Question about Sony WEGA KDE-61XBR950 61 in. Plasma HDTV
Screen on and off
Hello, the TV turns on fine (picture, sound ok) but after a few minutes the screen goes dark and the sound is gone. In another few minutes both the picture and sound are back. This occurs over and over. Any ideas? Your input would be really appreciated!
    Genius:
  • 3,422 Answers
HI,
I don't think you did any damage. It is probably not hooked up properly.
Go back and check all connections and cables.
You may have caused an internal open connection or cold solder joint to quit. Do a little banging on the set with your hand or fist to vibrate it enough to scare a poor connection back to work!
HERE ARE FEW MORE TROUBLESHOOTING STEPS YOU CAN TRY:
ONE: Check the line cord. Wiggle both ends near the molded part.
TWO:Do a hard reset by unpluging all the cords for 4hrs and then plug it back.
THREE:The whacking test is to just bang or smack the set with your hand on the back, side, top, etc., to see if there are loose connections or cold solder joints inside that are acting up. If so, the banging should knock them back to normal and the set should restore. You might have to use some creative banging and some have had to put a book or magazine under one corner to torque the chassis enough to get it to work reliably.
If the problem still persists then like i said before,you will have to get it repaired by a technician.
Goodluck,
Please don't forget to rate the solution AS FIXYA.
Posted on Apr 07, 2008
  • 813 Answers
Hi friend
i think ur bordcapsitor are damged when capsiter is chage the u can show the pic & sound but when its became discharge ur sound & pic is gone bed so chak ur tv ckt from a good tecnision of tv he will charge to change the capcitor is $20 to $50
& thnx using fixya
  • Sony Master
  • 19,396 Answers
It is likely to be a problem with ysus board or with power unit
18 month old LG 43" LED TV. Screen goes dark, but can be seen if you hold a flashlight up to screen. Sound is fine.
The inverter supplies the voltage to activate the screen. There are usually 2 boards, a slave and a main board. Sounds like one of them is leaking voltage and causing the screen to go dark after the initial start up. Make sure you didn't joggle something loose while you were replacing the power board check all connections. GL
Aug 26, 2016 | LG Televison & Video
Screen goes black on toshiba tv how to fix
I would check to see if any capacitors have gone bad or are going bad.
Oct 07, 2012 | Toshiba 32A60 32" TV
Screen goes dark after few minutes
check your LCD inverter maybe there is loss connection or some parts damage from inverter.
May 05, 2009 | Polaroid TLA-01511C 15 in. LCD Television
TV turned off itself
Can you still turn it on?
If so, does it stay on with sound?
If the sound is ok and the picture is blue (even when changing channels, inputs, etc.) the lamp may have gone out.
Can you see the TV menu when you press the menu button on the remote or TV?
Jan 07, 2009 | Sony KP-51HW40 51" Rear Projection...
LG DU-42PX12X Plasma, picture startes flashing then goes black after a few minutes
You need to get this tv service asap.i beleive that the problem is in the inverter board or yb board.
good luck
caypianan@yahoo.com
Oct 25, 2008 | LG 42PX5D 42 in. Plasma HDTV
Picture flashes for 1/2 second then is gone...sound continues
power supply if led ligth stays blue and then after a few minutes changes to orange is your power supply.if light color goes to a purple that is your mainboard $$$$$$$$$$$
Oct 14, 2008 | Westinghouse SK-32H240S Television
TV screen goes blank but power stays on
Sounds like the CRTs are going into protective blanking due to the vertical output ic needing to be resolderd. Try resoldering the vertical IC that may possibly fix the issue.
Jun 15, 2008 | Mitsubishi WS-73713 73" Rear Projection...
TV Picture Goes Black
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
Jul 28, 2007 | Sony Grand WEGA KDF-60WF655 60" Rear...
Sony WEGA KDE-61XBR950 61 in. Plasma HDTV Logo
80 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
