Question about LG LP1200DXR Portable Air Conditioner
Air conditioner will run for about 3 hours then stops because its full - it seems to fill constantly fast??
  • 767 Answers
Hello my name is Heath it will be my pleasure to assist you. This is normal depending on the amount of humididty in the air the faster it will fill. What you could do is run an external drain line to drain the water while its filling so you don't have to keep dumping the fill pan.
Posted on May 26, 2010
My Sharp CV10NH, turns off and water full about every 30min...is there a solution to this problem?
If you are operating in a humid environment and are running in Dehumidifier mode, you might be filling your tank very quickly. Run it in Cool mode and you might last longer than 30 mins. Also, if you can isolate the room you are cooling from other parts of the house, that will help.
Aug 04, 2012 | Sharp CV10NH Air Conditioner
Red light blinking
Sorry, it is working well! Part of an air conditioner's job is to remove excess humidity from the air. This is what is filling up the bucket.
Jul 19, 2010 | Amcor 14000 Portable Air Conditioner
It keeps freezing up if you put it past #5
Hi and welcome to FixYa. I am Kelly. Freeze ups are caused by a couple things.
1. The first thing is a dirty evaporator coil. Air conditioners that run 24 hours a day should be thoroughly cleaned every 90 days.
2. The Blower fan wheel is dirty
3. The fan motor is not running fast enough.
Most of the time these 3 items listed above are the main reasons and Air Conditioner Freezes up.
Thanks for using FixYa,
Kelly
May 10, 2010 | Friedrich Casement SC06H10D Air...
Drainage
The amount of condensate it is producing is dependant on how humid the air is it is cooling. The more humid it is the more condensate you have.
May 02, 2010 | Sharp CV-P09FX Air Conditioner
How can I determine if the ac is removing the correct amount of moisture from the air?
tech answer is:3 pints of water per hour per 1 ton of cooling.
General rule of thumb is 20-25% of the capacity of the unit is devoted to dehumidifying.
If unit runs constantly and the temp really does not seem to be effected, unit is probably too small. If unit runs and cycles off frequently, i.e. short run times, and humidity is high, unit is too big.
Hope this helps
Jun 25, 2009 | Heating & Cooling
PAC L90 water tank capacity
when tank is full you will get the letters FE will signal a FULL TANK
(The tank is full)
You have it setup to constantly drain GOOD.
Should you should not plug the drain hoses to get colder air.
Do let it drain . It is more convenient!
If the unit is the proper BTU for the square footage of the area to be cooled it will be cold!
If the tank gets full you will not get cool air?
Please remember to leave a rating before you go!
Thank you
Jul 28, 2008 | DeLonghi Pinguino PACL90 Portable Air...
Full Tank very fast
witch model do you have, for some models thats normal on others its not, some run the water over hot coils and it evaporates others the water goes into a holding tank and sits their til the tank fills up then you must empty. expect more water when high humidity or in the summer
Jun 27, 2008 | DeLonghi Pinguino PACL90 Portable Air...
Maytag portable air conditioner runs for 2-3 seconds then stops and shows code "E1" on the display
empty water & clean filter.. full water drain (which takes a few weeks to fill) will shut off the unit
Jun 08, 2008 | Maytag Heating & Cooling
Water pump constantly running on Carrier gas furnace
Yes I agree with Master_tech Be sure the shipping retainer was removed if its a new unit, if its an old unit clean it and put an algae tablet in it.
Mar 04, 2008 | Carrier 38CKC036 Air Conditioner
LG LP1200DXR Portable Air Conditioner Logo
2,445 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
