Question about Philips Televison & Video
My Philips 32TA1600 tv remains stuck in standby mode and won't come o. Re-booting the main power switch does not help
5 Suggested Answers
  • 195 Answers
SOURCE: Stuck in standby philips 32pw9523/05m
stand by.
Posted on Dec 07, 2008
praky16
  • 744 Answers
SOURCE: Dmtech TV is stuck in stanby mode
The problem IS PROBABLY BEING CAUSED BY A SHORTED POWER REGULATOR (MX084 ) OR AN OPEN FUSEABLE RESISTOR IN THE POPWER SUPPLY...
thank u rate me!!
Posted on Feb 12, 2009
ginko
  • 19396 Answers
SOURCE: tv has got stuck on standby mode
If the TV goes off completely, then is usually a faulty power board.
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Posted on Apr 29, 2009
SOURCE: problem sony tv kv2197 go on standby
You may try resetting the TV to the original factory settings. If the issue persists then service will be required.
Posted on Jun 27, 2009
How to come out of standby mode and Iconn1 Philips 42HF9442?
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Sep 09, 2016 | Philips Televison & Video
Emerson lc370em2 will not turn on just flickers
Hello Mike, seems you have a problem with your power-supply board....*or check if the tv switched back into standby mode..if tv switched back to stanby mode .....please check your A/V <Main proccessing Board...
Hoping to inform you correctly I remain,
Yours friendly.
Blessings.
Gladmar.
Mar 15, 2014 | Emerson Televison & Video
Philips HTS6100 -seems to be stuck in Standby Mode....won't actually do anything! Any ideas?
Your unit maybe on protect condition that why on standby mode,,,it means theirs a truoble in circuit inside that why happened...try to consult in the nearest service cnter or a wll trained technician,,wish you luck
Feb 19, 2012 | Sony Audio Players & Recorders
37PF9731D/10 - when turned on the tv power light remains green but no picture or sound. Just a clicking sound - like it does normally when swiching on from being on standbay. It reapts the attempt to turn...
The clicking sound is from the main power supply relay being turning on and off, it is driven by hte main board and it gets the power from the standby power supply board.
You need to check the main powwer supply board and the standby power supply board voltages.
Check the resistor in the main power supply board also
Please see my pictures here: http://s807.photobucket.com/albums/yy352/budm/Philips/Philips%2037PF9631D_37/
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Jun 16, 2011 | Philips 37PF9731D 37 in. HD-Ready LCD...
Projection TV Phillps 60PP9202/17F, bought 2004. Was watching and suddenly the picture went out. All connections are good and components work. Can you help?
Hi.
If there is no power at all, then it is either the power cord or power board inside the TV.
If after the fault the TV went in standby and does not wake up, then the TV is in protect mode.
In protect mode higher voltages from PSU gets shut down and TV remains in standby.(see also Why my TV does not start up and remains in...)
Try first leaving the TV power cord unplugged for some times, let say one hour or so. Then connect powr
If that does not work, and you keep having the TV in protect mode, it means that there is a fault.
In that case call the support number listed on Philips user manual to arrange repair.
If you are a technician I can try locating parts, service manual and giving more directions. Common faults that affect a Philips rear projections are convergence, PSU board, lamp and ballast assembly.
Regards.
May 28, 2010 | Philips 60PP9202 60" Rear Projection...
Tvs stuck on standby
Please can anyone help me, my tv switched off itself cant switch it back on. it is on standby mode tried everything in vain the model is Toshiba 28/32YT56
Oct 09, 2009 | Philips Magnavox 20MS3442 20" TV
TV will not go into standby mode
You may have to unplug the tv from AC power for a few seconds and then reaaply the power! Or replace the small signal board.
Sep 13, 2009 | Philips 42PFL5603D 42 in. LCD HDTV
NO POWER COMES ON THE TV 43PP8421 PHILIPS
It sounds like the main filter board is defective as thats the power supply board for your model.
Mar 25, 2009 | Philips 43PP9202 43" Rear Projection...
TV/DVD unit locked in Standby mode
Did you check the casing for a reset button (sometime it an itty ***** hole)
Hope this helps
Trap
Jan 25, 2009 | Bush DVD142RC 14 in. TV/DVD Combo
Televison & Video Logo
187 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
