Question about Minolta DiALTA Di250f All-In-One Laser Printer
Co500 the copier fail to operate and gives out this code co500
  • Minolta Master
  • 6,161 Answers
First check the right side cover where the image unit is located. Check the two latches that latch that door are not broken especially the rear one. Then get a paper clip and stick the clip in the small hole on the right side of the control panel it will touch a switch. The control panel with go thru some screens when you see the screen with copiers on it on the left side of the screen in the middle you will see a small "." when dot appears touch 3 button. Then the machine will continue to the code screen. Press the utility button should see a new button "Maintenance Mode" touch it then touch trouble reset. The machine will again go thru screens will see the"." again do nothing. Should go ready to Copy. If the code comes back do not reset you are messing with the Fuser the Hot part continue reset without a technician looking at and or replacing it can catch on fire that would ruin a perfectly good day
Posted on Mar 01, 2015
How to remove error code with co500
my dear panel side smal hole give pin hole your codes reast
May 26, 2014 | Minolta Di251 All-In-One Printer
Error co500 cspro ep3000
open front door to your left a small access cover remove the screw press the trouble reset button. if the code comes back have a konicaminolta tech look at it, continue reset may start a fire you are resetting code for the fuser the hot part of the copier
Oct 13, 2011 | Minolta EP4000/5000 CS/PRO Copier
Sir my problem is start machine in warm up complete to display error red blink in code co500
The fusing unit malfunction code.Clean and measurement the continuity of the heater lamp,thermistor and thermofuse.To reset press the service button.Please tell me the copier model for more information.
Sep 25, 2009 | Konica Minolta Office Equipment & Supplies
Malfunction detected, code CO500 on our printer, model Di251.
my di2010 has a co500 code on it after someone tried to run a transparency thru it.
Jun 25, 2009 | Minolta Di251 All-In-One Printer
I have a konica 7218 with a co500 error
Hello sir; Just need you to reset, turn power off thenhold down "stop" key while you turn on the power.
Jun 08, 2009 | Konica Minolta Office Equipment & Supplies
Error CO500
On the right side of cotrol panel there is small hole press it with clips .On the screen appear small dot press it then press 3 then apear screen chose from it troble reset .
Mar 30, 2009 | Konica Minolta DiALTA Di200 Copier
Error CO500
This error code indicates low temperature at warmup.Can somestime be reset IF you can find the reset switch.On earlier models it was behind a small panel on the innards of the machine after you open the front door.Good Luck!
Mar 30, 2009 | Minolta Di3010 Copier
IMAGISTICS 2620 Error code C0500
How to reset malfunction code C0500 of a imagistic
Feb 03, 2009 | Konica Minolta DiALTA Di200 Copier
Minolta Di351 Dialta
Try shutting the copier down and then unplugging it from the wall for 15 minutes.
If this does not reset the device, a technician is required.
Jun 10, 2008 | Konica Minolta DiALTA Di200 Copier
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
