Question about Dell Latitude D600 Notebook
A disk read error occured and keep on re-start
  • Dell Master
  • 32,281 Answers
This error occurs when the computer boots up and cannot find the hard disk and boot up with Windows.
The problem is either the hard disk has failed or the system files are missing or corrupted.
First check the BIOS settings to see if the hard disk is detected and it is the first boot device. If the hard disk is not detected then most likely the hard disk is faulty and you need to replace the hard drive and install Windows on the new hard drive, plus the laptop's device drivers and your programs.
If the hard disk is detected then place the Windows installation CD in the CD drive, and boot up with this Windows CD and do a Repair.
If this does not work then re-install Windows.
Posted on May 26, 2010
  • Dell Master
  • 4,737 Answers
Please check that the hard disk is connected properly. If you know that the hard disk is working, check whether it is detected or not. If it's not detected, you'll need to recheck it again with the power supply. If possible, try it to another Laptop so that you can make sure that Hdd isn't the culprit. In case it's detected and the problem still persists, repair the operating system installation, this will definitely solve your problem. Good luck.
5 Suggested Answers
TeK Micro
  • 62 Answers
SOURCE: problem with a disk read error
There are a couple of possibilities.
1. The hard drive is defective.
2. The operating system is corrupt.
The easiest way to test this is to run the restore cd that came with the computer to reload Windows.
If you get this error while running the restore cd then you will need to get a new hard drive.
Posted on Jan 03, 2008
jilpeshpatel
  • 259 Answers
SOURCE: disk read error occured
If not give it a go and do a repair if needed again!
1- You may have a corrupt MBR (master boot record)!! You will need to reformat and do Fdisk /mbr to delete the master boot record!! Save all data first as this will not allow you to access any of your data as all file location addresses are located in the MBR!!
2 - Your harddrive may have a bad sector get a zerofill tool(low level formatting tool)!! This will rewrite you HD's sectors putting them back to factory spec's!! Maxtors is called Maxblast you can get it from thier site!!
3- or it could be a defective drive, but most read errors are due ot corrupt MBR or a bad sector!!
Posted on Mar 26, 2009
byteguy
  • 2229 Answers
SOURCE: A Disk read error occurred upon booting
This could be a sign of the hard drive having a problem.
I would recommend that you do a scan of the hard drive to check for errors.
You didn't mention which operating system you have, but you need to click on My Computer and then right-click on your hard drive. Go to Properties and then Tools.
Once there, select the option that tells you to check the disk for errors. Check the entire drive. Note that this will not run right away. You must restart your computer, as the utility needs exclusive access to the hard drive.
If this type of error reoccurs, it's time to back up your data, 'cause you probably have a hard drive that is dying.
Posted on Apr 09, 2009
  • 1752 Answers
SOURCE: how to fix a disk read error occured?
Sorry, it's time for a new hard drive.
Posted on Nov 19, 2009
My acre aspire 5517 keeps getting a disk read error occurred and I keeps repeating it over and over what do I do?
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Apr 17, 2013 | Acer Aspire Computers & Internet
"A disk read error occurred. Please click ctr +
You have as it states, a disc read error which means you have errors on the hard drive.
As soon as you get into your system run CHKDSK/F, that will attempt to restore the damaged files.
Make backups and look for a replacement hard drive.
Hope that helps.
Feb 16, 2011 | Acer Aspire One PC Notebook
You have problem at the boot sector of the disk. Maybe it's hardware problem (controler, disk) or maybe it's a virus. Shut down the system and try start it up after some minutes. If it start up make a full back up just in case ......
Stelios.
Feb 21, 2010 | Computers & Internet
When i start my asus eee pc 900 laptop i get an error it says
BIOS / system is not able to read ur boot files and boot sector on HD...press F8 when system starts and get into Safe Mode or Last known good comand that worked etc etc...and then do a system scan
Jan 11, 2010 | ASUS Eee PC 900 PC Notebook
when upower up thecomputer enter in bios setup press del or F2 or F1 to neter in bios setup when u power up.
thenr eset bios defaults settings.
then check your hardiskk is deteted or not.
if sata is enabled then disable then press F10 to save settings.
Jan 07, 2009 | Sony VAIO VGN-FS640W Notebook
More than likely you have a hard drive failing/failure.
You should have it looked at if you are not "comfortable" doing it yourself.
Read hard disk error keeps coming up, computer does not recognise the [player
acer laptop 5290 won't boot up.. keeps saying "disk read error occurred" cannot get anywhere but to that screen saying that.
Jul 26, 2008 | Archos 104 MP3 Player
Problem with a disk read error
Jan 03, 2008 | Computers & Internet
Dell Latitude D600 Notebook Logo
308 people viewed this question
Alun Cox
