Question about Toshiba Satellite L10 Notebook
My Toshiba L10 will not switch on the power supply is ok and plugged in and there is a blue light on to say power cord is connected but still will not power up, any ideas?
    Sergeant:
    Champion:
  • 256 Answers
Do you have a known good ac adapter to try it with? Or is that ac adapter you were saying lights on powering on a different computer?Try to test both to check the functionality of the ac adapter and the port. If ac adapter will work with a different pc, then possibly the port is damaged. You may need to replace the motherboard. If still it wont turn on, then you may just need to replace the ac adapter.
Posted on May 26, 2010
Testimonial: "Its sorted thanks. I have replaced the power supply and its fine now, cheers."
Blue blinking light
I would check the easy solution first. Servers have redundant power supplies. Make sure that all power supplies power cords are connected to the power outlets. I have seen a similar problem when one of the power supplies was not connected to the AC power source.
Apr 09, 2014 | Intel S5000VSA Motherboard
Toshiba satellite A200-27Z power cord led flasing failure to post will try any suggestions
Have you tried another Cord with the EXACT same power specs? Remove the battery. Has the cord/charger/transformer been damaged? Has the AC jack been damaged? Due to pulling on the cord while plugged in? At the AC jack "wiggle" the plug a bit to see if the plug and AC jack are making a good connection or Loose. Sounds like a loose AC connection.
Jan 10, 2013 | Computers & Internet
I have a hp desktop about 5 years old..few days ago we had a power outage. power came on and off a few times ..i wasnt home but my pc was on when i came home my pc was off and wouldnt start..i try to push...
> bad power supply
Try an ordinary lamp in the wall-socket -- to make sure that a circuit-breaker inside your home has not "tripped", i.e., no power to anything that plugs in.
If there is an on/off switch beside where the power-cord connects to the power-supply, switch it to the "off" ("zero") position.
Unplug the AC cord from the power-supply.
While watching the fan inside the power-supply, and/or watching the fan on top of the CPU, plug-in the AC cord. One of the fans may "twitch", if there is power.
Flip that rocker-switch to the "on" ("one") position, and see if one of the fans "twitches".
Also, look on the motherboard for a small lamp -- it may go on if the AC power-cord is connected,
or may go on when that "back" switch is set to "on".
Try a different power-supply. If still nothing, then it's your motherboard that got "fried".
Nov 11, 2010 | HP Pavillion s7420n PC Desktop
It will not turn on please help me
Hello, I will try my best to help you, ok? I need to ask you a couple of questions so I can understand your situation more clearly ok?
1) Do you have your power cord plugged into a Power Strip or surge protector? If so, check and make sure that the switch is ON and/or the surge protector button has'nt been tripped.
2) Is there any sign of power to the Power Supply Box that your power cord is plugged into? (ie: led light, or sound of the fan inside of the Power Supply Box?)
3) Is the outlet that you are connected to live with power? (try plugging a lamp into the socket to make sure)
After you have ruled out the above possibilities, let me know, and we will go from there, ok?
Jul 18, 2010 | HP Pavilion a1700n PC Desktop
Power problem .... tried 3 different power supply cords...the green light on the rear blinking meaning???? pushed switch on front ...held in.....no response only moved from 1 office to another....always...
was it dropped..?? the indicator light should b solid not flashing.. If you held the power switch in for several min an nothing Try plugging the cord directly into the wall. Do not use power strips as they may have failed.Toggle the voltage regulator switch from 115V to 230V then back again. If you are in North America, this switch must be on 115V. you may have a loose connection in the machine Lastly, you may need to go inside the case and confirm the thin wires running from the front power and reset switches are connected to the motherboard., to check be sure u are grounded an check all connections inside the computer... If the LED is still flashing, the power supply is probably bad.
Apr 28, 2010 | HP Pavilion a350n PC Desktop
My Toshiba Equium L10 - 200 notebook has suddenley stopped working. When it's plugged in to the mains there are no lights on and then when I press the power button, the light closest to it flashes once,...
Just remove the battery and switch it on main power and check.if it is work then connect the battery and conncet the power cord and leave it for 15 minutes and then switch on the power button.
Nov 17, 2009 | Toshiba Satellite L10 Notebook
Power on but no screen oor hard disk motion
Hello there:
i would suggest using a spare monitor and connect the cord that would normally go into a computer and connect it to the laptop and then plug in the power cord for the monitor and turn on the computer if this works and everything is ok then you know that the laptop screen may be faulty or there may be a loose connection somewhere ok?
best regards michael
Sep 11, 2009 | Toshiba Satellite M35X-S111 Notebook
Describe your Toshiba Satellite® L10 PC
You most likely have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :- To determine if you have a LCD screen or video card problem, read this and follow the instructions. Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case. The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills. Check out www.lcdparts.net for parts, repair service and DIY info.
Jun 04, 2009 | Toshiba Satellite L10 Notebook
Toshiba laptop power cable won't charge battery
I had the same problem with my HP laptop some years ago. you have a broken cable/cord and it is the part that is permanently attached with your power pack. If you look at the cord that plugs into your laptop, you can be able to see the faulty part of it. it is usually very flexible or swollen. You can either take it to an electrical technician to change that part of the cord. Your power pack is still ok, but have the technician to check it out first before you change the cord. Else, you may have to get another power pack. below is the full specification of the power pack that is recommended for your laptop.
This Toshiba Global AC Adapter is a 65W external AC adapter designed to work with Satellite 1000, 1005, 1100, 1105, 1200, 3000, 3005, A80, A85, A110, L10, L15, L20, L25, L35, L45-S2416, L45-S4687, M30X, M35X, M40-S312TD, M45-S165, M45-S169, M45-S165X, M45-S169X, M55-S139, M55-S141, M55-S1001, M55-S1391, M55-S1412, M105-S10XX, M115-S10XX; Tecra L2 series portable computers. Get an extra AC adapter to be kept at home, in the office or in your travel case.
Specifications:
* Power: 100-240V/ 50-60Hz Frequency (Universal) input voltage; 19V x 3.42A output voltage
* Dimensions: 4.25" W x 1.34" D x 1.85" H
* Weight: 0.67 lbs
* Power cord included
* Compatible with Satellite 1000, 1005, 1100, 1105, 1200, 3000, 3005, A80, A85, A110, L10, L15, L20, L25, L35, L45-S2416, L45-S4687, M30X, M35X, M40-S312TD, M45-S165, M45-S169, M45-S165X, M45-S169X, M55-S139, M55-S141, M55-S1001, M55-S1391, M55-S1412, M105-S10XX, M115-S10XX; Tecra L2 series portable computers
* One year limited warranty
Note: This AC Adapter is the direct replacement for Toshiba 60W AC Adapter (Mfr. Part#: PA3097U-1ACA) and Toshiba 65W Global AC Adapter (Mfr. Part#: PA3396U-1ACA)
Apr 22, 2009 | Toshiba Satellite M35X-S149 Notebook
Power BOX supply cord problem or hardrive problem?
Check these settings first. In a clear spot on the screen where no icons are, right click and go to properties, box opens and at top should list from R to L, themes-desktop-screensaver-appearance-advanced. click on screensaver, close to bottom click on power, another box should open, click on power schemes, make sure it's set to portable/laptop, and at bottom make sure settings for plugged in are are set to never. If it's not that then you have a bad power supply cord, or a bad power supply unit in laptop. If it's new and under warranty take it in and have replaced if not warrantied then will cost you about 100-150, just a guess!! hope this helps. But it sounds like the supply cord making the beeping noise might be bad. Make sure it's plugged all the way in as well.
Nov 17, 2008 | Toshiba Satellite M40-S417TD Notebook
Toshiba Satellite L10 Notebook Logo
225 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
