I have a F&P smart drive excellence 6.5 model GW609AU. when cycle grts to rinse or spin the power cuts off if i turn machine off at wall for a couple of mins and turn back on starts up where it last shut off from then shuts down again
  • fonc May 26, 2010
    thx when i have time will try remedies, thx again
  • 12,061 Answers
Manuals.appliancesonline.com.au/mw512/mw512_user_guide.pdf
www.casa.co.nz/.../F&P/SmartDrive-Parts-MW511,MWC11,GW511,512,611-25p.pdf -
http://www.aars.com.au/F&P%20Service%20manual%20517735.pdf
http://www.washerhelp.co.uk/diy-repair-help.html
Hi, I have collected for you your service manual, user manual, a DIY self help repair and troubleshooting website. Use the service manuals, and DIY sites and you should be able to isolate your issue.
Posted on May 26, 2010
Fisher & Paykel IWL 16 shuts off during all cycles.
I says power cut restarting in 10 seconds
I'm sorry, it is the board, the switch mode power supply is dying.
Every time it starts to do something it power cuts.
Best to get a new motor controller board,
Quote the 6 digit part number under the bar code to get the right part.
Mar 25, 2013 | Fisher Paykel Eco IWL16
Fisher and Paykel 7.5 washing machine keeps powering off during rinse and spin cycles
The pump has a thermal safety cut out on it.
If the pump gets too hot it cut out.
Just put a new pump in and your all going again.
Aug 05, 2012 | Fisher and Paykel Washing Machines
Our Fisher and Paykel excellence 5.5 smart drive 9, washes fine but when it comes on rinse cycle it wont drain the water and makes a humming sound.
Check your pump with a multimeter for correct reading
230V AC Pump 50Hz 33Ohms +/- 8% @ 20oC
110V AC Pump 60Hz 7Ohms +/- 8% @ 20oC
Also check for blockages that may stop pump from turning.
Disconnect from power & Bail out all the water you can before removing pump.
Jul 07, 2012 | Fisher and Paykel Washing Machines
My fisher & paykel 7.5 kg excellence smart drive doesn't spin
Check the out of balance switch (under the larger Grey board)
for corrosion on the terminals and replace if faulty.
Jul 03, 2012 | Fisher and Paykel Washing Machines
F & P excellence 6.5 smart drive - Model GW608U - the machine will not fully progress throught the "Rinse" cycle. It will empty the wash water and spin & spray a little, then power...
Hi - this sounds more likely to be a faulty motor control module, its overheating and a electronic component is failing. Only way is to fit a new control module to eliminate the possibilty, another probable cause may well be the RPS sensor failing as it goes into spin mode.
Really need to do a few tests with a multi-meter, see if the motor/stator windings are ok, a faulty RPS at times will give a similar head ache..
May 05, 2011 | Fisher and Paykel Fisher & Paykel Washer
I have the fisher & paykal excellence 6-5 smart drive model gw609au when i first turn it on the seconds green light is flashing and it is trying to fill up but starts and stops all the time then just...
Hi Damian just read your posting.Your fault on your machine is the out of balance switch is faulty.Do you still require help?Please reply and I can guide you throe the repair of this problem.
Jul 02, 2010 | Fisher and Paykel Fisher & Paykel Washer
Hey, my f&p smart drive 9 excellence washing machine does not start wash cycle after entering water level etc.... upon pressing the start button nothing is happening any thoughts?
Is the bowl turning slowly when you press start.if it does then you may have a faulty inlet valve,make sure taps are turned on.try advancing the machine to spin cycle,see if it will do any other things such as spin & drain.if it does then probably just not letting in water & inlet valve needs replacing..try filling machine by hand & see if it washes.
May 24, 2010 | Fisher and Paykel (IWL12)
Fisher & Paykel Smart Drive 7.5 washing machine.
Unplug the machine have someone tilt the machine back and look under the machine for a little fan on a motor give it a turn to see if it spins it might just be sticky or it may need replacing.
Jan 07, 2010 | Fisher Paykel Eco IWL16
Fisher & Pykel Smart Drive 9
Spin the fan on water pump (you can acess with difficulty from bottom of washer) if it has a little sand in it, it may clear. It is possible to remove water pump if mechanically minded and see if something small eg staple or 5c coin is stuck in it if this dosn't work or you may find you need to replace water pump.
Aug 19, 2008 | Fisher and Paykel Fisher & Paykel Washer
Washing Machines Logo
97 people viewed this question
Top Washing Machines Experts
