Question about Philips Televison & Video
Hi, how are things? I have a problem with my DVD player. The Phillips DVP 3005. The colour is a little bit off. Almost black and whitish. I would like to know to fix this problem please. Thank you
  • 10,515 Answers
This seems to be a connection related problem between the TV and the DVD. The causes include:
1) It is possible that one of your component video output (red,green and blue jacks) is connected to a composite video input(yellow jack) on the TV.
2) You are using the S-video output while your DVD player's output switch is not on the S position.
3) It could be because of a defective cable.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on May 26, 2010
My Philips DVD DVP 3005 won't play any sound. The picture is absolutely fine though. What can I do?
Find out the protection transistors between buffer ic 4558 and sound output rc socket and remove them and also check both + / - 12V on ic 4558
Thanks & regards
Shrinath inde
maharashtra india
Dec 28, 2010 | Philips DVP-3005 DVD Player
How to clean the dvp 3005 DVD head player?
Cleaning the laser lens
1) Remove any CDs from the unit and unplug all leads. Turn the unit upside down and use the small, flat screwdriver to pop out all the little plastic and rubber screw covers.
2) Take your normal sized Phillips screwdriver and unscrew all the screws.
BE CAREFUL not to damage the eject/power button ribbon cable, as these are very fragile.
Take a cotton bud and careful place some of the alcohol on it (but not so much that it is dripping everywhere). This alcohol is the same (or similar) to the small bottle of alcohol which is in audio and video cassette cleaning kits. This is probably the best way to locate a source. Locate the lens (the circular glass part) and very gently rub the cotton bud around the lens in circular motions for about 30 seconds, being very gentle. Once done, flip the cotton bud over and dry the lens with the other end for about 10 seconds.
You have now completed the cleaning process. This often cures read errors and should always be attempted first. Reverse the dismantling process and put the machine back together, making sure you DON’T TRAP the eject / power button ribbon cable, as this can cause serious problems for you if it happens.
Power on the unit and try to load both a CD. If all works fine then CONGRATULATIONS on completing the guide successfully.
Jun 02, 2010 | Philips DVP-3005 DVD Player
How can I make the DVP 3005 DVD player multi regional
I think you are looking to make your DVD Player, Region Free?? If so, here is a link that has an upgraded firmware that is NOT RELEASED BY PHILIPS, so use this at your own risk. Please read very carefully before attempting any of this. Use at your own risk.
Click Me
Heop This Helps
Oct 06, 2009 | Philips DVP-3005 DVD Player
I have lost the operation manual,how can I get a replacement.?
go to www.phillips dot com and there should be a link to download the manual
May 20, 2009 | Philips DVP-3005 DVD Player
DVD player only plays DVD in black and white - what's wrong?
Ok,
I'm not sure what you mean by digibox. Under what conditions are you able to see things in color? Is a digibox a seperate device you can get to work with the same connection as your player? If one device displays color on the same connection and another doesn't then that seems to rule out the television being the problem. Can you clarify a little more?
Jan 11, 2009 | Sony DVP-NS330 DVD Player
Software upgradation
Its called firmware, and you would need it on a disc, you would have to get it from Philips or maybe their website.
Don't download firmware from anyone else but Philips.
Feb 12, 2008 | Philips DVP-3005 DVD Player
No video, only audio
With the first problem i would check the Scart lead to make sure both ends are pushed all the way in, if the lead is in at an angle that can cause loss of colour or picture, and that none of the pins are bent. Failing that try another Scart lead.
Most DVD players need to have progressive scan enabled in the settings menu, are you using a HDMI lead or Video Composite, (5 phono plugs)? HDMI is the better of the two!
Nov 27, 2007 | Philips DVP-3005 DVD Player
Televison & Video Logo
13 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
