How to I get connected to the internet on my Toshiba Libretto 100 CT
  • jarjar May 21, 2012
    You can use a PCMCIA to USB adapter then plop a usb wireless nic into that.
    for web use IE 6 or Dillo. Better browsers will run but very slowly. highly rec adding an SSD. it makes using it much better.
    or out of the box you can maybe use IRDA or parralel port. but that's more trouble than it's worth.
  • 428 Answers
That is a pretty old machine. Not sure whether it has enough resources to browse web. I don't think that machine has either usb or modem port. If so you need to buy a router which has a serial connectivity. I m not sure whether they are available. You can use a serial to usb converter to access it. There are some techniques to overclock the CPU as well. You can check it by surfing the net.
Please rate the answer and a testimonial (comment) if the solution helped you to solve the problem...Thanks for contacting Fixya
Posted on May 30, 2010
Toshiba libretto 50 ct wont boot
I haven't encountered multiple beeps on shutdown - but multiple beeps on startup is usually an indication of a memory issue. Frequently can be resolved by simply taking memory modules out and re-inserting them.
If problem continues, may need to replace memory chip. If more than one chip, put one in at a time and startup to see which chip is causing the problem.
Not sure, based on your description of the problem, if this is the issue - but certainly worth a try.
Best of Luck!
Jan 03, 2013 | Toshiba Libretto 50CT Notebook
Internet hookup wiring needed
That a bit vague. Your ISP should supply everything but a Ethernet cable to plug into computer.
Dec 20, 2012 | Toshiba Libretto 110CT Notebook
My toshiba libretto laptop won't turn on how do i fix it
first, I will advice that you check the adapter, see if its still working. The adapter might be the reason your laptop is not working.
If you have confirmed that the adapter is still good, let me know so that I can direct you further.
Take care.
May 28, 2010 | Toshiba Libretto 50CT Notebook
Does anybody know if a Toshiba Libretto U100 can run on a DDR PC2700 333 1Gb ECC so dimm?
Go to www.crucial.com
They will run a test on your laptop and tell you exactly which memory will work on your machine
It is free and safe
Jan 29, 2010 | Toshiba Libretto U100 PC Notebook
Toshiba libretto BIOS Reset
If there is a password that is not allowing you to reset the BIOS, I would recommend going to the following website and having one of the technicians use their proprietary devices that can unlock it for you. Im not sure if there is a charge but this may be the best solution to avoid any headaches. Just let them know there is a bios password preventing you from entering the BIOS and you need it removed and they should be able to help you from there.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/gaspLocator.jsp?subs=tais
Mar 06, 2009 | Toshiba Libretto 100CT Notebook
I cant reformat my Toshiba libretto L3. I tried everything
You cant boot from cd. Try changing the boot order in the BIOS and allow the CD to have ownership over the Harddisk Drive. This way the computer is forced to boot from the CD.
Jan 16, 2009 | Toshiba PA2502U - Libretto 100, 110,...
Upgrade the Toshiba Libretto 50 CT
if you want to improve the speed of your laptop you could buy a faster harddrive with an higher rpm per minute than the one installed in the unit, that WILL speed up the system:), and yes its possible to boot from the 2gb flash card but i recommend if you are going to use a flash card you get a bigger one:)
Cheers
Jan 04, 2009 | Toshiba Libretto 50CT Notebook
TOSHIBA LIBRETTO 50CT NEEDS LINUX
Hello there
If you haven't got it already, download "Freespire" its a free linux download and really easy to use!!!!!!
It comes equipt with all the software you will need and a automatic updater which will download anything you need for the system.
Its easy to set up your internet and use office software (you can even view microsoft docs), with this you can even connect and chat to MSN, Yahoo etc
give it a go you will like it!!!!!!!!!
Kind regards
Dec 14, 2008 | Toshiba Libretto 50CT Notebook
Libretto 100ct
Está desliogando sozinho.... o que fazer?
Oct 25, 2007 | Toshiba PA2502U - Libretto 100, 110,...
Computers & Internet Logo
79 people viewed this question
David Payne
David Payne
