Question about Ovens
Hi there i have a problem with a blanco hotplate model number EMT600SS the old simmerstat is no longer made but i dont know how to wire in the new type they use can you help with any schematic diagrams of the old type and the new type or do you know how i can wire in the new one for this hotplate model. the simmerstat controller is the second one in from front to back thank you
  • Ovens Master
  • 12,061 Answers
Usually, a simmerstat is just a mutipole switch, that switches in and out the DUAL ELEMENTS elements in this order, ONE element a, time, (LOW) One element is series, with the other, (MED) two element in parallel. (HIGH). One is common.
So we have a Common, and we have a P
L1
L2
H1
H2
It doesn't make any difference how it controls the elements as long as they are switched as related you will be all good. Just use a meter.
Posted on May 26, 2010
I have a Simpson Neptune stove 2U602W which needs new simmerstats.
If the connectors are in the same pattern, you can ignore the numbers and go by the position of the connectors, so top left on the old, would go to top left on the new.
You could ask the maker direct.
http://www.simpson.co.nz/SupportCentre
Sep 13, 2015 | Ovens
I'm after a blanco oven manual for BSO632. The
Blanco Oven
http://www.scribd.com/doc/7992811/Blanco-Oven
Sep 20, 2014 | Ovens
Need illusrated wireing diagram for 18 year old defy gemini petit chef electric stove
Oven:
power comes in, goes to overtemp > timer > function switch > thermostat > element then back to neutral
fan & light come on with function or thermostat switch.
what else do you need to connect?
Oh, hotplates. Power in > infinite switch > hotplate and indicator then back to neutral.
Watch out for two phase with indicator light.
Oct 18, 2013 | Ovens
Need a wiring diagram for ego simmerstat
Where can I find the wiring diagram for simmerstat regulator 48ER101C1P please?
Jul 29, 2012 | Ovens
Hi i have a blanco electric oven model no bms 901 sse and the timer shows A and no time . And the oven does not work can u please help me
I had a similar problem with the same model of Blanco Oven but in my case the clock was completely dead apart from the letter A which was lit (and this proved there was power to the oven).
The oven would not work because the clock module (electronics control unit) was dead.
I rang a Blanco parts supplier, who advised the clock module was no longer available (Blanco advised the same). Another supplier said they could supply the clock module for A$425 which is an absolute ripp off (a reasonable price would be A$50 as it only has a couple of components).
As the clock module is not essential (it only provides the time, alarms, and fancy features most people don't need) I decided to by-pass it by shorting out the two (brown) wires on the LHS (which connect to the relay on the clock module). In effect it behaves as if the relay is always ON, supplying power to the stove.
The oven now gets power and works fine and it cost me virtually nothing to repair. I strongly recommend this solution to anyone experiencing problems with the clock module.
Some basic understanding of electrical/electronics systems is all that is needed to implement this repair.
Aug 10, 2011 | Ovens
I have a Simpson electric oven with stove top elements, and one of the burners will only cook at the highest level, I cant figure out how to change it, any suggestions?
You need to change the "Simmerstat", take the model number to your local electrical parts supplier/parts counter at your local stove retail shop that sells Simpson stoves and ask for one for that model, make sure you get the right one for the position as some control a single element and some control dual elements.
*** TURN OFF THE WALL SWITCH AND ENSURE NO POWER IS APPLIED TO THE STOVE BEFORE PROCEEDING ****
Remove the upper back panel of the stove. Swap wire for wire of the old simmerstat to the new one, remove the knob from the old Simmerstat, undo the nut securing the simmerstat in the oven control panel and discard, fit new one, secure, fit knob, fit back panel, turn on wall switch and test.
Some countrys/states require registered electricians perform this task on electrical appliances so you must ensure you can do this legally before you start and take the relevant safety precautions and don't electrocute yourself.
Apr 13, 2011 | Ovens
I am trying to replace a simmerstat in an old hotpoint cooker and have been supplied with an EGO 50 52076 070 as a universal replacement. The old simmerstat has terminals 'live' 'neutral' and 'load' - how...
I bought some of these simmerstats to refurb an industrial machine and faced the same issues - which terminals do what?
The parts came with a confusing wiring diagram, the terminal numbers didn't match.
The good news is that you can easily get inside this unit to see how it works without damaging it.
Release the metal front plate by gently lifting the tangs with a screwdriver then undrneath is a plastic shield which isn't glued in or anything, it just pulls out.
Here's what I found:
The bi-metal heater is connected between 2 and 4.
The bi-metal switch is between P1 and 2.
There is an auxiliary switch between 4 and P2 (P2 is the same metal strip as PILOT).
The auxiliary switch is closed when the control is 'not off'.
I also noted the short metal stub near 'TOP', in line with 2.
It is in fact the same metal strip as 2 so should be treated with respect i.e. it has mains voltage on it.
For my application, I wired:
Live in to P1
Neutral in to 4
Load powered from 2, returning to Neutral
Pilot Light from P1 to P2 (observe that the pilot wiring is a bit scary because it has a switched neutral).
Dec 22, 2010 | Ovens
Belling oven & grill not heating ,element been testing by electrician and seems to be ok, fan and lights working
hi you dont mention the model but all bellings have a thermal cut out (Limpet stat) the formats have one on the right hand side . remove the side panel to get to it . other models may be at the back, Also can be under the hotplates if freestanding cooker. look for a button sized cylinder 15mm dia 10mm deep with 2 wires connected. or follow a common wire back from the elements( one of them will go there).
Nov 20, 2010 | Belling Ovens
Ovens Logo
56 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
