Question about Radio Shack Pro-2051 Base Scanner
Radioshack pro 2067 will not recieve anything
It slowly started to get static and now will not even recieve weather
    Genius:
  • 1,274 Answers
Make sure its your local weather channel, turn squelch to minimum, get your local frequency at www.RadioReference.com ...hope this was helpful...
Posted on May 26, 2010
I need to program a weather scanner for a pro 2018 weather scanner from rdio shack
Weather frequencies are factory programmed into the PRO-2018. Just press the weather button to start scanning them. You can also program one or more manually if you wish. For a list of NOAA weather broadcast frequencies, follow this link:
http://www.nws.noaa.gov/nwr/indexnw.htm
Need the manual for your scanner? You can download/print it here:
http://support.radioshack.com/support_electronics/doc69/69290.pdf
Bill B
Sep 05, 2010 | Radio Shack Pro-2018 Scanner
My scanner (radioshack Pro 2018) doesn't receive signals from local poloce, ambulance and so on. What do I need to do?
First, try scanning the Weather band to see if you scanner is working properly. If you don't pick up anything, your scanner likely needs some professional help. If the Weather broadcasts come in, then you just don't have the correct frequencies programmed for your local services, and it's possible that your area is using a trunked system - which your scanner is not capable of receiving. For a comprehensive database of active frequencies and systems in your area, Visit:
The site will tell you if trunking systems are in use, and it will also provide a wealth of other useful scanning info.
Bill B
Aug 10, 2010 | Radio Shack Pro-2018 Scanner
Hi I have a problem buying a RadioShack Scanner pro 2067 and I want to listen to the radio links operating in 250Mhz brodcasting as I do to unlock the scanner to work on all frequencies? Lucas alosno...
Your scanner does not support reception in the 250MHz range, and there is no way to "unlock" it or any other modern scanner to receive frequencies that it is not designed to receive. In order to receive transmissions in the Military Air band, 225-380MHz, you will need to purchase a different scanner - such as the Uniden Bearcat BC370CRS.
Bill B
Jun 01, 2010 | Radio Communications
Can not hear anything
Take the cover off, hook the antenna up and turn the unit on. Take a pencil with the eraser end and press around on the circuit board, look for cold solder joints....hope this helps..
May 17, 2010 | Radio Communications
My cb transmits with a very weak signal and won't recieve anything. The weather band recieves with no problems. I couldn't even pick up a signal on my SWR meter but a friend of mine tested it on his home...
There are a few things that could be wrong. If there is something wrong with the mic, you may not hear anything on the radio. but weather will work.
Other then that, the receive section of the radio could be blown.
Try a new mic, and if it doesn't work, then there is something blown in the radio. It needs a tech.
Sep 25, 2009 | Cobra 18 WX ST 40-Channels Base CB Radio
I have a new pr097 scanner and programed it fine but i get nothing recieved not even weather channel thay scan all fine but it dont stop on anything i cant figure it out also on my old scanner when you...
im just going to radio shack and return it for the only other one they have in stock which only goes to 512mhz whics stinks but at least i will recieve something wwhich is better than nothing
Dec 27, 2008 | Radio Shack Pro-97 Handheld Scanner
Radio Shack Pro-2051 Base Scanner Logo
154 people viewed this question
Top Radio Shack Radio Communications Experts
John
John
Greg Cann
Greg Cann
Jason
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
