATIONS/157094.pdf
Good Luck
Posted on May 26, 2010
  • 1 more comment
  • goonerpaul May 27, 2010
    Thanks for looking this up. i found this one too, but these are just the specs and not the instructions. i wish companies wouldn't make it so difficult to find their instructions.
    i noticed that the aussie version of blanco's website had a number of instruction manuals, but none for faucets.
    i'm not sure where to go next.
    Cheers,
    paul.
  • Jyackle5
    Jyackle5 May 31, 2010
    If you unscrew the sprayer from the hose do you get water coming out of the hose. If you do that means that you need a new sprayer. If not then you need to trace the hose back to the faucet to see if you get water coming out before the hose is attached.
  • Jyackle5
    Or contact Blanco on link below to see what they say you should look at.
    http://www.blanco-australia.com/ContactU...
  • 10,319 Answers
Information can be retrieved fro this website below
http://www.blanco-australia.com/content.aspx?PageID=95&CategoryID=164
Posted on Jun 01, 2010
  • frank thomas wilson
    frank thomas wilson Jun 01, 2010
    Thank you Paul & good luck
    Please also provide a rating as well using the thumbs up logo if you will -please
    Frank
Leaking blanco single handle faucet with sprayer
minarl deposit bildup in the handol best to just replace the sprayer any hardwer store hose is still good only sprayer head needs replaced comen threds
Mar 11, 2012 | Blanco Plumbing
I have a single handle blanco classic that is leaking around the base I have removed the handle and cartridge but cant figure out how to remove the sprayer to replace the seal
You need to turn the water off under the sink. Disconnect the sprayer hose from the threaded shank under the center of the faucet body. Pull the spray head out of the faucet. Contact Blanco to receive your faucet parts free.
Nov 06, 2010 | Blanco Classic Single Handle Faucet with...
I just installed a blanco faucet with sprayer. Turned water back and then tried faucet but no water comes out. Help
Turn water back off loosen supply lines from faucet turn water back on slowly with supply lines draining into bucket so as to flush them out.If water flowed ok reattach lines to faucet turn both angle stops on full and turn faucet on pivoting handle in all directions.If it still doesn't work take the sprayer line loose from the spout try turning the faucet on again with the line in a bucket. By now you have narrowed it down and the problem should be obvious.Also make sure a shipping plug was not left in line. Hope this helps
Jun 24, 2010 | Blanco Classic Single Handle Faucet with...
I have never done it before, so I need step by step directions in removing an old blanco single handle faucet and now putting in the new one
Turn your water supply off to the existing faucet.
With a crescent wrench and plyers remove the supply tubes from the shut off valves.
Unthread the sprayer hose that is attached to the brass connector under neath your faucet in the cabinet.
Unthread the lock nut and fastening plate which is on the same brass fitting as your spray hose.
Remove faucet from the sink.
Reinstall the new faucet in the reverse order.
Feb 25, 2010 | Blanco Classic Single Handle Faucet with...
The water pressure drops rapidly when the faucet is turned on. The pressure in the hose is constant, but when the sprayer is attached to the hose the pressure drops.
Seems like you have some debris in the sprayer. Remove the aerator and see if there is any there or take it outside and force water into the aerator and hopefully it blows out through the inlet.
Jan 29, 2010 | Blanco Classic Single Handle Faucet with...
Low water pressure/slow flow Blanco Elan faucet 2.2 gpm
pull the sprayer out, get some plyers or a wrench and losen up the connection. between the hose and the sprayer there is usually a screen take it out and walla it should take care of you, it also helps to leave the sprayer in some lime away or vinegar for a few hrs to get the hard water losened up in it
Jun 27, 2009 | Blanco ELAN II 1 Handle Pull-out Spray...
Leaky Blanco Single Lever Kitchen Faucet with separate sprayer
You only need one small o-ring. If you put two of them it will not work properly and will mostlikely leak like crazy. If this helped please rate.
Feb 12, 2009 | Blanco Classic Single Handle Faucet with...
Blanco purus II poor water pressure
If the pressure is the same for both hot and cold. Then most of the time it could be just a blocked Screen/Aerator. Unscrew it and see if the pressure has improved. If so the replace it! Lowe's or Home Depot have them.
Jan 30, 2009 | Blanco Plumbing
Blanco Classic Single Handle Faucet with Pull-Out Spray .... Logo
122 people viewed this question
Top Blanco Plumbing Experts
Mack Baxter
Andrew Bugbee
Are you a Blanco Plumbing Expert? Answer questions, earn points and help others
