Question about Daewoo DWC-072C Air Conditioner
How to take front cover off to check for dust build up
  • 767 Answers
Hello my name is Heath it will be my pleasure to assist you. If you take the filer out then take the knobs off lift the bottom up slightly and then out it should pop there are clips that hold the cover onto the air conditioner.
Posted on May 26, 2010
It keeps ticking then shuts off and on
Check the user guide for advice and begin by clearing the vents of any dust build up. You may have to remove and clean felt pads designed to catch the dust.
It sounds as though the unit is overheating and it switches off to protect the system.
Jan 06, 2015 | Televison & Video
How to replace front wheel bearing on 2003 kia sedona
Disassembly 1. Remove oil seal from front wheel hub. 2. Remove front wheel hub assembly with suitable tool.
bi6c021a.gif 3. Remove retaining ring. note_icon_eng.gif If the bearing inner race remains on wheel hub, grind a section of inner race until approximately 0.020 in (0.5 mm) remains. Remove race with a chisel.
bi6c021b.gif 4. Remove wheel bearing with suitable tool.
bi6c021c.gif note_icon_eng.gif Do not remove dust cover unless necessary. Do not reuse dust cover if removed. 5. Mark relative positions of dust cover and knuckle for proper reassembly. 6. Remove dust cover with a chisel.
ai2a023c.gif note_icon_eng.gif Do not remove wheel hub bolt unless necessary. Do not reuse wheel hub bolt if removed. 7. Remove wheel hub bolt with a press.
bi6c021d.gif Assembly 1. Press in new wheel studs. note_icon_eng.gif Front wheel hub press in either bolt turning or loosening by the torque of 108.5 lb•ft (147 N•m, 15 kg•m) shall not be premissible.
bi6c022a.gif 2. Mark new dust cover to match the removed dust cover. 3. Align mark on new dust cover with knuckle. 4. Install new dust cover with suitable tool.
bi6c022b.gif 5. Install new wheel bearing with suitable tool. 6. Install front wheel hub assembly with suitable tool.
bi6c022c.gif note_icon_eng.gif Use a new oil seal, and apply grease to seal. Install oil seal so that it is flush with knuckle. 7. Install new oil seal with SST(0K993 331 016).
Jan 12, 2013 | 2003 Kia Sedona
Showing error code 0046
Fusing motor cooling fan is in op due to dust build up, motor gone bad, or the main control board has gone, to reset open close front door, if it still come back (code) Then remove the back cover after unplugging and clean all filters and fans if one is dirty they all might need dust removal. remove each fan clean with can air make sure they turn properly.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
May 26, 2012 | Minolta EP4000/5000 CS/PRO Copier
I drive a bmw 320i. There's lots of black stuff in the front magwheels, looks like dried up oil and grime. There's also some oil and grime at wheel housing. What seems to be the problem?
Sounds like it is just brake dust build up. The front brakes take most of the brunt when you stop so they wear down faster and emit more brake dust. I would check for any brake leaks though just to be safe.
Jan 30, 2011 | BMW 323 Cars & Trucks
My fans on my computer are not running right what do i do?
Check its plug to the mother board and confirm it is well plugged. Then switch the terminals to see if runs right.
Oct 21, 2010 | Computers & Internet
Wall unit leaking water new installationseems to be drain line problem.
I had this problem once. I took the front cover off the wall unit and located the the drainage hose and found a build up of dust which was blocking the outlet.
Jun 17, 2010 | Fujitsu 18C1 Air Conditioner
The dust cover on my front rotor is bent really bad. Can I remove it or does it have to stay on the truck to operate?
the dust cover is exactly that it prevents brake dust from getting onto other components, unless something like a sensor is attached to the cover, or it is rubbing against your rotor or other components then there is no need to remove it. but you will see a noted increase of brake dust build up in your wheels, and since they are semi-metallic pads you could see small rust spots.
Mar 15, 2010 | 2004 Dodge Ram 1500
"spillage at draft diverter on wall heater. Should have vent checked" See heater (HVAC) Written by PG&E
Around hear, squirells drops nuts and pecan down the vents also walnuts and birds builds nests with leaves and straw. please have this checked!
Dec 20, 2009 | Heating & Cooling
IN MY JUST PURCHASED UNIT I HAVE ENCOUNTERED WHAT APPEARS TO BE DUST OR PARTICLE SPECKS IN THE VIEWING SURFACE WHICH ARE MOT RELATED TO THE NEGATIVES OR SKIDES. I HAVE SCANNED APPROXIMATELU 900 SLIDES AND...
Most of these devices have photoelectric sensors build-in, which tells the unit whether there is too much paper dust on the sensors, When there is too much paper dust covering the sensor, the device will report to the User that there is too much paper dust on the sensor, and the device will not function properly, due to the build up of paper dust.
Get a can of compressed air and gently spray inside the device, to remove the build up of paper dust,
-a.
Dec 06, 2009 | Pacific Image Electronics Memor-ease...
Shutter closed
Any small distortion to the case will jam the dust shutter mechanism, as will dislodged dust and dirt. Remove the battery and carefuly remove the case screws. DO NOT LOSE. Lift off the front cover, take care with the top control knob and on/off switch as there are dust shields that may tear. This reveals the dust cover mechanism on the front of the camera. Dust off with an air-duster or soft spotlessly clean (new) paintbrush. Check a narrow ribbon cable is plugged-in at the front as this powers the cover motor. Gently guide the case around the top rotary control & on-off switch and line-up the circuit board beneath the rotary switch. Do not force anything together. Lightly re-assemble without screws and insert the battery - you cannot make this test without the cover-on as the case supports the switches needed to control the camera. Check that the cover operates correctly or is jamming on the case cover at the front where the shutter moves. If all OK replace the screws, else gently straighten the case with your fingers. This has happened several times to mine and cleaning it/lightly straightening the case cover always make it work again.
Jan 30, 2008 | Fuji MX-1700 Zoom Digital Camera
Daewoo DWC-072C Air Conditioner Logo
179 people viewed this question
Top Daewoo Heating & Cooling Experts
Tim Whalen
armandog07
armandog07
Steve
Are you a Daewoo Heating and Cooling Expert? Answer questions, earn points and help others
