Question about HP Photosmart C6180 All-In-One InkJet Printer
HP Photosmart fault Oxc19a0022 ink system failure what to do?
chiploon
  • 32 Answers
SOURCE: HP Photosmart C5180 will not read new ink cartridge
With reference to Expert Burti, he has given the solution to your problem.
"Just got off the phone to HP and the issue is resolved *phew*. This waswhat I was told to do for my C5180. First they told me to do a powerdrain. This is done by pulling out the power cable and then holding theon/off button for a minute, then putting the power cable back in (this didn't work).
Then we did a master reset. Unplug the printer, then pressing the help and ok buttons simultaneously plug it back in. This sorted it. :
Have to say it looked like this whole process used up shed loads ofink, so by the time I had finished I needed to replace 3 cartridges!
HP were pretty good and were very willing to send out a new printer if the reset didn't work (as the printer is still in warrenty). Hope you get yours sorted too."
With thanks from expert Burti.
Posted on Jan 02, 2009
SOURCE: hp 3310 photosmart - ink system failure 0xc19a0013
Ink may be new, but their nozzles may be blocked; depending on manner of storage. To be sure apply a folded tissue paper to the ink nuzzle and press firmly. If the tissue comes off well blotted with ink it means you still have a good amount of ink in it and the nozzle is not blocked. If not blotted or scantily blotted, it means ink is really low or nuzzle is blocked. To be very sure of this, place nuzzle in a plate/saucer with a bit water so that the nuzzle is soaked. Leave for about 10 minutes. Then apply the tissue again. If still not well blotted it means ink is really low or empty. If new you should return it for a replacement. In the case of blocked nozzles, the procedure may be repeated over to get results.
If this doesn't work let me know.
Posted on Dec 20, 2009
bhautesh1983
  • 402 Answers
SOURCE: Photosmart 7360-ink Ink System Failure error
1) Press * and # at the same time
2) Press 1, 2, 3 and “support R0632M” should display
3) Press > and “information menu” should display
4) Press > and “configuration menu” should display
5) Press OK and “hardware failure status” should display
6) Press OK “failure status: clear”. Press OK to clear
7) Press CANCEL
8) Press CANCEL
9) Press CANCEL
10) Turn printer off, unplug power cord for 2 minutes, and plug cord back in then turn printer back on.
And Thanks.
Posted on Mar 11, 2010
mediastormer
  • 135 Answers
SOURCE: hp c6380 printer; having problems with the ink system failure; ox
Follow steps below to reset Hewlett-Packard (HP) All-in-one Printers (products with keypads only). Resetting your printer will reset your printer to its original state.
For products with keypads on the control panel:
1. Without turning the unit off, unplug the power cord from the back of the product.
2. Press and hold “# and 6′ keys.
3. While holding those keys plug the power cord back in.
4. Wait until the screen goes blank before you release those keys.
5. Follow on printer screen instructions.
For Box-type models:
1. Unplug the power cord from the printer.
2. Wait for 30 seconds.
3. Plug the power cable back in the printer and turn it on.
Posted on Jul 09, 2010
SOURCE: what to do hp photosmart c1580 series ink system
hat to do hp photosmart c1580 series ink system failure Oxc18a0001
Posted on Oct 27, 2010
I am having problems with printing......this is error message on the printer screen Ink system failure......0xc19a0022
Hello and Welcome to FixYa!
The error
oxc19a0022 is mostly occurred in HP printers. To solve the error code oxc19a0022,Follow the given steps
  • Reset the printer without turning off the printer, disconnect the USB cable from the rear of the printer
  • Remove the cartridges from the printer
  • Wait for the 'Insert Cartridges' message to display on the control panel
  • Disconnect the power from the back of the printer
  • Now wait 60 seconds
  • Now reconnect the power If the product does not automatically turn on, press the Power button
  • Reinsert the cartridges, and then close any open doors on the printer.
  • If you receive a prompt to print a calibration page.Print it
  • Reconnect the USB cable to the port of the printer & then try printing again
Error will automatically remove.
But if u face still this error then printer service required.
In that condition best option is to Contact HP Service Provider
I hope this solution helps you
Thank you for using FixYa
Aug 27, 2011 | HP Photosmart 3310 Printer
Printer displays "INK SYSTYM FAILURE" error code
Printhead assembly needs to be replaced. call hp support. if printer is still in warranty replacement will be for free.
Jun 02, 2011 | HP Photosmart 3310 Printer
C6380 hp printer displays message: ink system failure Oxc19a0022 I have reset the system and then cleaned the printhead but the message persists
Try resetting the printer a second time. If you have done this step, unfortunately, you either need a replacement print head or the printer needs service.
Print heads are not returnable if a new one doesn't solve the problem.
You can order a replacement print head either by phone or by entering your printer's model and serial numbers here: http://h20141.www2.hp.com/Hpparts/Default.aspx?mscssid=7E679E4B5EF640FF85D318BA520F8C9A .
I wish that I had better news.
Mar 22, 2011 | HP Photosmart C6180 All-In-One InkJet...
Hp Photosmart Premium C309A INK SYSTEM FAILURE Oxc19a0022
When errors like this occurs, it is advised to reset the printer first before any other step(s) is taken;
Press *(star) and # (hash) together on the printer and let go.
Key 1 then2 then3
Press the right arrow key until the on screen menu shows System Configuration
Press OK
Press right arrow key until failure status is displayed
OK again.
Keep pressing cancel till you get back to the main menu then
Unplug from power for 1 minute then plug back in
Power back on.
Or
Reset the system by holding down the OK, Cancel, Black, and Color buttons down at the same time and turn the 3310 off. Keep holding the buttons down until the printer shuts off and the turn it back on. You will have to turn the printer off twice and then it will recalibrate.
If after resetting, the error still appears, the it means the print-head assembly or white pump gear in the printer needs to be replaced. But if your printer is still under warranty , replacement will be for free by HP.
Good luck.
Mar 15, 2011 | HP Photosmart Premium C309A All-In-One...
Hp c6380 printer; having problems with the ink system failure; ox
Jul 09, 2010 | HP Photosmart C6380 All-In-One InkJet...
What to do hp photosmart c1580 series ink system
May 01, 2010 | HP Photosmart C6280 Printer
HP photosmart 6188 Ink Failiure System
Not sure how to help you. Ink failure I would think is cartridge failure. Are you original virgin cartridges or refills? I need the actual error message that the printer is giving.
Nov 14, 2008 | HP Photosmart C5180 All-In-One InkJet...
HP Photosmart C6180 All-In-One InkJet Printer Logo
805 people viewed this question
Seeker5211
Seeker5211
