Question about Solid Audio Formula Series F27 2-Channel Amplifier Car Audio Amplifier
Which is best woofer for this mamp
Which is best woofer for this amp
Find macth wattage woofer to your amp.
Posted on May 27, 2010
I have 4 rsd65cs Phoenix gold 6.5 components 4ohm stable & 1 06S10L74 kicker I want to run it at 2ohm. A lil overpower is fine as I can always turn down.what is the best Option 5 channel amp? Thanks
sounds like you need to get a 2nd amp for the woofer, then bridge the two amps but be sure to adjust the output mode to lpf for your woofer and hpf for the 6.5s. hope this helps.
May 04, 2015 | Kicker Car Audio & Video
How do you hook up 3 12 inch woofers to an 1800watt audiobahn 2 channel amp to receive more depth in the bass?
Hi, im a retired installer so let me see if i can help you out. First, you need to get the impedance of your woofers. Next, you need to find out if your amp is bridgeable. That means you can make both channels tie together. Now here is your issue to consider. Running an odd number of woofers may not be the way to go because of your impedance. That being said, if you can get me the info above i can tell you the best way to set you up.
May 03, 2015 | AudioBahn Car Audio & Video
What's the best way to hook up my jl audio 13" w 7 sub to my jl audio 1000/1 amp
the best way? hmm. i would start off with some wire. Keep in mind that you will need to separate the positive (usually red or has a stripe or marking on it) from the negative (Black usually is the common color for this wire) and hook the up according to your amps positive and negative hook ups / terminals following your sub-woofers terminals. then depending on your sub woofers Voice coils (Duel or single voice coils) yours are duel or quad coils but i\'m sure they are duel (2 of each positive and negative equaling a total of 4 posts on each sub-woofer). figure out your amps ohm load handling and does your amp run hot (1,2 or 4 ohm stable some are even less like 0.5 or lower) i would run at a 1 or 2 ohm load as that is usually standard on 1 channel amps. make sure to check your wiring and if your not sure about ohm loads just Google wiring for sub-woofer ohm loads such as 0.5 ohm, 1 ohm, 2 ohm or 4 ohm loads. also make sure your box is not sealed do to the fact they are siht and cant produce sound like a vented / ported enclosure keep the size as big as you can fit in your car or truck the bigger the better. i had one 8\'\' sony sub pounding like a 15\'\' sub real loud . Also MDF particle board is garbage it causes port noise and absorbs water
Apr 28, 2014 | Car Audio & Video
What would be the best settings on a pyramid arctic 1000 watt amp for one JL audio w1 12
Your sub is a 4ohm woofer, running it in bridged mode + on right connection - on left connect as market on sub will give the best output. Your sub is rated at 75w to 300w and in this configuration will be getting just over 100w which about all the amp can provide with your sub/amp combo.
I don't know where they get the 1000w rating from either? the maximum the amp can possibly provide is 150w if running a 2ohm woofer in bridged mode.
Mar 08, 2012 | Car Audio & Video
QUESTION ABOUT SPEAKERS. SPRCIFICALY WOOLFER. WHAT KIND OF WOOLFER SHOULD WORK BEST WITH THIS AMP?
hi,
Do you mean sub woofer. Then you can select any brands Active sub woofer ( active means built in amplifier) to connect with your system. They comes in different power (watts). you can use an active sub woofer with 100W output.
connect the sub woofer pre out of you amp to the pre input of sub woofer.
ok
Feb 05, 2011 | Technics SA-EX500 Receiver
I have an sony xplod 4 channel 600 watt amp
First are they in the same box? If so and they are sharing the same air space running one amp to both is best andwill perform better. One woofer could be over powering the other and or you could have a woofer problem. A lso your wiring coul be problem. When amp is bridged it changes the OHM reading and output your other woofer may not be rated at or able to handle a lower Ohm rating also it coul blow that woofer if it hasn't already hapened . Be careful. check woofers independently for operation and check the non performing woofer on an unbridged power source or amp. Hope this helps. Write back if not.
May 06, 2010 | Rockford Fosgate P112-200 Car Subwoofer
How to connect a 4 ch amp to 4 speakers and sub-woofer
http://www.audiosavings.com/content/ebay/SubWiring.html
this link will help u understand the wiring & how too wire your speakers...
as far as speaker ohms & amps go, 4 ohm speakers should be wired too 2) two ch. amps.
hope i was of sum help.
Jul 14, 2009 | Car Audio & Video
Djust
alot of times its not just the amp that gives you better sounding bass.. A lot has a to do with a few other factors as well.. first off your subwoofer.. the bigger the subwoofer the deeper the bass. Some woofers exturde, or flex differently depending on the quality and structure of the woofer.. 2nd is gonna be the sub box. different size boxes will give your sub diff. depths of bass. ... general idea is the bigger the box deeper the bass. But if your woofer is not supplied enough power a big box is useless.   With that size amp your best bet is too run a single woofer. Probably a 10inch woofer would sound the best.. but it in.75cub inch. sealed box.. should sound great.
Nov 11, 2008 | AudioBahn DUB Mag Audio DUB2502 Car Audio...
Sub-woofer malfunction
if the amp is going bad repair or replace, the sub you would probably have to replace, this would be the best fix. but check the amp also.good-luck!
Jul 12, 2008 | Logitech Z-5500 Computer Speakers
Subwoofers and amps
If you replace the head unit, that will make a big difference. If not, then it really depends on the type of music you primarily listen to. From a single sub setup, an 8 or 10 in a sealed box is best for punchy base, i.e. alternative, hard rock... A 12, 15, or 18 is designed to reach those lower bass frequencies and are suited better for ported enclosures. I.e. Rap, bass heavy Regge, etc...However, that's not to say that you can't go back and forth between them. The main difference is that a 10 and below tends to be more accurate, and can follow the kick drums, for example, a lot faster than larger woofers. Determine what your primary listening music is, what you want out of your system, and a maximum price for everything first. Then, I can suggest woofers, amps, etc.
Jun 24, 2008 | Car Audio & Video
Solid Audio Formula Series F27 2-Channel Amplifier Car Audio Amplifier Logo
70 people viewed this question
Top Solid Audio Car Audio & Video Experts
xxxxxx xxx
Are you a Solid Audio Car Audio and Video Expert? Answer questions, earn points and help others
