Question about Sewing Machines
How do I thread tcm sewing machine - Sewing Machines
  • 27 Answers
SOURCE: Brother Sewing Machine model:CS8150 bobbin thread problems
The top of the machine is not threaded correctly. First raise the presserfot then rethread the machine. Bottom looping is usually caused by a lack of top tension. There could allso be a bur on the hook.
Posted on Feb 23, 2008
SOURCE: threading a sewing machine
What do you mean you are unable to pull the bobbin thread through, elaboration would help solve the problem...
I suspect I'm having the same problem with you if it's anything to do with the top thread looping around in the bobbin holder.
Damn machine!
Posted on Feb 26, 2008
  • 323 Answers
SOURCE: Threading my sewing machine
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} all machines thread the same. TTN tension, take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
Sewman7
Posted on Aug 27, 2008
Michaelle
  • 65 Answers
SOURCE: need help to thread our sewing machine.
you really must get a manual for this machine.
You can find manuals online for a small price.
At one time some sites had them for free, but I haven't been able to find many recently. sewusa.com has some older ones for free. but not many. you could try the kenmore site as well, if not I'd try to search on dogpile.com (sewing machine manuals)
Just so you know, your manual is the MOST important tool for any sewing machine, and its worth a couple of bucks to get it.
Posted on Jan 24, 2009
  • 980 Answers
SOURCE: Threading a HG Palmer Princess sewing machine
I can help you if you can email a picture with your email address, your machine is not a recognised make drivewithken@blueyonder.co.uk
Posted on Oct 25, 2009
How to thread a bobber model SE 200JjoAnnSewEssential sewing Machine
The thread will now go downward on the left side of the take-up lever.
  1. Locate and thread any thread guides, leading down to the sewing machine needle.
  2. Thread the sewing machine needle. Hold the thread with your left hand and turn the hand wheel.
  3. Watch for any thread to flap around.
Step-by-Step Guide to Threading a Sewing Machine - The Spruce.
or go to this link. How to thread bobbin Essential sewing Machine Google Search
Oct 26, 2017 | Sewing Machines
After threading the machine, start to sew and the thread breaks it seems that it gets caught in step 4 in Threading The Machine in the manual.
Not knowing the make & model of the machine limits out ability to help. What is Step 4? When threading the top thread, ALWAYS RAISE the presser foot. Verify that the thread path is correct--mis-threading is a frequent cause of broken thread.
Sewing Machine Problem 1 Thread Breakage
Sewing Machine Thread Keeps Breaking
Why Is My Thread Breaking How to Avoid Thread Breakage at Your Sewing...
Mar 16, 2017 | Sewing Machines
I need a picture to thread my sawing machine
What machine?
https://www.bing.com/images/search?q=thread+sewing+machine+diagram&qpvt=thread+sewing+machine+diagram&qpvt=thread+sewing+machine+diagram&qpvt=thread+sewing+machine+diagram&FORM=IGRE
Sep 29, 2016 | Sewing Machines
Why the thread cracked with when i sticked with the machine
Thread breakage could occur for several reasons.
First, try a brand new needle.
Second, use only good quality thread--NOT old thread or bargain bin varieties.
Third, when threading the upper thread, be sure to ALWAYS RAISE the presser foot throughout the threading process.
Verify that the thread path is correct (consult the owner's manual). Incorrect threading will usually break the thread.
Check that the upper thread tension is set at the midway point between the high & low numbers.
Why Does My Top Thread Keep Breaking Sewing Machine
NMSU Checklist of Common Machine Troubles
Why Does My Thread Keep Breaking While Sew
Aug 27, 2016 | Brother ES2000 Computerized Sewing Machine
I need to know how to thread my tcm sewing machine as i have no instructions as it was given to me thank you
I do not know this model but why don't you visit www.about.sewing.com, there is good general threading information there as well as care and maintenance tips for sewing machines. Older machines need oiling, many modern ones have nylon parts or oiling wicks so not required so often. If you can see red marks on parts of the machine, these are usually oiling spots.
sewing machines are usually horizontal top loading bobbins where the bobbin goes into a bobbin holder and the thread gets clicked into a tension spring.
Or vertical front loading bobbins inside a removable bobbin case with a tension spring on the outside of the bobbin case.
Top threading up is usually through a number of eyelets, through a tension device of some sort, then down to the needle.
Remember, the scarf (cut out) of the needle should face to the back of the machine. Most domestic sewing machines use 130/704H needle system and the needle has a flat shank which goes to the back in the needle holder so you get this right.
You can also try www.sewingpartsonline.com or www.sewusa.com, both list some instruction manuals and threading diagrams for some makes and models.
Apr 26, 2011 | Sewing Machines
Threading a sewing machine
Damn machine!
Nov 07, 2007 | Janome Mini Compact
Sewing Machines Logo
352 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
