Question about Spectra Precision Laser HV401 4 Automatic Self Leveling Horizontal/Vertical Visible Beam Laser Interior/Exterior Level Package With Case
Laser is not rorating after tripod with laser tipped while it was in use )roatting ). Any help?
  • 27 Answers
Check to see if head spins by hand head gears may be jammed is it fully leveling it will not spin unless completely leveled could be loose connection from fall A.P. Service & Supplies 610-944-8030 repairs lasers free estimate
Posted on May 29, 2010
3rd shaft lost inside 2nd shaft
Yup.Close all leggs up,tape the other 2 so they don't come out,then shake the tripod like your shaking a thermometer to get the mercury down.That lost leg should slide out easily.Once out,place a small hose clamp on each of the final legs just above the rubber tip and this will NEVER happen again.
Apr 15, 2014 | Promaster FW26T Featherweight Tripod
How do I release a Manfrotto 501HDV head from a tripod
Tip the tripod upside down, on the bottom plate where the head attaches there are 3 screws... they need to be loosened, and then the head will spin off.
Oct 27, 2012 | Manfrotto 503HDV Head and 351MVB2 Tripod...
How do you install the batteys in the stanley tripod legs?
To replace the batteries in each side of the 3-in-1 tripod light, you'll need to slide each light out of the central frame. Once each individual light is out on its own, you should be able to easily unscrew its bottom, giving you access to the battery compartment. Unlike the original Stanley tripod light, the actual tripod legs no longer hold the batteries.
On the original Stanley tripod LED light design, the black tripod leg tips simply unscrewed after you popped them out into the "stand" position. Much simpler to figure out.
Jun 25, 2011 | Stanley 3in1 Tripod LED Flashlight 95155
Laser won't light
you can have a try below suggestions:
  1. Use new batteries.
  2. Use quality wooden matches. Some low quality matches are very difficult to ignite.
  3. Color the tip of the match black.
  4. Keep you hands steady or use a tripod to ensure a steady beam.
  5. Shorten the distance between our portable laser unit and the match.
  6. Use a lens to further focus the lens (try our convex lens).
Apr 14, 2011 | Laser by Nebo LASER
Please advise how to close the battery cover
Hello and Welcomethe Canon A560's bottom panel is reasonably flat, with a sliding door to access the battery compartment and a threaded plastic tripod mount off in the opposite corner. The battery door and tripod mount are far enough away from each other to permit quick battery changes while working with most tripods To close the battery cover first Hold it and make it Flat and then by the tip of Your thumb Press it in inner side To demonstrate it the image is given below: angel_bird_0.jpg
Further assistance i am here to help
Please don't forget to click on Four thumbs which are given below if it is helpful
THANKS & Keep Using Fixya
Mar 09, 2011 | Canon PowerShot A560 Digital Camera
Do you have a spares manual for a manfrotto 501 head and can I get it on line
Got online Information about your Tripad and head (no downloadable manual)
1. How to use" lessons ( Tripod Basics, Studio Glamour Etc)
2. Warranty
3. Tripod + Head Chooser
4. Lighting and Cine Support Solutions
Hope this will help you more.
Click on this link for the lessons, tips and instructions.
Check this LINK also for some PDF files and quick guide that can be downloaded.
Apr 07, 2010 | Manfrotto 501HDV535K Tripod
I lost my keys to my Samsonite 29" Spinner luggage bag and I locked myself out of it. Help!
file an old key with a small 'L' tip or do the same with a hacksaw blade. The tip should be appx 1/2" x 1/8" with the 'L' on the tip. Try several tip sizes. Spray some oil inside first.
Dec 21, 2008 | Samsonite Tripod
Meade etx-80 sticking
Some (not all) versions have an end stop - it it just reaching that? The scope will rotate only aboit 3 complete turns between the 2 ends.
The 'correct' starting position is as follows: Place scope on tripod or table with control panel at the West. Unlock the declination lock (horizontal slew). Rotate scope anticlockwise until it hits the end stop, Then roate it back clockwise until scope is pointing North (should be about 3/8 of a turn, as the end stop is at South West). Then lock the declination, Set the tube horizontal and continue with the alignment process.
Autostar always thinks you have set the position like that. If you haven't, it will work OK until it tries to rotate past the point it won't go, then chaos results!
Feb 12, 2008 | Meade ETX-90 (48x90 mm)
Spectra Precision Laser HV401 4 Automatic Self Leveling Horizontal/Vertical Visible Beam Laser Interior/Exterior Level Package With Case Logo
407 people viewed this question
Top Spectra Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Spectra Measuring Tool and Sensor Expert? Answer questions, earn points and help others
