Question about NEC NP300 LCD Projector
How to connect Dell Inspiron 510m to NEC NP305?
How do you connect a Dell Inspiron 510m to an NEC NP305 projector? I work with a variety of projectors and this is the only make that I cannot get to work with my Dell. Although my laptop screen flicks to black when I press Fn F8 as if it is going to send through to the projector, the projector will not pick up the signal. I've tried the usual advice of connecting all the cables and switching on the projector first, then the laptop - have also tried vice versa - but it doesn't make any difference. Any help much appreciated! Thanks.
  • Brett Duxbury
    Brett Duxbury May 06, 2017
    Hi hilarymaclea, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    did you select the appropriaite source on the projector ?https://www.manualslib.com/manual/297864...
5 Suggested Answers
Benimur
  • 6966 Answers
SOURCE: Sanyo Projector==No signal
Hi, Perhaps you can try lowering the screen resolution first of the laptop before plugging in the projector and then the Fn + F8. Thereafter, gradually increase the screen resolution until projector stops displaying. The idea is that your current screen resolution maybe too much for the projector to handle. This of course is assuming that there is no hardware problem with the projector. Hope this be of some help/idea. Post back how things turn up or should you need further information. Good luck and kind regards.
Posted on Sep 14, 2007
SOURCE: I cannot ger the projector to project the image on the laptop. I have held down the Fn Key and F8 to no avail
go to the control panel. Personalization and select the second screen. That usually works for me.
Posted on May 13, 2008
maklean
  • 1665 Answers
SOURCE: nec gt5000 projector turns off 10 seconds after power up
It;s power supply circuit seem to be faulty.
Posted on Sep 13, 2008
  • 6 Answers
SOURCE: Nec projector not coming on
Yep, there is a switch that enguages the lapm cover is opened, put the lamp cover back in place and the status blinking red light will stop, and projector will be ready.
Posted on Aug 07, 2009
How to connect dell laptop to nec mt 1050
what model laptop you have
and if your laptop support VGA connection then you can connect it to your projector
Mar 15, 2015 | NEC MultiSync MT1050 Multimedia Projector
Color of projector output weird
Have you checked the cable (connectors) for good contact.
Mar 14, 2014 | Dell Inspiron 6400 Notebook
What do I need to connect between my Mini Dell Inspiron to my LCD projector
That netbook has just a VGA output so only a VGA cable will work - your projector must have a VGA input, check that since very few new ones still have it.
Jun 26, 2011 | Dell Inspiron Mini 10 Notebook
Cant get it to work with laptop
power ON your projector and laptop
connect your laptop and projector with VGA cable and press
if your laptop PANASONIC or NEC (Fn+F3)
ACER, HP,SHARP,TOSHIBA (Fn+F5)
LENOVO, SONY (Fn+F7)
DELL, EPSON (Fn+F8)
FUJITSU (Fn+F10)
APPLE (F7)
If problem exist remove the VGA driver in your laptop and reinstall the correct driver not a standard display driver
Feb 09, 2011 | Panasonic PT L720U Multimedia Projector
The nec vt575 shows an image on the projector but not from laptop
this is very simple, its just a matter of a bios upgrade for your laptop
Mar 23, 2010 | NEC VT575 Multimedia Projector
PINK PROJECTOR SCREEN DELL B130
Generally, a cable connection or cable issue. not all the color signals are making it to the projector. Try reseating the cable connections on both ends. If no changes, then try another vga cable
Mar 18, 2010 | Dell Inspiron B130 Notebook
DLP Projector connection to Laptop
you need to go to te control pannel and go to display settings then manually select the external monitor then hit apply it will open on your projector
Nov 02, 2009 | Office Equipment & Supplies
How do I connect to my projector
If your dell is equipped to do this it is on the back side and appears as a video card connector or s-Video out. It is possible that your Dell is not equipped to make this connection, I have found a few that are not.
Oct 12, 2009 | Dell Inspiron 1300 Notebook
Dell 2400MP out of range with vga connection
make sure that the resolution matches and that the laptop and the projector are both on vga and not composite. you can also reset the projector settings to factory default to start from the beginning.
Aug 18, 2009 | Dell 2400MP DLP Projector
Get a laptop to talk to projector
  1. Are you using the SVGA connector on the laptop or the S-Video?
  2. If using the SVGA (normal computer monitor connector) then you have to "toggle" the proper Function Key. e.g FN+F5 on my laptop to change from internal LCD to external or both.
Mar 25, 2008 | Dell Inspiron 6400 Notebook
NEC NP300 LCD Projector Logo
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
