Question about Maytag Centennial 7.0 Cu. Ft. Super Capacity Plus Electric Dryer
Hello, I just purchase the dryer on april 3 of this year and went to use it and the drum would not go around, my husband took it apart and the belt is off , but unsure how it goes back together. Do you know where we could ge a manual or do you know how to put it back?
  • Maytag Master
  • 12,061 Answers
How to replace belt on samsung dv218ae
Hello & Welcome to FixYa
Please follow the step by step instructions for belt replacement given in this video:
Please get back to me if you have any other questions.
Kevin
Aug 07, 2011 | Samsung DV218AEW Electric Dryer
I took the dryer apart and lubercated the belt and now I cant put the belt back on. How do I do this?
Hi buttcrackplu...
The belt will go around the drum,around the motor and idler pulleys....
Go to this webpage to see how the belt is routed.
Free Answer.,..Please rate me
http://www.applianceaid.com/images/belt-config.JPG
Apr 18, 2011 | Maytag Neptune MDE4000 Electric Dryer
Changing dryer belt on kirkland/whirlpool dryer took apart dryer but dont see where belt suppose to mount.
Hello. The belt goes around the tub and the tension pulley. In fact, it is always a good idea to replace both the belt and the idler/tension pulley at the same time. J.
If you want a schematic go to searsdirect.com and enter your model number. J.
Jun 27, 2010 | Whirlpool LER4634J Electric Dryer
Putting on belt
put it around drum,then around motor pulley, then idler pulley with spring attached to, move it forward and slip belt onto idler pulley and release and belt should become tight,then self align belt by manually turning drum before putting unit together
Sep 13, 2009 | Crosley CDE6000 Electric Dryer
Dryer takes three cycles to dry took apart need help put back together
Model #?
If this is a standard dryer with the idler pulley, place the pulley into the slots to the left of the motor pulley. Bring the belt through the idler so it is running on the flat side of the belt and place the belt around the motor. The idler should be placing down pressure on the belt keeping it tight. make sure there are no twists all the way around the drum or it will pop off.
Eric
May 28, 2009 | Kenmore Dryers
My dryer is sqeaking loudly when running
Squeaking usually comes from drum roller supports and/or the belt idler pulley needing lubricated. If the drum does not have drum roller supports under the drum, it will be equipped with a plastic drum glide the is located around the perimeter of the front drum facing. If this plastic wears down it will cause the drum to scrape against the metal bulkhead and make noise. If equipped, you need to replace the drum glide
The drum rollers (if equipped) can be lubricated with a light weight turbine oil (like the kind you would lubricate some ceiling fan motors with). Lubricate the roller wheels at the axle ONLY. Do not lubricate the wheels. The same is true for the idler pulley. Make sure you don't get any oil on the belt, or it will slip.
If you need instructions on how to reinstall the drive belt, repairclinic.com has dryer belt diagram illustrations under their "Repair Help" section. Look for the "Dryer Belt Diagram" link on the left hand side of the page. If your dryer is a GE model, you would use diagram M, D, or L (depending on the age of the dryer).
If you have questions, let me know. I hope this helps you.
May 06, 2009 | GE 7.0 Cu. Ft. Super Capacity Gas Dryer
Husband took car apart to fix water pump
IF ITS A SUPPERTINE BELT THE TENSION ARM NEEDS TO BEE ON TOP OF BELT ITS SPRING LOADED LITTLE SQUARE HOLE IN IT MAY TAKE 3/4 OR 1/2 INCH RATCHET
Apr 05, 2009 | 1993 Chevrolet Lumina APV
Our kenmore dryer doesn't spin
thats your belt and it may have slipped off the pulleys underneight
Dec 04, 2008 | Dryers
Putting dryer back together
from front with belt around drum ..gather slack and push under idler and around motor pulley right to left...recommend doing it before reinstalling front place rollers on front panel under front lip of drum and lift ..easier than trying to reach under front panel and will a little more slck in belt
Sep 13, 2008 | Kenmore 63012 Electric Dryer
Broken belt
remove top first, then front just a few screws,then put belt around the drum and pulley and reassemble,bye.eire
Dec 03, 2007 | Kenmore 63942 Dryer
Open Questions:
See all Maytag Centennial 7.0 Cu. Ft. Super Capacity Plus Questions
Maytag Centennial 7.0 Cu. Ft. Super Capacity Plus Electric Dryer Logo
108 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
