Question about Scotts Company Scotts& Accugreeen 3000 Drop Spreader 3 Pack
I pruchased a used Bezzecchi spreader that attaches to the PTO on my tractor. There was no information with it. I have searched high and low on the internet for information. I need to know where to set the settings for grass seed, lawn fertilizer, etc. Any help will be appreciated very much.
SOURCE: I have a Scott Rotary Fertilizer Spreader. When I
If the wheels turn( that is you can push the spreader easily) but the vertical shaft that spins the broadcasting plate doesn't, seems like the gears connecting the axle to that vertical shaft are worn; but if the wheels just slide along the gropund without turning then it would seem something right under the bin is keeping the verical shaft from turning. But I'm NOT an expert; I'm looking for an answer myself,
Posted on Mar 16, 2009
SOURCE: Model 300 runs out of fertilizer
Since I didn't have a manul, I downloaded one from Scott's and used that to calibrate the spreader which was out of calibration.
Posted on Apr 09, 2009
  • 125 Answers
SOURCE: need to apply lawn fertilizer at a rate of 5 lbs,
http://www.gardentech.com/spreadersettings.asp
this is a link which will help you. Your setting should be on 7-8 using a criss-cross distribution pattern
Posted on Sep 07, 2009
Testimonial: "thanks pal, worked great"
SOURCE: repair parts for a Republic EZ Broadcast Fertilizer Spreader
I have a problem with a broken handle it looks like there is no parts for the EZ Broadcast Spreader. The sad part is the rest of the unit is in great condition.
Looks like plan obsolescent!
Posted on Dec 16, 2009
  • 8 Answers
SOURCE: As the cyclone brand spreader is
CYCLONE ROTARY
2.0
EARTHWAY ROTARY
6.0
EV-N-SPREAD
6.0
K-GRO ROTARY
.75
ORTHO ROTARY
.75
PRECISION ROTARY SB50
1.50
RED DEVIL ROTARY
1.50
REPUBLIC EZ ROATRY
.75
SCOTTS SPEEDYGREEN 1000,2000,3000
2.12
SCOTTS BASIC BROADCAST
2.12
SCOTTS EDGEGUARD BROADCAST
2.12
SEARS ROTARY
.75
TRUE TEMPER ROTARY
1.5
VIGORO ROTARY
1.50
SCOTTS STANDARD ROTARY
2.12
CRAFTSMAN
6.0
SCOTT’S EASY GREEN
25
SCOTT’S HANDYGREEN
__________________________________________
Drop Spreaders:
K-GRO DROP
2.25
ORTHO DROP
2.25
REPUBLIC EZ DROP
2.25
SCOTTS ACCUGREEN 1000
3.0
SCOTTS ACCUGREEN 2000
3.0
SCOTTS ACCUGREEN 3000
3.0
SCOTTS DROP PF1, PF2, PF3, PF4
3.0
SEARS DROP 2.25
Posted on May 01, 2010
PTO led on the dash lights up when i try to start the tractor. I replaced the PTO switch, but no luck. Its like the starter loop thinks the PTO is ON, but the switch is definitely OFF.
Sounds like something like the key switch is searching for a ground.Use a piece of wire hooking one end to the negative of the battery and touch the metal case of the key switch with the other end , turn the key and see if the pto light still comes on , Feedback from a bad ground can drive you crazy.
Jul 04, 2016 | Garden
PTO wont engage unless battery is charged up
Dale, it is normal for the PTO not to engage when voltage is low. Have battery and charging system diagnosed and repaired.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Charging System Battery Alternator Test Briggs FAQ
CHARGING SYSTEM MAINTENANCE
LAWN MOWER TRACTOR ZTR HOW TO TEST SMALL ENGINE VOLTAGE REGULATOR...
May 25, 2016 | Cub Cadet Garden
PTO inoperative.
What's the make & model of your tractor? If this is a garden tractor, it sounds like either the belt on your (I assume) electric clutch is slipping or you have low power to the magnets. If this is a farm tractor, then your pto clutch plate is worn and/or needs replacement/adjustment.
Apr 10, 2016 | Garden
Pto won't disengage, unable to start tractor. pto attached to post hole digger in ground
It could be gear bound and not allowing it to disengage, i experienced that a few times in my farming days, we dug a lot of postholes with a PTO driven digger. What usually happened is i ended up getting caught on rocks and stalled out because i had the engine speed to low. What i generally had to do to fix it was remove the PTO shaft from the digger, disconnect from the tractors output shaft, then get it started and everything moving, then disengage the PTO and reconnect the post hole digger, then give her hell and get the engine speed up before re-engaging the PTO, that would generally shock it loose. If not then i would have to disconnect the PTO shaft again and spin it backwards by hand to rotate the digger in the opposite direction to remove the hangup.
Nov 25, 2015 | John Deere 670 770 870 970 1070 Compact...
John Deere 285 lawn tractor pto works but the wire keeps melting?
U need to inspect wiring for wear thuroly. Some is internal from age causing resistenc. Obtain a shopbook or somethin similar in library or online
Oct 08, 2015 | John Deere Tractor Starter 285 345 2243...
My old massey Harris tractor doesn't blow snow very well PTO to slow and rev to fast when I have at full throtle I don't think there is much I can do other than using a different tractor any thots
There are speed increasing gear boxes available for PTOs.
Bare Co USA Hydraulic Pump Motor Adaptors Spindles
Do a Google search for
pto speed increaser
You will get lots of interesting solutions to compare to what you can make work. Then try ebay but you may have to get creative with your search parameters.
PRAIRIE 1035 PTO GEAR REDUCTION INCREASER 1 1 15 SPLINE
Feb 08, 2015 | Garden
Clutch for johndeere 870
That is normal for a live pto. If your tractor has a two stage clutch you should be able to stop the PTO with clutch all the way in (as in push the pedal all the way down). It should be transmission independant, meaning it will work even though the transmission is not turning AND if you are running something that has a lot of inertia, it won't push you around by driving the rear wheels even though you have the clutch in.
Aug 25, 2012 | John Deere 760 790 850 870 Flail Spreader...
What attachments can I use for a manual pto lawn tractor?
it would depend on the model/size of the machine i have seen that the snow blower attachments don't work very well on any rider i don't think sears had a tiller for anything modern and what you would pay for most any attachment you can get a stand alone version cheaper if you want a work tractor get a wheel horse a old cub or deere tractor not a riding mower that is to weak to handle the work out
May 21, 2012 | Craftsman Garden
NO power to pto craftsman gt 5000
could be a clutch switch look at sears parts online for the location
Apr 01, 2012 | Garden
Scotts Company Scotts& Accugreeen 3000 Drop Spreader  3 Pack Logo
374 people viewed this question
Top Scotts Company Garden Experts
john h
Nick Olsen
jhnolson
Are you a Scotts Company Garden Expert? Answer questions, earn points and help others
