Question about HP Officejet J5780 All-In-One InkJet Printer
My hp j5780 all in one printer is saying 'close cartridge door' it is closed . it won't let me do anything i have tried opening and closing and removing ink cart's and replacing still says the same.
    Problem Solver:
  • 6 Answers
I was having this problem as well. HP has a tutorial on this problem:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c01050739&dlc=en&product=3301296
However this document stopped just short of solving my problem. When I got to step 3, I found that the metal lever referenced in the document was missing from my printer. I have no idea what happened to it. This metal lever, when present, depresses a contact switch when the cover closes and permits the printer to function. If the metal lever is absent, the contact switch is not depressed and the printer believes the cover is still open.
However, the instructions don't say what to do when the metal lever is missing ... other than service the printer.
HP technical support was no help. They advised me to buy a new printer. However, I discovered a work around: I unscrewed the two screws in the top of the cover and placed a dab of sticky tack on the contact switch. Then I put a carefully folded square of aluminum foil atop the sticky tack. When I screwed the cover back down, this arrangement pushed down on the contact switch and the printer resumed function.
Hope this information helps you.
Posted on Jun 10, 2010
I have an open door message on my hp 350 copier printer
Open the door, ensure there is no debris of any kind arount it and then shut it firmly. This may resolve the issue
Jun 10, 2015 | HP Deskjet 350 InkJet Printer
Hp cp2025 error reads "front door open" when front door is closed
pront door liver switch open not work it ,or it displace.you should check it or service need
Sep 12, 2012 | HP Laserjet Cp2025n Printer
Cartridge door open message won't go away
see door switch your door switch have problem
May 27, 2012 | HP Office Equipment & Supplies
HP psc 1210 won't print. screen says i have a door open
you need to close cartridge access door Close it
Hope this helps,
Lucas
Jul 07, 2011 | HP Office Equipment & Supplies
HP deskjet 2360 won't print states door open but it is closed - just installed replacement cartridges
The sensor which reads the door as open or closed is probably being blocked by something so that it is not registering that you have closed it.
My recommendation would be to open the printer, use a flashlight and try to find if there are any scraps of plastic or anything that might be causing the printer to think it is still open.
If that doesn't work, try closing it gently but firmly, and then use two hands to shift the top back and forth slightly to see if it is slightly mis-aligned.
If neither of those are the culprit, there may be a problem with the door sensor that will need to be examined by a repair person, but that is fairly unlikely.
Hope this is helpful!
May 13, 2011 | HP Deskjet D2360 InkJet Printer
What does ! in a circle mean on an HP 2035n printer
The printer cartridge door is open. Attention
The print-cartridge door is open. Close the print-cartridge door Attention
Jan 28, 2011 | HP P2035N LaserJet Monochrome Printer
All in one hp printer says "cover is open"? what do I do?
Dear Sir,
Step 1: Close door If the cartridge access door is open, close it. Figure 2: Close doorc00112062.jpg Then restart printer and try. Thanks For Your Time,
Apr 07, 2010 | HP Photosmart C6280 Printer
Problem getting J5780 to recognize that cartrige door is shut
Is this a BRAND NEW printer? Just setting it up, just took out of the box?
If so double-check that you have removed all the packing/shipping tape pieces, plasic guards, retaining pieces .. that is what is sounds like
Dec 26, 2008 | HP Office Equipment & Supplies
Door open , close print cartridge access door
I have an HP Officejet 6210 All-in-One. When you open the print cartridge access door there is a black toggle switch that needs to be in the depressed position to let the unit know the door is closed. Something was missing from the topside of the "door" so the switch didn't close. I simply stuffed in some foam material to close this, and the unit operates normally. You will need to remove this when changing cartridges, then replace it again.0a64d2c.jpg
Jul 20, 2008 | HP Officejet J5780 All-In-One InkJet...
Says printer cartridge access door open when closed
No it will not complain for an open door if there is no cartridge. There will be a separate warning for no cartridge or toner not installed error. You might want to play around with the cartridge door a little and see for a possible paper stuck somewhere inside.
Apr 26, 2007 | HP PSC 2110 All-In-One InkJet Printer
HP Officejet J5780 All-In-One InkJet Printer Logo
116 people viewed this question
Seeker5211
Seeker5211
