Question about Corvette Chevy Malibu 90-04 Car Radio Wire Harness
My 2004 Chevy Malibu factory cd player will not pull the whole cd in it states reading cd then check disk. When I hit the eject button it makes a sound like it is trying but does nothing.
  • leshia21 May 26, 2010
    yes the information was helpful and made sense.
  • 10,515 Answers
I would like to share Few Details with you :-
1. On most of the Models, this is due to Faulty CD Lens. In that case, it is better to pick these sets up for $50 - $75 and is cheaper than any Repair.
2. As you also mentioned that when you eject button, there is a sound and it does nothing. The above 2 Symptoms are seen in many cars due SOFTWARE. You need to get the Radio Re-Programmed.
There is a Technical Bulletin's which were issued for the same. One of them would be :-
Condition
Some customers may comment on one of the following conditions:
• Long CD load-to-play time
• CD ejects with an error message of "CHECK CD"
• CD does not return to previous track after an ignition cycle
• Clock resets to 12:00
• CD does not play
• CD does not eject
• CD stuck in CD player
• Radio will not accept CD
Cause
A software anomaly within the radio has been found.
You need to have the radio reprogrammed at the dealer
. Even if you get the cd out, it will happen again. The new software corrects this issue.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on May 26, 2010
    There was a stuck cd in the player but I used double sided tape and another cd to get it out. However while stuck the cd was able to play but would not eject fully. Do u still think the radio needs to be reprogrammed?
  • taran_2005
    taran_2005 May 26, 2010
    Thanks for your response!!
    That's the reason i offered Both the Possibilities. It could be a Combination of Faulty Lens and Faulty Software / Faulty Radio. The above mentioned Solution is actually a Part of Technical Bulletin issued by Chevy.
    Yes, it is a Possibility. I could explain you in a simple way :-
    How Actually CD Ejects from the Player?
    When you Press Eject Button, a signal is sent that would make the Player eject the Disc. If the Software is not Updated or a Glitch, the player might not be able to get a Signal or Might receive a wrong signal and would not eject the CD.
    Hope i helped you.
    Thanks
I bought a 2004 chevy malibu. Im having problems with the CD player reading discs and ejecting them even. Would appreciate any advice to help. Thanks in advance!
You can not buy parts or obtain repair manuals for this, you MUST send it out to a factory approved repair center, many are online that can fix or rebuild the deck..
Jul 17, 2017 | Cars & Trucks
2004 chevy mailbu maxx. I just bought it used today and the factory cd player doesn't work just makes a clicking noise when I hit the eject button and says check disk. Any ideas what to do to get it to...
If it is an in dash cd changer, I would suggest you replace it with an aftermarket single disc player. In dash changers are very delicate and don't take much for them to go bad.
Feb 29, 2012 | Car Audio & Video
My cd is stuck in player of a 2004 chevy blazer 4x4
  • You need to wait for your car's stereo to cool down. If you used it for it for an extended period of time, it may have gotten hot and the ejection device may not respond.
  • Hold down the eject button.If you can hear the mechanical ejection noise. If your car stereo is making this noise, it is more than likely that the CD is just sticking inside the CD player and you can try and grab it with your had and pull it out .
  • Look for a hole the size of a pin on your car stereo's CD player. This hole is very small and looks similar to one on a CD-Rom drive, after locating the hole, use a pin and attempt to manually eject the CD. Now in case you have a factory stereo.
    Hope this will help you out.
  • May 16, 2011 | 2004 Chevrolet TrailBlazer
    Delco factory Radio/CD player,it gives an err msg.and ejects CD
    The laser in the cd player may be dirty or has gone bad and can no longer read the disc.
    Apr 17, 2010 | 1998 Chevrolet S-10 Pickup
    Selective CD player
    you need to use cd-r + look at the ones that don't work they are cd-r- you might of also not closed out the disk that would keep the disk where it would work on you pc but not your cd player.
    Aug 23, 2009 | 2007 Chevrolet Malibu SS Sedan New Cars
    Chevy Malibu 2004, CD disc is stuck in the player. When ejecting only get a clicking. The CD is from the library and has a sticker in the center. I have tried eject and pushing on the cd with a paper clip....
    its jammed in the carrier obviously so yes by all means take out the unit remove the cover & disc that way you can check unit for any damge!
    Cheers Rob.
    Jul 20, 2009 | 2004 Chevrolet Malibu
    Stuck CD in the multi CD player of 2004 Chevy Malibu Maxx
    The only thing that is left for you to do is to remove the stereo and then disassemble it and remove it yourself. A little daunting but needs to be done. Sounds like it went in wrong and then became jammed
    Jun 10, 2009 | 2004 Chevrolet Malibu
    2004 Chevy Silverado factory Stereo, CD is stuck in player, sounds like it is trying to eject but won't!
    I searched quick and couldn't really find anything on a manual eject button. Flip through the manual a little bit and see what it has about the radio. If all else fails and you aren't worried about possibly breaking the stock cd player, some skinny needle nose pliers should reach in far enough to grip the cd and you can pull it out. But there is a good chance you could break the cd player in doing so.
    May 04, 2009 | 2004 Chevrolet Silverado 2500HD
    2004 MALIBU CD CHANGER/ STUCK CD
    My CD player did the same thing on my 2005 Chevy Malibu MAXX LS.  I know it sounds weird, but disconnect the car battery from the car (resetting the whole car system), and then reconnect.  I pressed the eject button on the console, and it ejected my CD with no problem.
    Oct 21, 2008 | 2004 Chevrolet Malibu
    My cd player in my 2005 chevy malibu wont eject all it does is clicks
    we have a 05 malibu. cd got stuck and displayed locked on radio. on the passenger side floor board is a fuse box. u have to pull the panel off takes about 10sec to do. find tha fuse that says radio its a 10A fuse. pull tha fuse out. put key in ignition and turn forward. put fuse back in and hit the eject button cd will come out.
    Sep 07, 2008 | Audio Players & Recorders
    Corvette Chevy  Malibu 90-04 Car Radio Wire Harness Logo
    412 people viewed this question
    Top Corvette Car Audio & Video Experts
    xxxxxx xxx
    Are you a Corvette Car Audio and Video Expert? Answer questions, earn points and help others
