Question about Canon PIXMA iP1300 Printer
I can't print out.
Hello hope someone can help me.
I can't print out because every time I print the paper wont continue to go down so thats why I cant finish printing. The printer is ok when turning on and offf the only problem is in the printing method.. PLS HELP ME
    Sergeant:
  • 284 Answers
Most probably the paper feeding area stuck by foreign object or faulty DRIVE ASSY
Posted on May 26, 2010
Testimonial: "ok thanks :)"
  • Chee Seng Jun 05, 2010
    You may try to uside down the printer unit, hope there is something falling down then you may operate the machine properly.
Hello, I have problem with Printer Kyocera FS-1300.. when i connect it to pc, it starts to print some symbols, like smiley face on left corner of page, and i cant stop it, when i disconnnect my device...
Hi. I would suggest that you unplug the printer, reinstall software and check you computer for viruses. If i continues, try letting it print out. maybe someone set so that 30 pages with a smiley would be printed next time you plugged it in. I how this will fix you problem.
Jun 08, 2011 | Kyocera Fs-1300d Printer
Our printer is a Samsung CLX3175FN and we can't print, scan or photocopy because it keeps on flashing "document jam". We already checked it, tried turning it off for a while but still we get the...
check carefully for pieces of paper inside of printer.
open front cover, remove printer cartridge and check...
open rear cover and do the same thing.
If your printer still wont print check paper sensor, maybe someone is broken - if "YES" just visit Samsung service
Apr 28, 2011 | Samsung CLX-3175FN Color Laser All-in-One...
Error Number : 71 The selected paper size and the paper source are not compatible. Turn the Photo Paper Tray handle to the right, load paper of the correct size in the auto feeder or change the paper size...
This is probably a software settings issue, please check in the application that you use for printing if the default paper size is the correct one (A4 on Letter)
Also check in Control panel, under printers Properties, that the correct paper size is selected.
Try printing again.
Regards,
Katharsys
Mar 31, 2011 | Office Equipment & Supplies
Printer wont print. The orange light is lit up on the second spot from the left which shows an up and down squiggle line. Cant find my manual to show me what this error message means.
The light means that the printer has a paper jam.
To resolve this, Press Continue twice quickly to see the secondary error code. Press Continue to resume printing once all the jammed pages are cleared from the paper path.
You may download the user manual from Lexmark Support site, or you may also click the link http://bit.ly/a8pwFZ to download the user manual.
For further assistance, please contact Lexmark Technical Support
Feb 13, 2011 | Lexmark E260dn Laser Printer
It wont print.
did you press the Enter key to continue? try to open the ink cover and close it.
you might need to shut it down (possibly even take the power cord out) and re-print.
HP printers a known to get "confused"
Feb 09, 2010 | HP DeskJet F380 All-In-One Printer
My Epson cx 4200 won't print because each attempt the paper jam light flashes and the printer stops trying to print. The paper is being pulled into the machine un-evenly.
It's highly likely that you either have a foreign object down the paper feed tray or the guides are incorrectly set...
Hopefully one of these will solve this:
1. Remove any paper, tape down the scanner lid and
gently tip your printer upside down and give it a GENTLE shake to see if anything drops out. This is really only something I'd recommend for someone strong and careful so take your time.
2. Check for any jammed foreign objects such as pens, paper clips, etc...that have fallen down into the printer. The place to look is wherever the paper seems to be bunching up most as it goes through
3. Make sure you're inserting the paper, with the guides set to the correct width and not loose. The guides help correct any issues with skew as the paper is pulled in, so this may correct any other issues.
Hope one of these helps..
Jan 24, 2009 | Epson CX4200 All-In-One PSC Printer
Paper Stuck in Printing Calculator
Maybe the commenter should get a life and do something else besides trolling sites like this sniping at people trying to do real work.
We came here to see if someone had solved the problem...sure, we're smart enough to buy a new one, but why throw out something that can be fixed for a few minutes time or a few dollars investment.
My problem ended up being a small piece of paper caught in the paper path...working paper through it several times cleared the issue. Hope that helps someone.
Apr 03, 2007 | Sharp EL-2630PII Calculator
Paper problems
I had same problem. first turn of the printer and unplug electrical supply. turn the printer upside down and make sure there is nothing stuck in paper feeder. the next step, take a paper sort of a greetings card and try to run it through the feeder gently. if you cant get it through then don't force it. but this will clear up any object stuck in to paper feeder. now plug in yor power cord and try a test page from your printers properties. hope this will work for you. good luck...........
Aug 16, 2006 | Dell 810 All-In-One InkJet Printer
Canon PIXMA iP1300 Printer Logo
154 people viewed this question
old marine
old marine
