Question about Hampton Bay 52 In. Brushed Nickel Romano with Integrated Pan Style Light Kit Fan
I have a Fan model 404 141 54'' windward 111.
I have a Fan model 404 141 54'' windward 111. The fan only work in medium speed on auto or manual mode
salt56
  • 373 Answers
SOURCE: Hampton bay Fan 54 in
I think one of the brushes in the motor may be at fault: not connected properly. Would require taking motor apart and checking
Posted on Dec 30, 2007
SOURCE: Hampton Bay 54 In. 5-Blade with remote control at wall.
1. Set the remote to run the fan on high.
2. Pull the fan speed chain until the fan reaches high speed.
3. All speeds should work normally now.
The remote is modulating the maximum speed as set by the pull chain.
Posted on Apr 08, 2008
  • 10 Answers
SOURCE: Hampton Bay Ceiling Fan Windward II
There is a 4 position (dip) switch on both the fan housing and the remote. Make sure these switches are set exactly the same and the remote will control the light and fan separately. If not, the remote may be getting interference on the preset frequency - try CHANGING the dip switches to a different setting and the remote should work.
Posted on Oct 24, 2008
  • 75 Answers
SOURCE: lost screws to attach fan blades on ceiling fan
This is not a 'promo' for Home Depot but you will find the screws there that you need.
You will need 15 screws, with an 'unfinished' appearance, for the attachment of the five blades to the arms, and 10 screws that have a smooth rounded finish to attach the arms to the motor housing. If they do not have it in stock they can order ot for you.
If you have an electrical fan store in your area you should be able to find the items there as well.
If you have an old discarded ceiling fan, take the screws out of it and try them on your current fan, they should work.
Good luck. :)
Posted on Apr 26, 2009
SOURCE: I have a hampton bay
Use gloves to grip the cover and just turn. Works like a charm!
Posted on Jul 01, 2010
Instalation diagran for windward II speed control unit
I thought this fan comes with a remote. You can't use both.
Aug 03, 2014 | Hampton Bay 54 in. Windward II Brushed...
Www gpwarranty com
for the Problem with Hampton Bay 54 in. Windward II Brushed Steel Ceiling Fan check the manual
http://lightingworldbay.com/windward-iv-52-indoor-brushed-ceiling-fan-manual/
Apr 25, 2013 | Hampton Bay 54 in. Windward II Brushed...
Windward II, model 55296; Remote no longer activates fan or light even though electricity is on. Batteries have been changed. Face of remote just has blank rectangle with a blank.curved indicator...
First off you might try shutting down the power on the Windward itself. There may be a disconnect near the unit, or a breaker.. or the breaker may be in the house in the main breaker panel. In either case, turn it off for maybe 10 minutes and see if that resets the system for you.
Since they've been working for a year it's not the initial setup so hopefully the above gets you lined out. If not you'll probably want to check out Windward's customer service since that code probably isn't in your basic home-owner's manual you get with the unit.
If you know any local HVAC folks you might ask a technician if he has the problem codes (and symbols) for that model and they can give you an idea of what's up.
:o)
Jan 04, 2011 | Heating & Cooling
Hampton Bay Windward II Purchased 2002 The fan has lost high speed. Low speed and medium speed work fine. When the fan is turned on to high speed it runs at medium speed. When switched from high to medium...
Most fans have a small rectangular multi-tap capacitor connected to the speed control in the fan. It is likely that this has gone partially bad. The capacitance values are printed on it. Lighting stores and big box hardware stores generally carry replacements.
Feb 23, 2010 | Dryers
No Medium Fan Speed
sounds like ur medium speed has gone out
Feb 20, 2010 | Air Purifiers
Fan will go no faster than Low
SPEED MOTER CONTROLLER MAY BE DAMMAGED.
Aug 10, 2009 | Dryers
My Hampton Bay Windward II
I need a fan chain pull switch for my Hampton Bay 5 Blade Model 552 od--
SKU # 409-952----
MFG # 5A00007
SER # 720275940415653B
The switch controls High,Medium,Low Speed and Off.
4 Wires--Black,Brown Purple and Gray are connected to awitch, they come from a Block Capacitor (4.5mf,6mf and 5mf)
This fan was purchased around 1995 and is in good condition but needs this replacement switch---
Where can I get the replacement for this model?
Apr 19, 2009 | Hampton Bay 24002 Ceiling Fan
Can't figure out how to reverse the Hampton fan with the remote
I have the Hampton Bay Windward II Ceiling Fan SKU 523-127. I have replaced various parts over the years including the ballast, light shade, 9" 30 Watt Circline bulb and the remote.
Hampton Bay Windward II Ceiling Fan SKU 523-127 was sold by Home Depot, and manufactured by King of Fans.
King of Fans website is: http://www.kingoffans.com
This fan can be seen by clicking on Products --> Ceiling Fans --> Click on page 9 (at the bottom of the webpage) then click on the Windward II fan picture, then you will be able to click on Download Owner's Guide.
Mar 11, 2009 | Dryers
Ceiling fan does not reverse with remote
Just reporting that I called Hampton Bay about the remote not working to reverse the fan. I was told that I needed to have the fan running on low and then press reverse on the remote control. If that doesn't work, customer service told me to press reverse while running the fan on medium. (Some fans are set to reverse on low and others on medium.) Nowhere in the manual is this addressed. I had been pressing reverse with the fan turned off, which seemed to me a logical thing to do. Live and learn.
Aug 25, 2007 | Hampton Bay 24750 Huntington III Ceiling...
Hampton Bay 52 In. Brushed Nickel Romano with Integrated Pan Style Light Kit Fan Logo
98 people viewed this question
Top Hampton Bay Dryers Experts
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
