Question about Belling XOU592 / XOU593 Electric Double Oven
Main oven works on full power whatever you set it
Xou 592 main oven works on full power whatever you set it to
  • 327 Answers
Hello,you need to replace thermostat
Thanks
Posted on May 26, 2010
Testimonial: "thank you for the information, very helpful. "
  • John Lovell May 06, 2012
    Hi, do you know of any sites where I would be able to find the instructions to change the thermostat?
    Thanks
Electric fan oven
Sounds like the oven thermostat stuck, for whatever reason and then the oven overheat thermostat kicked in. At the very least, I think you will need a new oven thermostat and possibly an overheat one as well. On the 720 there are two, one for each oven, so when you take the oven to bits, check both out.
Dec 17, 2011 | Stoves Ovens
Tecnick tck 8522/2 oven
power to the main oven has to go through the oven clock if time is not set main oven will not work also if clock set on auto time rather than manual oven will not work conversley if clock is faulty it will not work top oven is unaffected as oven clock auto timer cannot be used on top oven.try resetting power of and on again reset time on clock if clock not faulty oven will now work.
Jun 05, 2010 | Tecnik TKC8522 Electric Double Oven
Oven not heating up [fan works] the oven is a belling xou 163 the grill works but the oven does not warm up
It wilbe a faulty oven element, you will need ti fit a new one.
It is located at the rear of the oven, behind a removeable cover.
Please rate my solution.
Thankyou.
Feb 11, 2010 | Belling XOU252 Electric Single Oven
No Power to Belling 163 model
check the safty cut out, if there is one
May 16, 2009 | Belling XOU252 Electric Single Oven
No gas to lower oven - Cannon Camberley
Hey Stephen - try setting the clock then set the cook period. the oven will only work when that's on i think.
May 07, 2009 | Ovens
Fan making loud noise
Hi
does the noise start as soon as you turn the fan oven on?
does the noise stop as you turn off?
just depending what make and model you have there is two fans
in it 1 is the fan motor inside oven at back and other
is the cooling fan which is at top of oven .you just need
to find out which one it is and just replace . then should be back to normal
regards dan
Mar 19, 2009 | Belling XOU174 Electric Single Oven
Belling XOU 252 Oven suddenly stopped working
Yes ,I would say that without doubt the element has gone
Elements can go without any warning at all.
Dec 13, 2008 | Belling XOU252 Electric Single Oven
Belling oven xou 179
Hi
you need to remove back panel in oven. from there you will see the element somtimes you can unscrew them from inside if not you will have to remove oven from housing . remove back panel and the element will be bolt from behind just remove these the refitt new element in reverse order. hope this helps you
regards dan
May 19, 2008 | Belling XOU174 Electric Single Oven
Wiring Diagram for AEG Build-in Electric Oven B2.6L
can i use 13amp socket for a electric oven
Nov 04, 2007 | Ovens
Broken cooking appliance :( please help
if the fan is spinning then it sounds as though the element has gone. has your fuse box recently tripped? it may have been the blowing element.
Jun 10, 2007 | Belling XOU252 Electric Single Oven
Belling XOU592 / XOU593 Electric Double Oven Logo
305 people viewed this question
Top Belling Ovens Experts
ashburton
Lawrence Oravetz
Are you a Belling Oven Expert? Answer questions, earn points and help others
