Question about HP LaserJet 1200 Printer
HP laserjet 1200 printer
My HP 1200 series printer,over time is now not responding,when I ask it to print,the print queue just shows error?if I perservere for 30 minutes eventually the printer will respond and print.
    Scholar:
  • 94 Answers
The system of your printer are abnormal funtioning becuase of the over time use or massive printing and the chepset of the board are overheat that's why you need to turn it Off to relaxe the device inside the printer. The best solution for that is to replace the chepset but you did not buy the chepset for that printer, it is because only the HP Company can make that kind of chepset. But if you have un-used of same printer you can also get the chepset and try to put it and replace the chepset of your printer.
Posted on May 26, 2010
  • HP Master
  • 4,737 Answers
Upgrade your ram and clean the registry. this will fix your problem, generally almost all this problem's related to Memory, so first upgrade your Ram to at leat 512, i recommend 1 Gb. Good luck.
Error 49.33.03
First turn off the printer and then delete the job held at the computer in the print queue. Then turn the printer back on. The error should go away. Try printing the document again to see if the error returns. Normally a corrupt print job causes this issue. If the error appears with no jobs being sent to the printer then the formatter board is most likely bad.
Mar 10, 2014 | HP Color Laserjet Enterprise Cp5525n...
49 server error
49.xx.xy error- General firmware error ( like a blue screen in windows)
a corrupt print file is usually the cause and can be cleared by disconnecting the printer from the network, then cycle the power , allow the machine to come to ready and ask the pritner for a configuration page( just a test to see if the printer is able to respond- if not then replace formatter/firmware chip) when this has finished printing goto the workstation that sent the last files to the printer and clear ALL print queues form the PC then and only after clearing the print queues can you re-connect the network - failing to clear the print queue will cause the printer to re-try printing the corrupt document which will result in 49.xx.xy error being displayed again.
Dec 28, 2013 | HP LaserJet 5200 Printer
There is an error code on my HP LaserJet P3015 which reads 49.4C02 ERROR
HP LJ P3015 with 49.4c02 error - tried lots of things in the end went into printer driver right clicked and then clicked troubleshoot - windows came up with a fix dont know if it is permanent - troubleshooter said a print job was deleted from the print queue. Presume the printer tries to print the problem job in the queue each time it is switched on.
Oct 10, 2013 | HP Laserjet P3015X Printer
How to clear error code 49.4c18 on HP laserjet 4250
any 49.xxxx codes are related to firmware crash.
the probable cause is a corrupt file in the print queue. remove the printer from the network then after network is disconnected - cycle the power on the machine ( switch off then wait 10 seconds switch back on)
the 49 error will probably clear . if so Clear All print jobs in Print queue on the computerr workstation. then reconnect printer and away you go!
if however the error remains then you will need to Upgrade the firmware or replace the firmare chip/formatter ( unlikely I've only ever replaced one out of thousands of calls for this fault)
Nov 04, 2012 | HP LaserJet 4250n Printer
49.2f9d error hp laserjet 3005dn how to solve the problem
Most times a 49.xxxx error on an HP printer is caused by either the print driver, firmware or the print job itself.
If it happens when printing a PDF file try sending the file to the printer as an image.
Upgrade the print driver and the firmware.
You may need to disconnect the printer from the pc or network, power it off and pull the plug for a couple of minutes to clear the error.
If it's a network printer it would be a good idea to check the printer queue for any jobs still in it and delete them before powering the printer up again.
Dec 14, 2010 | HP LaserJet P3005 Printer
Hp laserjet 1200
If you want the printer driver for your HP printer then -
You can download the HP printer drivers from their supportWEB site. Please click on this link and select your model printer to download:- http://welcome.hp.com/country/us/en/support.html
Dec 09, 2010 | Office Equipment & Supplies
Printing stops halfway through document
This is a memory problem, it clears when you switch it off because it clears the RAM. You need to add more memory, or better still buy a new Canon. :>)
Jun 18, 2017 | HP LaserJet 1200 Printer
Print Job enter's queue, but doesn't actually print.
hi thanks for using fixya!
Do you have 32bit or 64bit system?
Mar 24, 2009 | HP LaserJet 4250n Printer
Hp laserjet 1200 series
Remove the DIMM and reseat it.
If the printer still has an error, replace the DIMM.
Unplug the power, reseat the paper tray, and reattach the power cable.
Oct 20, 2008 | HP LaserJet 1200 Printer
Unable to communicate to a 1320n laserjet printer
unistall the driver completly and install again so after that click shared printer and them try it
Sep 25, 2007 | HP LaserJet 1320n Printer
HP LaserJet 1200 Printer Logo
168 people viewed this question
Seeker5211
Seeker5211
