Question about Whirlpool ED5THAXMS Side by Side Refrigerator
Whirlpool Refrigerator I saw a post where you could get water from your Whirlpool, but couldn't get it to make ice. That is now the same problem we are having. May I ask what the problem ended up being with yours?
  • 1,073 Answers
Replace the water valve
Posted on Apr 10, 2008
How to reinsert ice maker into 1992 Model TS25AF
You unscrew the srews holding the ice maker into the refrigerator. There may be 2 or 3. Then you should unplug any electrical connection, and saw on another site you need to remove the arm and install it onto the new ice maker. Then replace the new ice maker into refrigerator. There should be a different piece that's actually connected to the water input and then sends the water into the Icemaker.
Aug 31, 2013 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker stoped,is there a reset button ? Filter has been replaced.Have tried the hair dryer .
Let's begin by filling your ice maker with tapo water if now small cubews are in tray. If after the water freezes and the ice drops into the ice bin and does not refill itself with water this will point to the=> 67006322 Dual Water Control Valve Ice makers are some of the most worked part of a refrigerator and have about a five year lifespan. There are just too many things that can go wrong that can stop the ice making process. To explain the process of a Whirlpool ice maker I am going to post a Whirlpool Ice Maker Troubling pdf and a short YouTube Icemaker Repair toutorial. If you have any questions I will be here to assist you, Thanks Sea Breeze
Jun 02, 2012 | Maytag (MFI2568AEW) Bottom Freezer French...
How can i check to see if the defrost is working in my whirlpool refrigerator model number ET1CHMXKQ03. Initially water started leaking into the fridge from the freezer, i looked and saw everything iced...
you will need to access the heater in the rear area of the freezer compartment and disconnect the heater element and take a continuity test of the element,if this checks good,then in the same area is your defrost timer,unplug the heater from it and hook up a voltmeter and energize the defrost timer manually and see if you have a voltage there
Jan 16, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Water and ice dispenser leaking water
Just saw your post, sorry no one answered you. If the ice maker is leaking it has a crack or the dual water control valve is stuck open slightly. Most times it is the defrost drain behind the back panel and at bottom of the evaporator coil. Some drains freeze shut and some become blocked as the make the turns leaving the refrigerator. If you would like more information and photo help please let me know, Thanks, Sea Breeze
Jun 02, 2009 | Whirlpool GS5SHAXN Side by Side...
Whirlpool refrigerator leaking from top of unit
Listened to other posts and figured drain plug was clogged. It was with ice. Removed bottom pan and back panel of freezer, removed ice on bottom, put hot water in drain to thaw ice until it flowed into pan underneath fridge. Thanks for the ideas.
Jun 02, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Roper refer/freezer with ice maker
If the ice maker is not running and water still comes in replace the solenoid valve where the water line attaches, otherwise replace the ice maker module
Jun 04, 2008 | Whirlpool ET1FHTXM Top Freezer...
Whirlpool Gold icemaker not working Model GD5SHAXLB02
problem with the heater or the thermastat of the ice maker
May 11, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice maker not getting water
It could be the water valve at rear.check water supply to valve,
if that's ok,you could change valve at rear
Nov 30, 2007 | Whirlpool ED2FHEXN Side by Side...
Whirlpool refrigerator ED22TEXHW01 ice maker
Tammi, you first want to check to make sure the water inlet tube to the icemaker is not frozen shut. Next, get yourself a jumper wire about 4 inches long with the ends stripped exposing the wire on each end. Pull off the ice maker cover, it will pull right off. Now you are looking at the module. On the module, left side, you will see two test points marked V and L. Insert one end of the jumper wire into V and the other marked L. You are now sending 120 volts to the water valve and water should fill the ice maker providing the inlet tube is not frozen over. If it doesn't fill, you either have a bad water valve or module itself. Also check to see if the clips that hold the center gear on the module are not broken. back.
Mar 22, 2007 | Whirlpool GD2SHGX Refrigerator
Whirlpool ED5THAXMS Side by Side Refrigerator Logo
70 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
