Question about Car Audio & Video
I have a 2001 ford expedition and it had been making a humming sound while the running and then for a few minutes after being shut off. Eventually the fuel pump had went out. Immediatly after replacing the fuel pump with a brand new one I tried the car and it was still making the humming sound. The car ran fine but the gas gage was registering wrong. It ran fine for a few months but now has began kinda hesitating when Im accelerating kinda like its not getting enough gas, after doing this and increasingly getting more and more frequent my check engine light came on and it read misfire on cylinder 5. I had plugs changed about the time the pump was replaced and also I changed the fuel filter, at that time as well. After haveing the code read the check engine light went off and has remained off but every now and then the car will do the hesitating thing. Any suggestions on what maybe this could be??
  • 6,927 Answers
The humming noise it not good,if the whole assembely was not replaced,you may have to replace it as an assembely,instead of just the pump,now,if you did put the whole assembely in,then it is defective,and you need to replace it.Also,fuel injection cleaner might help with this situation,try lucas,to as little fuel as possible for a consentrated effect,it will clean the injectors better and quicker.
Posted on May 26, 2010
1998 ford expedition shut,s off when driving and no code,s
sounds like fuel pump is ready to fail. first check and or change fuel filter. if truck still shuts off then time to test fuel pump. first see if it is running by taking off gas cap and turn on key just one notch short of starting truck. if you hear a hum then your pump is working. but then you may have low pressure. if so then your fuel pump needs replaced. I just did this. its about a 4-6 hour job. go to youtube they have a good step by step video on how to do. good luck
Feb 27, 2015 | 1998 Ford Expedition
2001 ford expedition wipers are making a sound but not moving
like the motor running but no side to side movement?.. look at the base of the windsheild( through the vents) and see if the connecting arm is working or not.. it may have broken loose..
Feb 12, 2013 | 2001 Ford Expedition
Starts fine when cold but after a few minutes shut it off then wont start unless u pump the heck out of it then black smokes comes out tailpipe
Sounds likes burning to rich..did ya get any codes out of it...A bad engine coolant sensor can make it do that..or a mass air flow sensor..Need to try and get the codes out of it..Try and disconnect the mass air flow sensor ..It might not idle but it should clear up and run..
Sep 04, 2011 | 1999 Ford Expedition
99 ford expedition runs fine when u first start it but when u shut it off it wont start kinda wants to if u hold gas pedal to floor
could be fuel pressure regulator or throttle position sensor,check them first,make sure your getting fuel to motor
Aug 21, 2011 | 2001 Ford Expedition
Back end of my 2001 Ford Expedition FWD, Eddie Bauer, was dragging. Had diagnostic test run and found out it needed a new air ride compressor. Had compressor installed, but compressor continues to run...
The compressor should only run until the rear suspension reaches the desired height. If it continues to run after the suspension has raised to ride height then you may have a leaking air bag/solenoid or line. If you dont have any leaks it is possible the EVO(air suspension module} or relay is at fault.
Nov 14, 2010 | 2001 Ford Expedition
Humming sound coming from Gas Cap - stops when open gas cap
do u have a check engine light? have you tried replacing the gas cap, the vent valve located in the gas cap may be the cause of this.
Apr 08, 2009 | 2000 Ford Expedition
2001 Ford F-150 Dyes in traffic id outside temp is above 70 F
heat build up causing spark system to break down
tell tale sign is highway drive is fine (plenty of cool air under hood)
you may have spark module prelim failure
it'll only get worse eventually it won't run but a few minutes
Mar 12, 2009 | 2001 Ford F150 Styleside SuperCrew
The heater do not work in my 2001 ford expedition
sounds like your thermostat is not working (stuck closed). if the hose on top is soft after several minutes of engine running this is definitely the problem. good luck
Feb 21, 2009 | 2000 Ford Expedition
Car Audio & Video Logo
22 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
