Question about Refrigerators
My Amcor fridge has a broken door gasket. Do you sell them or know where I could get a replacement?
  • c_mboya May 26, 2010
    Where can i buy the gasket???????
  • Refrigerators Master
  • 4,737 Answers
Yes you can get the spare from the repairing shop. If you let me know your current location, I can give you the contact number for one of the service center. Thanking you. Awaiting your reply.my Amcor fridge has a - 9187a76.gif
Posted on May 26, 2010
I NEED A NEW GASKET FOR FRIDGE DOOR
Fixya does not sell replacement gaskets. Suggest you check with a local appliance parts supplier.
Aug 21, 2016 | Hotpoint Refrigerators
Replaced freezer gaskets now not sealing well
Jay, Check to see if hinge can be adjusted so door closes tighter, may be a faulty door seal, or maybe it needs manipulated to soften, shape, stretch it to seal better. You can try the dollar bill trick between the seal and fridge to locate the problem/leaking spots. The bill should not pull out with out there being a little force, no force means seal is not proper in that area. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How To Check The Seal On Your Fridge And Oven
How To Test And Replace Bad Refrigerator Gasket
How to Fix Gaps in Refrigerator Door Gasket
How to Check Freezer Door Seal DoItYourself com
Aug 20, 2016 | Refrigerators
Why is the temperature erratic in my compact fridge?
Check the door gaskets. Close a dollar bill between the door and the gasket and pull out slowly, little or no resistance means the gasket is leaking at that location. You need to test it all the way around. Adjust as required, if its broken or distorted in some areas, replace it. If gasket is OK, check that the thermostat are is clean and clear so air flows around it easily. If that's OK, most likely you have a bad stat.
Mar 20, 2015 | Refrigerators
I had a power failure and my amcor fridge/freezer, with 3 stars, was off for 17 hours. Is the food still safe to eat(meaning if it defrosted and got re-frozen
If the food defrosted then no its not safe to re-freeze, but if the door was kept close then it should of maintained a frozen state.
Mar 02, 2011 | Amcor Refrigerators
The door liner is cracked and broken the the fridge works great i would like to replace it where do i get a new one
Door rubber gasket is available with any fridge dealer retail shop. And also easy to replace.Below the gasket there are screws. Unscrew and fix new rubber gasket after removing existing one. If you can't call repairman. Matter of 2 to 3 hrs job. Thanks.
Jan 23, 2011 | Refrigerators
The seal on the door of my Ariston fridge/freezer has gone. Part Number BC 312 AL. Can you tell me how much a replacement would cost and how long to deliver to France. Thankyou
You will have to find an appliance parts retailer that sells those refrigerator gaskets. Fixya does not sell parts, i dont think
Sep 27, 2010 | Freezers
Top lock on GE Profile Fridge is broken
bad news you have to replace the door gasket
they only sell them in pairs and not cheap
Jul 03, 2009 | GE Profile PFS22SBSS Bottom Freezer French...
I want to remove door handle to replace broken fixture.
I think you may have to remove the door gasket, if you look behind the gasket you will see the screws holding it and the inner door liner in place, both should be removed and you will then have access to the handle screws from within the door.
May 27, 2009 | Westinghouse WRS6R3EW 36" 25.8 Cu. Ft....
THE REFRIGERATOR FREEZER DOOR STAYS SHUT BUT THERE IS NO SUCTION AND I AM GETTING ICE CRYSTALS INSIDE THE FREEZER. WHAT COULD THE PROBLEM BE?
there is some thing wrong whit your door gasket, check your door gasket all around and see if is seal properly, if is broken there is places than custom make fridge gaskets. if by any chance you tuck your doors a part, may be than you dint properly adjust the door or you are missing a shim if so.
use some coins to adjust the hinges. buy placing in between the fridge body and the hinge.
place a piece of paper on the fridge and close the door it shut hold the paper all the way around the door.
Good luck :)
Apr 06, 2009 | Hotpoint RLA50 Refrigerator
Refrigerators Logo
21 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
