Question about Konica Minolta Bizhub c203 Copier
Bizhub c203 I changed the chips in the Image Units and it worked fine. There was an error light on the machine so I unplugged the machine and plugged it back up. Now when it boots up it locks out and gives me an error code C-D252. It says to turn the main switch off and then back on. If it gives the error again to call a service tech. I called a service tech but they cannot get here for a few days. This does not help me. What could be the problem? I did a trouble reset and it still does it. I changed the chips back to the original ones and it stil does it. Thank You for a fast response.
  • Konica Minolta Expert
  • 316 Answers
High voltage problem
Posted on Jun 07, 2010
How do we properly shake the image unit of the Konica Minolta bizhub c203 to clear error message C-2558?
ugh sorry replace the toner hopper and all of the componets if a new iu dosnt fix the problem
Aug 18, 2014 | Konica Minolta Bizhub c203 Copier
How to repair c203 bizhub error code 5370
Cooling Fan FM-6 for the MFP board, rear of machine a small fan between to large fans.
filter clean?
DUST?
May 09, 2014 | Genuine Konica Minolta Konica Bizhub...
How can I solve error code c255A
From another site
Details Subject:
C-255A (C255A), C-255B (C255B), C-2559 (C2559) or C-255C (C255C) at power up.
Description:
C-255x code at power up.
Solution:
CAUSE: The K (black) IU (C-255C) has failed. The M (Magenta) IU (C-255A), Y (Yellow) IU (C-255B) or C (Cyan) IU (C-2559) is not fully seated or has failed.
SOLUTION: Replace the K (black) IU (Item #A0DE02F for the bizhub C203/C253 and Item #A0DE03F for the bizhub C353). Reseat the color IU and if the problem persists, replace it. Item # Color IU Model
A0DE0CF Magenta bizhub C203/C253
A0DE0DF Magenta bizhub C353
A0DE06F Yellow bizhub C203/C253
A0DE07F Yellow bizhub C353
A0DE0HF Cyan bizhub C203/C253
A0DE0JF Cyan bizhub C353
SPECIAL NOTE: Solution contribution by Tom Kelly, Workgroup/SSD
Options:
None Specified Details Subject:
After toner installation, C255x code within a few hundred prints.
Description:
C2551, C2553, C2555 or C2557 codes.
Solution:
CAUSE: Toner is not supplied due to abnormal position of coupling.
Normal condition The coupling is blocked by bracket
May 03, 2014 | Konica Minolta bizhub C250 All-In-One...
Cyan TCR Sensor adjustment failure
Replace the image unit code has nothing to do with the chip!!!
Feb 04, 2014 | Konica Minolta Bizhub c203 Copier
Error code p21
This is a color registration error. You can try cleaning the PH units and registration sensors but this model had a TSB about PH unit failures. New PH units were shipped to dealers for every machine they had in the fleet for field repair. If your copier didn't get the new PH units during the "recall" period you will have to pay for them. They must be replaced as a set and you are looking at thousands of $ to repair.
Aug 03, 2013 | Konica Minolta Bizhub c203 Copier
I got an error code 2556 on my c203.please help
Very very common issue... did you clear it yet?? if not to clear it open and close frount door. then to fix issue change toner.... if that doesnt do it try running something with lots of yellow on it... the code means there is too much yellow toner in the image unit... if that wont work then replace yellow image unit.OH you may want to clean the belt sencors too its super easy i can help if needed
Sep 21, 2011 | Konica Minolta Bizhub c203 Copier
Code error p9 p21 p16 c203 what can i do?
The p error codes you have are due to the test pattern being put on to the transfer belt to check the image density control
The first thig to do is to check and see the condition of the transfer belt and if it has reached life or looks bad replace it also on taking out the transfer belt directly where it goes in there is a cover slide the cover and clean out the idc sensors imgae density control sensors
Also there is firmware to correct the issue do this last the above will get rid of your issuesAlso add toner to all the units manually add the toner as well
Feb 11, 2011 | Konica Minolta Bizhub c203 Copier
Imaging units for Bizhub C300
There is no setting you can extend the life, however, in the service mode ( utility->meter count-> stop, 0, 0, stop, 0, 1) then press stop, 0, c. There should be a setting in there that you can disable the "image unit life end stop" setting. You will get a message every 5 minutes telling you to change the unit, but your machine won't stop working. Otherwise you can just change the chip in the image unit.
Jul 26, 2010 | Konica Minolta bizhub C450P Laser Printer
How do you remove the drum unit on a bizhub C203
This machine has more than one drum unit, its a color machine. You have three color and one black as well as 4 developer units. You need to know which one needs to be removed. Shut the machine down unplug it from the wall. The upper units are the drums, which should easily slide out. If I remember correctly you have to flip up a clip on the front of each drum unit first to slide the drum out.
Apr 08, 2010 | Konica Minolta Bizhub c203 Copier
Konica Minolta Bizhub c203 Copier Logo
637 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
