Question about HP Office Equipment & Supplies
My HP 1200 series printer,over time is now not responding,when I ask it to print,the print queue just shows error?if I perservere for 30 minutes eventually the printer will respond and print.
  • HP Master
  • 4,737 Answers
Your first requirement is to check the print queue, double click on the print icon on the taskbar and check how many print queues are there. If there are more except the one you gave, delete them. To do this, select the unwanted print queues, right click, cancel. Next, check your Ram, how much memory is available, at least 512mb should be installed to run a modern printer error free, i recommend 1Gb.
Thirdly, clean all the temporary files and unwanted registry files using a registry cleaner, you can download one from here Ccleanerperiform or here ccleaner.
Again, make sure no virus has been infected your system. If this problem still persists, run a full virus scan using an updated antivirus
You'll also need to update the driver of your printer to the latest version. If you still have problem even after doing this, Please let me know. I wish you good luck.
Posted on May 26, 2010
Error 49.38.07
Power off the printer for a minute. Power it on. Do you get the 49 error, does the printer READY? If it comes READY wait a few minutes. No 49 error? start printing, anything. 49 come back? clear the print queue after powering off the printer. Power back on. Do what you did above. No 49 error, it was probably a bad print job in the queue. If it comes back again, you will have to go to www.hp.com/support and answer the questions until you get to the FIRMWARE UPGRADE. Read it carefully and do it.
It's also possible there is a bad network, bad memory or bad formatter.
Jul 08, 2014 | HP Laserjet P3015X Printer
49 server error
49.xx.xy error- General firmware error ( like a blue screen in windows)
a corrupt print file is usually the cause and can be cleared by disconnecting the printer from the network, then cycle the power , allow the machine to come to ready and ask the pritner for a configuration page( just a test to see if the printer is able to respond- if not then replace formatter/firmware chip) when this has finished printing goto the workstation that sent the last files to the printer and clear ALL print queues form the PC then and only after clearing the print queues can you re-connect the network - failing to clear the print queue will cause the printer to re-try printing the corrupt document which will result in 49.xx.xy error being displayed again.
Dec 28, 2013 | HP LaserJet 5200 Printer
We use hp T770 HDD, error massage 79.03 when loading, after show preparing print system massage in a few minutes. ask for restart but after restarted the problem persist. please kindly help us if there any...
79 errors are often linked to firmware. Unplug the printer from power as well as any network or USB cables you may have plugged in. If the printer will restart without an interface cable connected then it is likely a bad print job. Clear all jobs from the print queues and then plug in the interface cable. If printer continues to stay at ready, download the current firmware and install it. This should resolve the problem.
May 25, 2011 | HP DesignJet Z2100 InkJet Photo Printer
HP Laser Jet 1200 Series does not respond to the print command. The dialog box shows "printing" then "deleting" then dissapears. The light on the printer stays green. I use Vista 86....
Hi, i think you have a software problem.
Try to download and renew software from here:
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?pnameOID=29790&locale=en_US&taskId=135&prodSeriesId=29789&prodTypeId=18972
Remember to select your operating system.
The x86 is 32 bit, and the x64, is 64 bit system.
Uninstall the old driver before installing the new one.
Try also to erase old print jobs.
Hope this will help you.
Apr 12, 2011 | HP Office Equipment & Supplies
49.2f9d error hp laserjet 3005dn how to solve the problem
Most times a 49.xxxx error on an HP printer is caused by either the print driver, firmware or the print job itself.
If it happens when printing a PDF file try sending the file to the printer as an image.
Upgrade the print driver and the firmware.
You may need to disconnect the printer from the pc or network, power it off and pull the plug for a couple of minutes to clear the error.
If it's a network printer it would be a good idea to check the printer queue for any jobs still in it and delete them before powering the printer up again.
Dec 14, 2010 | HP LaserJet P3005 Printer
HP laserjet 1200 printer
Upgrade your ram and clean the registry. this will fix your problem, generally almost all this problem's related to Memory, so first upgrade your Ram to at leat 512, i recommend 1 Gb. Good luck.
May 26, 2010 | HP LaserJet 1200 Printer
Hp director shows 2 icons.
just adjust the cable of the printer at the back of your desktop..
Jan 21, 2009 | HP Compaq dc5700 Microtower - Free Flat...
Lexmark 1200 series printer won't print
Call me and I can walk you through what Lexmark just walked me through with the same problem
Laurie
732-356-7256
Jan 10, 2009 | Lexmark X1270 All-In-One InkJet Printer
Not Printing
The copy function works fine because the printer alone is handling the copy. When you print, you need two machines to get their stories straight. Is your printer turned on before the machine boots up? or is the printer turned on after the machine has booted? Sometimes Windows won't load all the drivers needed if it doesn't detect a device during bootup. You may want to download the latest and greatest drivers from the HP site, uninstall and reinstall the drivers.
Jan 27, 2007 | HP PSC 1315xi All-in-One Printer
19 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
