Question about Pix FUJIFILM Fine S1500fd Digital Camera
Reading errors on the card, crupt files / images.
    Brigadier General:
  • 11,967 Answers
Download any pics from the card using a card reader if necessary. Then, format the card in the camera.
Posted on May 26, 2010
Pentax K20D error message Camera cant display this image. And images are wiped from memory card.
One or more of the image files are corrupted. This can happen when the camera batteries fail at an inopportune time (while a file is being saved, for instance), when the SD card is removed from the computer without being ejected, or when the files on the SD are manipulated (such as rotating it) on the computer and then returning the card to the camera.
Even though the camera may not be able to read or display these files, I have found that sometimes the computer is still able to. Before giving up on all the images, try them in a computer both via one or more card readers or directly in an SD card slot.
If all else fails, you can reuse the SD card by formatting it in the camera.
Jul 29, 2013 | Pentax K20D Digital Camera
My memory card keeps saying error what is the matter
- First identify the type of card, some memory card has lock or adapter. - Second, check the condition of the card.
  • Locked switch position
  • Visible discolorations or defects such as crack or nick in the card
  • Missing contacts at the end of the card
  • Deep scratches in the card contacts
  • Heat discoloration on the card
- Next, sure that the file format of the picture is supported by your printer - Then, try to save the file on your computer (If the computer can't read the memory card, the card might be causing the problem, you might contact the manufacturer of the card or replace the card) - If you successfully save the file on the computer, try other device like camera etc. - Format the memory card and try to capture an image and check if the file is corrupted or not. - If an error 'Unsupported Image File' appears, the memory is defective. try replacing the card or contact the manufacturer for further troubleshooting. - If the image displays properly, reinsert the memory to the printer. If the same error appears again, try using another memory card. - If the new memory card has the same issue try the steps provided above. And if the same error appears again after doing the steps call HP support to service your printer.
Apr 10, 2011 | HP Photosmart 8450 InkJet Printer
PNY Optima SD HC Card cannot be read in HP Photosmart 8150 printer.
  1. Verify that the printer is turned off.
  2. Remove the Secure Digital memory card from the printer.
  3. Examine the Secure Digital memory card:
    • Is the lock switch in the unlock position?
    • Are there any visible discolorations or defects such as crack or nick in the card?
    • Are there any contacts missing from the end of the card?
    • Are there any deep scratches in the card contacts?
    • Is there any heat discoloration on the card? NOTE: If all of the above questions result in No , proceed to Step 4.
  4. Check if the HP Photosmart printer supports the file format. NOTE: In order to know which file formats are supported by the different HP Photosmart printers, please refer to the manual of your printer.
  5. (Saving the pictures on the PC, if possible) Insert the Secure Digital memory card in the camera (or another device) and format it following the proper instructions to perform it.
  6. Capture an image.
  7. Review the image. If the image is corrupted or an error such as Unsupported Image File is displayed, the Secure Digital memory card is suspected to be defective and should either be replaced or referred to the manufacturer for further troubleshooting.
  8. If the images are read properly, turn on the printer. Insert the Secure Digital memory card in the Secure Digital slot.
  9. If the printer display continues to show the Card Not Recognized error, try using another Secure Digital memory card, if one is available.
  10. If the printer is still unable to read a functional and compatible Secure Digital card, contact HP to obtain additional troubleshooting information.
Oct 05, 2010 | PNY 4GB Secure Digital High Capacity...
I cannot play back images in my Sony cyber shot camera.
Please provide more information.
1. Does it have that error all the time and is unable to play back ANY images? Or does it say that for only some images?
It sounds like a corrupt memory card affecting one or more images that are not in the correct format for the camera to read it.
2. Did something lead up to this condition?
For example did anything happen to the camera? Was it dropped, got wet? or someone was messing with the memory card taking it in/out/in/out while the left sitting around?
Here are some potential solutions.
Sorry it's not a really short solution but there are several things that can cause this.
1. Re-seat the memory stick. So remove it and put it back in.
It should go in smoothly and all the way. See if it works then.
2. Try a different memory stick, take a photo or two and see if it plays back.
3. Erase the offending file.
A File Error can be caused by taking a photo with really low batteries and the camera shuts off halfway through saving the photo generating a corrupt file.
It often won't get over that on it's own so you have to use a computer to erase the offending file.
3. Fix corrupt card by reformatting it.
You could use a USB flash card reader (or connect the camera via USB) and retrieve your photo's to the computer so you have them. Then reformat the card and it's often OK again at that point.
If the problem comes back it's probably a faulty card.
Other causes:
A File Error can also be caused by loaning out the memory card and someone put it in a different camera for a while. Then when you get it back it can't read the new files on it. In that case use a computer to remove the extra files or backup your files and reformat the card.
Use the camera to format the card because Sony likes to do things their own way and they don't play well with others (with regard to compatability of batteries, memory cards, cables,,,etc) Their products don't fit or work with other company's products.
One Last check you could do is use a memory card reader (or the camera via USB if it mounts the card as a drive letter) and run a full Windows CheckDIsk on the card, to test it for errors.
Jul 25, 2010 | Sony Cameras
China mobile memory card problem
scan your memory card with an antivirus or else take back up your datas and format your memory card and if still not working .reset phone settings.
Jul 28, 2009 | Nokia N72 Cellular Phone
Error message on Nikon D40X camera
Yes, This happens to me if I change the file in any way, but don't take it off of my SD card. .So if you crop it or rotate it or anything, it's changed the file and won't be able to read it the same way. If you just "move" the file (on your computer) to a file, it won't be there any more. Hope that helps...
Mar 28, 2009 | Nikon D40x Digital Camera
Card read error on the digital picture frame - brand new. I bought this 7" digital photo frame from argos and I insert the SD card whilst the device is turned off, when I turn it on the message reads...
Put the card back into the camera and off load/take off your pictures (Put them on the computer). Then, put the card back into the camera and go to your options menu. Find the format feature, and format the card. Take some new pictures and then try putting the card back into the picture frame. Does it work? If so, transfer the images from your computer back to the card. If it continues to work, then Great! If not, more than likely there is an improper or corrupt file among your photos.
Good Luck!
Dec 12, 2008 | PANDIGITAL 7" Digital Photo Frame With...
Card error
For the image file numbering problem: Go into the setup menu and set the numbering option to "renew" instead of continuous. For the card error: use the setup menu and format the card in the camera. This will erase everything on the card, so you will lose your video files, unfortunatly.
Oct 11, 2008 | Fuji FinePix E500 Digital Camera
File crupted repair
Insert your Windows XP install Disk and reboot
when it asks if you want to repair or install windows pick INSTALL. it will then search for previous installations and find yours.
At this point you press R for repair, it will reair your entire installation of windows, leaving your prgrams and files intact.
Be careful though, as the wrong choice could wipe your drive, although you are given many dire warnings by the installer before you do this, so if you read and pay attention you should be safe.
If my solution was helpful please vote for me!
Nov 16, 2007 | Computers & Internet
Pix FUJIFILM Fine S1500fd Digital Camera Logo
73 people viewed this question
Top Pix Cameras Experts
JonSnell Electronic
JonSnell Electronic
Mister Danger
Are you a Pix Camera Expert? Answer questions, earn points and help others
