External USB driven hard disc not recognized Windows XP-
  • The external disc is a ST340015A standard USB driven disc.40GB
    It used to work fine earlier.Recent days it shows of as a local disc and is inaccessible.
    I don't wish to reformat as it will erase all data
    Scholar:
  • 102 Answers
Once the device has installed all drivers open "My Computer" and see if it even shows the drive. If the hard drive came with any installation software install it before attaching the drive. Make sure all cables are attached including the power cable if it came with one. One main thing to also check is that the drive is directly in a port by itself and not on a hub with other items. The only other problem may be that is the drive is too large (1TB) to be recognized and then you can google a patch that will allow it to be recognized. If none of this works the last option would be to allow your pc to format the drive and see if that helps.
Posted on May 26, 2010
  • Daniel Hebert May 29, 2010
    Looking up the model number you have a Seagate Barracuda 5400.1 which shows as a internal IDE drive. One other way is to install it as a internal drive as a slave drive. Talking to another friend he had a similar issue and removed the hard drive from the case because of the controller board going out. Installed it into a tower as a internal and it is still working to this day. If this is a option this would be a way to copy the information to a jump drive or a new external drive.
My computer will not recognize the drive. Does it have to be connect to a power supply? I have it connected to a usb port
Windows 7 does not recognize SimpleTech 250GB external USB drive ...
answers.microsoft.com/...does-not-recognize-simpletech-250gb/f7ceccd0...
Just bought a new computer, running Win 7. Drive worked fine on Win XP. ... Windows 7 does not recognize SimpleTech 250GB external USB drive ... I find it hard to believe that a external USB 2.0 drive can't work with Win 7. There must be ...
SimpleTech dvi hdmi pc Hard Drives Questions & Answers ...
www.fixya.com > Forum > Tags > dvi hdmi pc > Hard Drives
Question about SimpleDrive 160 GB External USB 2.0 Hard Drive ... Question about250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive ... my PC does not recognize the external drive 96300-40001-001 Driver Problem: Check whether ..
Dec 18, 2015 | SimpleTech SimpleDrive 250 GB External USB...
Not recognice by usb hard
A USB hard drive is a portable external storage device that works just like a conventional hard drive.
The device is simply plugged into a USB port on your computer as you would connect a flash drive.
Unlike a flash drive, however, a USB hard drive can store a much larger amount of data.
If your computer will not recognize your USB hard drive, you can try troubleshooting steps to resolve the problem.
Plug one end of the USB cable into the port on your hard drive and plug the other end into the USB port of your computer. Ensure that both ends of the cable are connected securely.
Open "My Computer" (Windows XP) or "Computer" (Windows Vista/7).
The USB device should be listed as "removable disk" once it is plugged into the computer.
If it is not listed among the available drives on your computer, proceed to the next step.
Ensure that the data cable is working properly.
Try another USB cable if you have one available.
Disconnect all other USB devices from the computer as they may interfere with the operating system detecting the external hard drive.
Reboot the computer if the USB hard drive is still not recognized.
Plug the USB cable into another USB port and check to see if the device is detected.
If you are using a USB hub, remove the device and plug the external hard drive directly into a USB port.
If the computer still fails to recognize the device, the external hard drive itself may be experiencing a hardware problem.
Check the status of the hard drive in the "Device Manager" window. Under Windows XP, right click "My Computer" and select "Device Manager."
For Windows Vista and Windows 7, click the "Windows" button in the lower left corner of the screen, then type "Computer Management" in the search bar and press "Enter."
Select "Device Manager" in the "Computer Management" window. In the Device Manager window, click the "+" sign that appears beside "Disk Drives."
If the external drive is not listed, click "Other Devices" in the Device Manager window and see if an "Unknown Device" appears.
The external hard drive may have been detected but the device is not working properly.
If it is still under warranty, take the device to the computer store where it was purchased to have it repaired or replaced.
Hope this helps
Nov 07, 2012 | Computers & Internet
My windows XP OS won't recognize my SimpleTech SimpleDrive Pininfarina 300GB External USB 2.0 Hard Drive
I found that often, external hard drives just don't have any active partitions and thus don't show up in Windows. Go into the control panel, administrative tools, computer management and then the disk manager and see if it has a partition. If it's just unallocated space, right click and make one.
Jan 16, 2012 | SimpleTech Simpledrive Computers &...
Hp 250 GB Pocket Media drive having erratic behaviour under Windows 7 (Motherboard ECS G41chipset), Under windows XP front and back USB ports recognize disk as USB 2.0 device - able to read and...
XP is a dead OS.
100% dead. and not supported now. by MS or HP.
but XP needs SP3, or USB will be bad
XP always had bad USB for years until , all patches were done.
The USB on XP are horrible.
you need good USB so all devices are PnP recognized
and negotiated currents (power) is working
and USB2 currents are weaker than USB 3.
and is key to making any motor driven HDD work right.!!
Dead as a door nail and no more security patches ever again.445635a4-18b0-42a5-a249-084bb91c84b0.jpg
Apr 04, 2017 | HP 250GB Pocket Media Drive 250 GB Hard...
I've got a 2 TB WD Elements external hard drive, and suddenly, no computer wants to recognize it when I plug it in. It is just rejected by any pc i've tried (3 laptops so far...) and I've a...
Is the PC you've used before is the operating system is windows Xp? If you've using windows Xp before then you've plug it in a windows 7 Operating system, it means your hard disc have no problem the operating system of your PC is different than before. Try to plug it in a windows Xp operating system then recover it in there then format it in a windows 7 operating system then, the windows Xp and windows 7 try to make a network place in the connection then share the hard disc files that you've recovered then copy and paste it in the newly format hard drive that formated in a windows 7 operating system.
Jul 21, 2011 | Western Digital Elements 2 TB USB 2.0...
REQUIRE WINDOWS 7 DRIVER FOR IOMEGA SILVER SERIES 250GB EXTERNAL HARD DISC DRIVE. THANK YOU
The external hard-drive is "plug-and-play", and Windows XP/Vista/7 all support "plug-and-play".
Thus, it should automatically be detected by Windows.
So, what's your "real" problem? Symptoms? Error-messages? What happens? What does not happen?
Nov 05, 2010 | Iomega Silver Series External 250GB...
External Hard disc isnot recognized by PC
Dear Sir,
Here is the Procedure for Connecting External Drives to Computer.Several brands of computer does not recognise external drives when connected to USB expansion slots,and Slots of front panel,So connect your Ext HDD to back side onboard Slots.Because there is a lack off USB power surge voltage to detect a large capacity exteral drives.Some time it is does not recognise by many computers,when USB power surge voltage is low.
I think it helps,
If you find any difficulty post a feed back we were happy to assist you
have a nice day.
Good luck
Sep 17, 2009 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
My external hard drive does not work on windows xp
You might need to initalize it in XP and then assign a drive letter.
Aug 29, 2009 | Iomega 250GB Ego HD USB 2.0/FW Red 250 GB...
Need driver
Hello maris12345
You shouldn't need drivers for your USB mass storage device on Windows XP. It should be "plug-n-play".
Is yours an older computer? If the computer's USB interface (hardware) is not at least USB ver 1.1 then that may be the problem. (I assume your external hard drive isn't being detected, yes?)
Can you run other USB devices on the same port(s) OK?
BJ
Apr 03, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
USB Problem
hmmm external hard drive should work without any problem as windows xp allready have inbuilt drivers for mass-storage.
try to Uninstall the USB driver, goto Device manager and Uninstall USB, then reboot to clean system registry and install USB driver from Windows XP setup disck. and try the external-hard drive, xp should recognize your external-hard drive. If not then install driver for your drive if you have and try. for camera and ipos u need to install drivers and supporting softwares from your manufacturers.
thanks
Iqbal
Mar 31, 2008 | HP Compaq Presario R4000 Notebook
Computers & Internet Logo
48 people viewed this question
David Payne
David Payne
